Old 02-22-2011, 06:58 PM   #1
DurtKlod OP
DurtKlod's Avatar
Oddometer: 1,434
Anybody running a 13 tooth front sprocket on a KLR650?
2011 Kawasaki KLR650 - The bike came stock with a 15 tooth front sprocket. It didn't have enough low end for me so I dropped it down to a 14. It's lots better but still not quite low enough. I'm thinking of dropping it down another to a 13.
I'm wondering if I do drop it to a 13, will I have to change the chain because the teeth are further apart? And... if I change the chain, will I have to change out the rear sprocket to match?
It's not the limits of the bike... it's the limits of the rider on the bike.
DurtKlod is offline   Reply With Quote
Old 02-22-2011, 07:39 PM   #2
Tosh Togo
Oddometer: 1,594
No, a 13T sprocket, or any other in the same tooth-pitch range, will have the same spacing between each tooth.
btw- going one less, to a 13t cs sprocket, will be a bigger change than losing the first tooth was*. It's also really hard on your chain to run a teeny front sprocket like that. A better way would be to add a few teeth to the rear sprocket instead, for a smaller net change.
*15 to 14t is ~ 7% reduction in speed for a given rpm: 15/14= 1.071
14 to 13t is ~ 7.5% reduction in speed for a given rpm: 14/13= 1.077
Maybe. That depends on how old the existing parts are.
Tosh Togo is offline   Reply With Quote
Old 02-22-2011, 08:11 PM   #3
Gray_Rider
Gray_Rider's Avatar
Oddometer: 270
If you go to a 13T, you will find you run out of revs quickly at highway speeds. So to maintain a decent road cruising speed, you will have to rev the shit out of it.
Steve
Gray_Rider is offline   Reply With Quote
Old 02-23-2011, 12:49 AM   #4
kens_Moto650
Top end explorer
kens_Moto650's Avatar
Oddometer: 31
KLR gearing
I run 14t and 46t on my klr its pretty good for a range of things,really perks it up. Im not into big distances though, it can still overtake cars at 120km/h with that gearing.
_________________________________________
2006 Suzuki DL1000.....V-strom for victory.
http://www.youtube.com/user/kennyMoto650?feature=guide
kens_Moto650 is offline   Reply With Quote
Old 03-03-2011, 04:38 PM   #5
NDTransplant
Oddometer: 396
I ran a 14/47 for 'off-road' stuff, and put a 16 on the front for road/normal use, which is close to stock gearing.
The 14/47 was nice for trying to pretend I had a real dirtbike....really revved the crap out of it for highway use, though.
2015 BMW 800 GSA
NDTransplant is offline   Reply With Quote
Old 03-03-2011, 08:09 PM   #6
farrington300
No wait....What?
farrington300's Avatar
Oddometer: 522
put a 45 on the rear, then switch between 14 and 16 on the front for off road/road.
TE610
WR250R
farrington300 is offline   Reply With Quote
Times are GMT -7.   It's 09:52 PM.
