Old 03-28-2012, 07:26 PM   #391
jay71
Farklin' Poser
jay71's Avatar
Oddometer: 316
Ed- I have a bunch of thin, neoprene kayak outfitting foam as well as contact cement if that Shorai foam isn't tough enough.
2006 KTM 950 Adventure
jay71 is offline   Reply With Quote
Old 03-29-2012, 07:34 AM   #392
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,072
Thanks J.. I'll give the Shorai foam a try and if it doesn't work I'll give you a shout.
If I can get my 950 rolling are you up for some time @ IMI?
Old 03-29-2012, 07:36 AM   #393
Narsisco Lopez
Addlepated
Narsisco Lopez's Avatar
Oddometer: 2,208
Man, I love the new storage box.
Narsisco Lopez is offline   Reply With Quote
Old 03-29-2012, 05:25 PM   #394
jay71
Farklin' Poser
jay71's Avatar
Oddometer: 316
Yessir- only problem is I'm on call this weekend so I wouldn't be able to until possibly next week sometime. Give me a jingle when you're up for it. If you need any foam and want to swing by Denver this weekend I'll be here twiddling my thumbs waiting for the pager to go off.
Old 03-30-2012, 07:42 AM   #395
Narsisco Lopez
Addlepated
Oddometer: 2,208
Hey Geek... what make/model torque wrench is this and where did you get it?
Old 03-30-2012, 08:19 AM   #396
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,072
Craftsman/Sears. I don't use it enough to warrant the extra money for a snapon...
Old 03-31-2012, 12:09 PM   #397
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,072
Spent two hours cleaning the garage so I could focus on the 950.
Did a bit of this...
to make this (still kicking myself for just not buying a pre-made one from CJDesigns)...
which required the cutting of this...
so I could have the clearance of this
then I went to do this....
but realized I still haven't done this...
...so I can't start the bike because the ignition key is on the bench on the old top clamp instead of on the bike.
Did I mention its 80 degrees here again today and I should be riding?
Old 03-31-2012, 12:23 PM   #398
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Bahahahahaha!
I could do that!
...I've certainly done worse...at least nothing's broke and you're not bleeding, yet...
S
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 03-31-2012, 12:24 PM   #399
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,072
I do have an electrical tape bandage on my thumb from trimming my 500's license plate to better fit.
I probably need a tetanus shot
Old 03-31-2012, 05:01 PM   #400
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,072
How hard is it to steal an LC8?
One phillips screw driver; remove two screws... remove the bottom half of the ignition key ... rotate the internal tumbler to on.
Old 03-31-2012, 05:01 PM   #401
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,072
Why am I grinning ear to ear while I'm taking this photo?
Old 03-31-2012, 06:24 PM   #402
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,072
...cuz the engine's running in the photo
I had to go for a booger around the neighborhood.. I slapped things back together (you know the routine.. just the corners of the airbox.. 2 bolts for the glove box.. just the top bolts for the fuel tanks.. slide the headlight in and
Holy heck does it feel different.
I can't come anywhere near touching the ground.. if one foot is down the other foot is 8 inches in the air (I wonder how much the suspension will pack down?) The geometry with the 20mm offset and the 4 inch risers is also completely different feeling. I think I might remove the damper and get to know the feeling and then reapply it afterward...
I have to take it apart and finish a bunch of things.. but at least I got a few minutes on her this evening.
Geek screwed with this post 03-31-2012 at 06:30 PM
Old 03-31-2012, 06:43 PM   #403
Geek OP
oot & aboot
Geek's Avatar
Oddometer: 31,072
Gotta like syncing the cylinders with this thing.. super easy.
Stick it in the front hole... note the number
Stick it in the back hole.. make sure its the same number
Try it at different RPMs
s
Old 03-31-2012, 06:53 PM   #404
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Try it at different RPMs s
Remarkably consistant!
Thanks for sharing your process...
AdvGa is offline   Reply With Quote
Old 03-31-2012, 07:31 PM   #405
jay71
Farklin' Poser
jay71's Avatar
Oddometer: 316
Looks great Ed!! Like the new stance- now I'm second guessing not going the full monty like you did!
jay71 screwed with this post 03-31-2012 at 08:04 PM
Times are GMT -7.   It's 06:22 PM.
