Old 05-05-2011, 08:30 PM   #211
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
Originally Posted by Geek View Post
Nope.. didn't weather proof them in any way. I think they are epoxy dipped.
that's sweet!
I was thinking of getting rid of the stock grip switch for the throller you have... how is the wiring done?
good job by the way. Keep some room for the HID behind the light... it's packed... I don't dare opening mine again
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 05-05-2011, 09:17 PM   #212
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,748
I still run my grips off of the KTM hotgrips wiring - works well, it all boils down to a couple of spade connectors that plug into ACC2 - the only key is keeping your wires positioned such that they are "chafe free" from lock to lock.
the heat-troller on the other hand is an entirely different animal. Because of the potential amps involved with my two 12 volt powerlets; I ran direct wires up from the battery for them and went from there.
Old 05-05-2011, 09:25 PM   #213
bikyto
bikyto's Avatar
Oddometer: 2,190
Thanks Geek! I'll try to give it a shot. I have the HDB setup as well.
I'm not sure how the wiring from the stock wire will hook up to the throller.
Old 05-05-2011, 09:29 PM   #214
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,748
The dual heat troller itself comes with a "recommended maximum of 15 amps" and includes an inline 15amp fuse.
not sure.. but I think that might be more than ACC1 recommends.
Old 05-05-2011, 09:32 PM   #215
bikyto
bikyto's Avatar
Oddometer: 2,190
I think so too. I have them to a separate fuse box directly to the battery right now. But that stock Ktm switch either does nothing or burns my hands... Gotta find a better way
Old 05-06-2011, 07:29 AM   #216
1Buffalo
High Plains Drifter
1Buffalo's Avatar
Oddometer: 79
...and last but not least I decided to check out how the paint turned out on the bottom of my skid plate
Nothing to see here.. move along
I'm sure you mention it someone in one of your post but is that the Black Dog plate?
1Buffalo is offline   Reply With Quote
Old 05-06-2011, 07:55 AM   #217
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,748
Yes, it is the black dog skidplate that I painted black(er).
Old 05-06-2011, 03:11 PM   #218
Subutai
Oddometer: 555
The Euroswitch.
..which isn't "legal" in Europe
Euro-spec bike; turn the power on from the ignition, and low beam is on. Low/high/overtake signaling controlled from left handlebar switch/trigger. Low beam is always on, as you suggested earlier.
Is there a gasket on the light switch? Looks like there is not, and those switches have a habit of rotting from the inside. A rubber sleeve coated one would be better. Seems the designers think that it never rains or the bike is not ridden during rain. Where did you get the switch?
Subutai is offline   Reply With Quote
Old 05-06-2011, 06:18 PM   #219
FINNDIAN
Mine goes to 11
FINNDIAN's Avatar
Oddometer: 1,758
thanks for the pic Geek
It looks as though all the wires are run up to the rh control already. Maybe all a cheap canadian would need is a waterproof switch and a little soldering?
ps. my Black is getting blacker too.
The more side roads you stop to explore, the less likely that life will pass you by. ~Robert Brault. 2004 KTM 950 S GO!!!!(Blacked out),03 Beta Rev3, 1973 Rokon Trailbreaker 2x2, 1999 Intruder 1500, 08 Aprilia rxv450, 90 DRBIG 800,79GS850
Ride Reports
FINNDIAN is offline   Reply With Quote
Old 05-07-2011, 08:02 AM   #220
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,748
There is not a gasket - there is not on the stock KTM switches either.
I got the switch from KTM twins.
Old 05-07-2011, 08:03 AM   #221
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,748
Nice! Are those Conti trail attacks?
Old 05-07-2011, 08:04 AM   #222
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,748
Friday Night Commute.
took the long way home
Old 05-07-2011, 01:22 PM   #223
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,748
My package arrived direct from China.
Quarter shown for size reference.
Now I just have to figure out how to wire it in
Anybody know the wire colors in the euro switch assembly?
Which of these wires does what?
I shoulda bought a "plug'n'play" setup from one of our KTM toy-sources.
Geek screwed with this post 05-07-2011 at 01:32 PM
Old 05-07-2011, 04:11 PM   #224
Sacal
Sacal's Avatar
Oddometer: 132
ad astra per alia porci
Sacal is offline   Reply With Quote
Old 05-07-2011, 06:51 PM   #225
VertigoCycles
Oddometer: 157
You're wiring them direct to the switch assembly? Why not wire them through the molex plug for the headlight assembly?
Sean Chaney
Vertigo Cycles
Flickr
VertigoCycles is offline   Reply With Quote
Times are GMT -7.   It's 03:40 AM.
