Old 02-21-2011, 06:45 PM   #16
EvilClown
Reality show stunt double
EvilClown's Avatar
Oddometer: 16,752
These are our Golden Years. ~ EC
The future is no place to place your better days. ~ DMB
The world is a book and those who do not travel read only one page.
~Augustine of Hippo
EvilClown is offline   Reply With Quote
Old 02-21-2011, 07:32 PM   #17
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,706
It might be a couple of days before I get to the fuel tanks again
Old 02-22-2011, 08:09 AM   #18
unaweep
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 20,121
Originally Posted by xianx View Post
just when i think im over my "wanting an Adventure" phase i see your bike and i've got to have one again.
i need a 12 step program or something.
you've got a beautiful ride brother
Fuck that. 12 step programs are for quitters!
I don't have to be right to argue.
NICO
unaweep is online now   Reply With Quote
Old 02-22-2011, 08:50 AM   #19
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,555
Out of curiosity why did you decide to go w/ the Safari tank vs. the rear mounted Adventure tank?
Yellow Pig is online now   Reply With Quote
Old 02-22-2011, 09:22 AM   #20
EvilClown
EvilClown's Avatar
Oddometer: 16,752
Originally Posted by geek View Post
...i looked at the various fuel options and they all have their advantages and disadvantages. For me, my adventure is my adventure touring bike and i want the ability to go as far as possible between fill ups when i need. An option quite a few of my buddies have gone with are the adv tanks that neduro has designed that replace one of the exhausts. as it is, i have some other plans for the back of this bike that the advtank will not be compatible with (though i'll probably use ned's system when i add an se to the stable).
Old 02-22-2011, 10:37 AM   #21
FINNDIAN
Mine goes to 11
FINNDIAN's Avatar
Oddometer: 1,756
@ yellow Pig
Geek said this at the beginning of this thread .
Originally Posted by Geek View Post
I looked at the various fuel options and they all have their advantages and disadvantages. For me, my Adventure is my Adventure Touring bike and I want the ability to go as far as possible between fill ups when I need. An option quite a few of my buddies have gone with are the ADV tanks that Neduro has designed that replace one of the exhausts. As it is, I have some other plans for the back of this bike that the AdvTank will not be compatible with (though I'll probably use Ned's system when I add an SE to the stable).
I'm actually going with both. You can never have too much fuel when riding in the middle of nowhere.
The more side roads you stop to explore, the less likely that life will pass you by. ~Robert Brault. 2004 KTM 950 S GO!!!!(Blacked out),03 Beta Rev3, 1973 Rokon Trailbreaker 2x2, 1999 Intruder 1500, 08 Aprilia rxv450, 90 DRBIG 800,79GS850
Ride Reports
FINNDIAN is offline   Reply With Quote
Old 02-22-2011, 12:34 PM   #22
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,706
See? As per post # one, Dan's the reason why I'll add random photos to this thread
I'm guessing that loaded Safari tanks will be a workout in sand... good thing I already have upgraded my fork springs.
Geek screwed with this post 02-22-2011 at 12:42 PM
Old 02-22-2011, 01:53 PM   #23
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,706
Transferring Hardware
Murphy's Law.. My stock tanks were nearly full. I don't have nearly the patience to drain them through the petcocks so instead I made a mess.
The instructions are rather sparse.. a single piece of paper - but I don't think you need anything more; it is pretty obvious what you do.
I like sentence one... something along the lines of "if you can't figure this out, get a mechanic's help"
Two nuggets of information on the sheet:
1) rinse the tanks out with a small amount of gas and discard to get rid of shavings.
2) use an anti-seize compound, NOT a thread-locker, on all bolts going into brass.
So first I rinsed out the tank and made another mess
I decided to to the left tank first as it's the "more complicated" one (although I dunno if you can really call any of this complicated).
Here's the stuff you need to transfer over:
The fuel level sensor
The petcock
The crossover petcock
..and the 3 sets of rubber mounts.
First I removed the fuel level sensor. If you ever wondered what it looks like on the inside.. now you know
Next came the crossover tube. For some reason they included different bolts for mounting it (and for the petcock too). I dunno why but just incase there was a real reason I used their hardware
If you ever wondered what the petcock looks like on the inside.. now you know
I then mounted it on the block-off plate. If I owned a 990 instead of a 950, I would insert my fuel pump into the hole that this block-off plate blocks.
As it is I mounted the petcock to the bottom of it with the supplied hardware.
In the background you can see the rubber gasket the plate uses to seal against the tank.
...transfer all the rubber mounts over:
et Voila...
I did one more swish with fuel, dumped it out adding to my mess, and test hung the tank on the bike
Easy peasy. Maybe 15 minutes work and that included playing with my camera.
...and at this point I came inside because the gas fumes are making me sick :puke
I'll go do the other tank after the vapors expire a bit.
Old 02-22-2011, 02:00 PM   #24
boat.man
Chief bottle washer
boat.man's Avatar
Oddometer: 170
Geek,
are the tanks black plastic or are they painted? how would you rate the appearance of them compared to the OEM tanks? is that an "adventure" decal on the side or what?
Thanks!!
When I read about the evils of drinking, I gave up reading.
07 KTM 990 Adventure
06 TE610 Sold
2 sleds
lets go play!!
boat.man is offline   Reply With Quote
Old 02-22-2011, 02:09 PM   #25
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,706
They are black molded plastic (not painted).
You definitely don't by them for finish. They are not glossy at all and the surface is by no means perfect. You can see molding pocks & stuff on them (little sand grain sized things here and there). If you are concerned about "finish" you will not like them. I'm trying to think of an equivalent plastic finish in every day life.. but all that comes to mind is "a thick version of the plastic used in dirtbike gas tanks".
That and....
The white ones turn yellow.
The orange ones look like a giant pumpkin.
The black ones explode in the sun.
I chose the lesser of the 3 evils. Why did I spend $1500 on these again? (j/k)
All that said, I really like the finish on the tanks. It gives the bike a "tougher offroad" appearance so that the harley guys don't think you are on a sportbike with knobblies
I dunno how the "adventure" labeling is done. I was looking at it and I can't tell. I dunno if its a "surface mar" in the molding or if it is sprayed on or what
I like it a lot though.. I'm digging the subtleness of the black on black
Geek screwed with this post 02-22-2011 at 02:15 PM
Old 02-22-2011, 02:10 PM   #26
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,706
Does anybody know if it matters which way up this thing faces? Now that I think of it.. i have no idea which way up I put it...
Old 02-22-2011, 02:22 PM   #27
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
Ooopsie!
Well you don't need it anymore
I think it's down... If I remember correctly... I think
Will you be adapting crash bars on these monsters?
And yes I want them too
bikyto is offline   Reply With Quote
Old 02-22-2011, 02:26 PM   #28
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,706
p.s. I do have a "non-glossy" set of rear fairings on the way too... they'll help with the blackout.
That way I can squirrel away my entire set of stock black body work.
I also gotta figure out how to get the damn yellow sticker off my skid plate
Old 02-22-2011, 02:26 PM   #29
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,706
Originally Posted by bikyto View Post
Ooopsie!
Yeah.. I'll just have to remember to fill up on the first Tuesday of every month
Old 02-22-2011, 04:00 PM   #30
FINNDIAN
Mine goes to 11
FINNDIAN's Avatar
Oddometer: 1,756
Did you get a set of used side panels? I was planing to paint a used set with a flat or semigloss.
Ride Reports
Times are GMT -7.   It's 09:32 AM.
