Old 03-25-2012, 07:48 PM   #361
Johnf3
Oddometer: 1,055
Another option on the brake line to to convert to the 990S style line. It will work great with your high fender set up and is a very clean install that cleans up the brake line routing.
When CJ gets around to making a caliper relocator bracket so I can run a single 320mm disc, I will have an extra 990S dual brake line.
I guess if you go with a left brake line you will need to find a 2004 line since that was a 265 front travel bike.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 03-26-2012, 06:41 AM   #362
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,748
From what I understand.. wait times may be going away!
More details to come.
Old 03-26-2012, 06:43 AM   #363
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,748
Hmmm.. have any pics?
I thought about moving the double banjo to the right caliper and then going up and over the high fender with the left line to the left caliper (kind of he opposite of how the bike came stock... but using two full length lines instead of that shorty line).
Old 03-26-2012, 07:49 AM   #364
Johnf3
Oddometer: 1,055
I kept my low fender when I did my brake line conversion but it will work the same with the high fender. I have an aux light bracket that will not work with a high fender. I will try and post a picture tonight.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Old 03-26-2012, 08:06 AM   #365
Tijuana_Taxi
Oddometer: 329
Orangecicle switched to the 990S style here includes a list of parts
http://advrider.com/forums/showthread.php?t=763632
Tijuana_Taxi is offline   Reply With Quote
Old 03-26-2012, 11:57 AM   #366
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,748
...we have a roller... wow it is tall. I'm 6 foot and when I stand beside it with the bike straight up and down, the tip of the handle bar hits me right in the nipples.
(I just wanted to type nipples)
I'm still trying to decide where to install the 3 step ladder...
Geek screwed with this post 03-26-2012 at 01:21 PM
Old 03-26-2012, 01:52 PM   #367
Narsisco Lopez
Addlepated
Narsisco Lopez's Avatar
Oddometer: 2,207
I wonder if Sidi makes boots with 5" soles?
Narsisco Lopez screwed with this post 03-26-2012 at 02:12 PM
Narsisco Lopez is offline   Reply With Quote
Old 03-26-2012, 02:04 PM   #368
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,566
I just had to quote this pic,
....just because it's a crappy picture from Geek.
I'm not used to that....
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 03-26-2012, 02:13 PM   #369
Narsisco Lopez
Addlepated
Oddometer: 2,207
He just had Lasik on Friday; his eyes must not be back to normal yet... give him a break
Old 03-26-2012, 02:48 PM   #370
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,748
I was too lazy to go in the house and get a better camera so I used my phone and tapatalk
Old 03-26-2012, 02:52 PM   #371
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,748
Fixing "little annoyances"...
My center stand has been a little too tight.. so I spread it a bit to give the swingarm a little more clearance
of course... now that I finally got around to doing that... the thing is waaaaaay too short and is going to have to be replaced
(with both wheels on the ground the center stand has air under it )
My bike has had a small weep on the left side for a couple of years... just enough to make a mess.. not enough that I've bothered to fix it. I've been assuming (hoping?) that it is the o-ring behind the oil pressure switch...
Since there is no oil in the bike and the side stand is off.. no better time than the present to change it
Fingers crossed this fixes it.
Old 03-26-2012, 05:14 PM   #372
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,748
adv db is screwing up
Old 03-26-2012, 06:13 PM   #373
xdbx
Motorcycle Connoisseur
xdbx's Avatar
Oddometer: 2,504
That's the neutral switch there, actually bud...
Oil pressure switch is up in the trough of the V, on the back of the front cylinder I believe. Do yourself a favor and pull the little spring out of the contact on the switch and stretch it now while you have it apart. Ensure your neutral light keeps on tickin...
Daniel
2005 KTM 950 Adventure S
2004 KTM 525 exc
2006 Beta Rev3
xdbx is offline   Reply With Quote
Old 03-26-2012, 08:15 PM   #374
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,040
Hi Geek, what's with the silver subframe ?
Same issue on my bike, neutral sensor has been weeping for a couple of years. I replaced the oring last fall and it still weeps. I now consider it a chain lube device.
Glad to see your big twin being put back together,i've been missing the HDR photos of Colorado
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Old 03-26-2012, 09:44 PM   #375
Hobbes950
Darth Kitten
Hobbes950's Avatar
Oddometer: 3,947
Centerstand trade?
I never use mine because it is a pain to get it up. Maybe one a tad shorter would do the trick?
What is the height difference Geek?
When in doubt, take it as a compliment.
My Ride Reports
Hobbes950 is offline   Reply With Quote
Times are GMT -7.   It's 05:45 PM.
