Old 04-01-2014, 10:08 AM   #31
Kodiakcarl
hairy n00b
Oddometer: 31
Slipscreen
Does anyone here know if the Slipscreen from Machine Moto Art fits the newer LC 1200 GS?
Kodiakcarl is offline   Reply With Quote
Old 04-01-2014, 10:22 AM   #32
RichBMW
RichBMW's Avatar
Oddometer: 2,025
No, but the Puig one does.
2015 BMW S1000R Sport
2015 BMW R1200GSAW
RichBMW is offline   Reply With Quote
Old 04-01-2014, 01:30 PM   #33
Hubbman
Hubbman's Avatar
Oddometer: 722
Chopped the stock screen...
Yep, I chopped 6.5" off the top of the stock screen and used Plastidip (sp?) on the backside to black it out.
I use this screen year round here in CA. Link to pics below....
http://www.advrider.com/forums/showt...4#post22099604
Hubbman is offline   Reply With Quote
Old 04-01-2014, 05:47 PM   #34
kendives
Oddometer: 170
I bought a used stock screen and cut it down for my summer riding. It worked quite well and I was able to fine tune it to what I liked best. Started with it a little higher than I thought I wanted and took it down gradually.
IBA 55388
kendives is offline   Reply With Quote
Old 04-01-2014, 09:13 PM   #35
EScott
Oddometer: 54
I also cut down my stock screen, but now kind of regret it, as it wasn't as successful at getting my head into clean air as I'd hoped.. maybe I'll eventually go shorter, but it looks about the same as the others pictured here...
I had much better luck with the Touratech sport screen with spoiler as there was much more adjustability between the screen itself, and the included spoiler smoothed the air coming off the top of the screen. I added a set of Tobinators and it was actually pretty good..
I was about ready to settle on this option, but ended up trying the much larger Wunderlich Ergo screen. This offers more protection, but about the same turbulence.. so I just use this one as I'm too lazy to change back and forth depending on the weather..
If anyone is interested in the Touratech screen or Tobinators, shoot me a PM.. I should clean out the garage a bit this spring.
EScott is offline   Reply With Quote
Old 04-02-2014, 05:30 PM   #36
Lonestar2112
scatology expert
Lonestar2112's Avatar
Oddometer: 7,201
Originally Posted by FlyingFinn View Post
Follows the approximate contour of the headlight.
Mikko
I painted the inside of my screen black. I found that with the screen down like your and the inside painted black, you can't see what is inbetween the screen and the instument cluster. I will often leave my gloves tucked up there. I ahve been know to leave other things there.
http://share.findmespot.com/shared/f...SKgzdmS9ir0XK3
Wypierdalaj ty chuju jebany
F*CK CANCER
Lonestar2112 is offline   Reply With Quote
Old 04-03-2014, 05:57 AM   #37
nsx
Oddometer: 157
They told me it would be available later this year.
nsx is offline   Reply With Quote
Old 04-08-2014, 11:48 AM   #38
Zoul
No Comment
Zoul's Avatar
Oddometer: 1,055
I contacted Puig yesterday. This windscreen will be available in mid May.
I had the one from Machine Art Moto on my oilhead and I loved it. the only thing that I didn't like was sustained 75mph was a bit difficult. not the best for long trips, but when you get there that windshield rocks.
Zoul is offline   Reply With Quote
Old 04-08-2014, 01:54 PM   #39
RichBMW
RichBMW's Avatar
Oddometer: 2,025
May? It's available NOW!
2015 BMW R1200GSAW
Old 04-08-2014, 01:56 PM   #40
Zoul
No Comment
Zoul's Avatar
Oddometer: 1,055
May on this side of the big pond....
Old 04-08-2014, 05:03 PM   #41
luca9277
luca9277's Avatar
Oddometer: 251
for those of you cutting the standard screen, how do you make sure the cut is clean and the lines are straight? I am thinking of cutting mine but I wonder whether I can do a decent job or it is going to look like a 3 yo with mild ADHD did it...
luca9277 is offline   Reply With Quote
Old 04-08-2014, 06:43 PM   #42
marchyman
Cam Killer
marchyman's Avatar
Oddometer: 7,417
You put some masking tape over the shield and draw a line where you want the cut. Repeat until you like the look. Then use a band saw and follow the line drawn on the masking tape. The final step is to use a file to smooth out any irregularities in the cut and some sand paper to make a nice clean edge.
I did it on my '05 a long time ago: http://www.snafu.org/pics/r1200gs/2006/0517-windscreen/
the result:
marchyman is offline   Reply With Quote
Old 04-08-2014, 06:52 PM   #43
luca9277
luca9277's Avatar
Oddometer: 251
i think the use of a band saw if the key so something decent! thanks for the suggestion!
Old 04-09-2014, 01:41 AM   #44
RichBMW
RichBMW's Avatar
Oddometer: 2,025
Order from Germany, they'll ship to you.
http://www.louis.de/_30ba2222a83526f...ex.php?lang=en
2015 BMW R1200GSAW
Times are GMT -7.   It's 05:54 AM.
