Old 03-01-2011, 04:52 AM   #46
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 15,971
Originally Posted by supershaft View Post
Thanks EPA? I think you mean the corporate farming lobby. Talk about corporate welfare. Ethanol mixed gas is a double whammy!
Science and business/politics.
Reality is so complicated.
Just to recap: SS you're saying 13.5 is the target, right?
Old 03-01-2011, 07:34 AM   #47
anotherguy
anotherguy's Avatar
Oddometer: 4,309
Most bikes make the most power at 13:1 or thereabout. The only way to know is test.
Honestly A/F R is the worst way to tune. A good exhaust system pulls some fresh air into the system giving an erroneous reading. A very rich mixture will give a lean reading through the sensor. I've had guys come in saying their bike is rich beacuse they can smell fuel in the exhaust when they are lean. A lean mixture is very hard to light and leaves a good bit of unburnt fuel in the exhaust.
Most carbed emission controlled bikes are lean off idle and way rich on the mains. The EPA testing concentrates on highway speed emissions (well used to) and that left the main circuit to be jetted fat. Why do you think DynoJet jet kit mains have their own numbering system? They got too many complaints about leaning the bike being the wrong way to go.
Having been a dyno operator/tuner for 25 years I've learned a few things about these bikes. I've had guys bitterly disappointed about only gaining 2 HP after a couple hours of dyno time. I'd tell 'em go ride the bike and come back and pay if you're happy. They only see the peak output and miss the 7HP/15FT-LB gain in the middle.
You can watch the efficiency go up as combustion chamber temps increase. I found out the hard way landspeed racing that fuel demand increases as time at WFO goes up. Someone whom I respect a great deal helped me on that one.
Oh and the reason you see ethanol in gas isn't because of farm lobbyists or politics. Economics alone. Lawsuits and costs. It's because MTBE (methyl tertiary butyl ether) seeps through steel and pollutes. No other reason.
When injustice becomes law,resistance becomes duty.
Thomas Jefferson
Old 03-01-2011, 08:37 AM   #48
midlman OP
midlman's Avatar
Oddometer: 25
Not sure on the seeping through the steel, but, MTBE is a possible carcinogen and also doesn't have an affinity to be sorbed onto organics in the groundwater/soils (eg. carbon/clays). This means it will hit the groundwater and just head downgradient until it hits your water well. You can tell how far a gasoline spill will travel on the groundwater just by tracking the MTBE as it will get there first (conservative tracer)....
Tom
91 BMW R100 GS/PD
04 Ducati 998 Matrix edition
93 Kawasaki ZX-11D
midlman is offline   Reply With Quote
Old 03-01-2011, 09:06 AM   #49
supershaft
because I can
Oddometer: 6,046
A big +1 except for the very last part anotherguy! Thanks for the excellent input.
My main point I am trying to get past is that so many people think they need to be richer when in fact they need to be leaner. On the mains that is. As you said too, just off idle often is where it really needs richening up.
supershaft is online now   Reply With Quote
Old 03-01-2011, 11:56 AM   #50
Weaverman
Damaged goods
Weaverman's Avatar
Oddometer: 58
MBT definition
Supershaft - I think I need to further or better define MBT. The term has been around forever in GM, and many people say "Mean Best Torque". We looked it up today in the GM Test Code, and the acronym is defined as "Minimum Timing for Best Torque". Simply defined, what's the minimum spark advance required to achieve maximum torque - MAXIMUM being the key term.
This is why I say MBT often cannot be achieved. Many engine designs are limited by knock before you can add enough spark advance to achieve max torque output. I've seen production engines reach the knock limit with the torque curve still rising as you add spark even with 100+ octane fuel. That's what I mean when I say many times MBT timing cannot be achieved.
I agree with Anotherguy on most points...I guess everything, it's just that I don't know anything about MTBE penetrating steel. I do caution peoplae who are looking at A/F ratios and shooting for a lean number, especially with the fuel we're using now. I don't think 13.0:1 is viable with 10%+ ethanol. It does bring with it some evaporative cooling, which helps to stave off detonation with bikes like the airhead.
Seat of the pants feel is all about torque, not the peak HP numbers on the sheet. That's (part of) why we like these airheads; they feel good in the range they run, and we're not usually redlining any bike with each gear change. The torque of an R100GS v. the torque of the F800GS is very similar. It's just that the R100 has a lower RPM ceiling and thus less HP. Quirky old POS, but out of the 30+ bikes I've owned I think it's my all-time favorite. Funny.
Weaverman screwed with this post 03-01-2011 at 12:02 PM
Weaverman is offline   Reply With Quote
Old 03-01-2011, 12:33 PM   #51
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 15,971
Absolutely.
Had a similar discussion with a friend over the weekend as we made plans to increase compression in his '88 RS. Done right it'll improve torque throughout the rev-range, which equates to more manageable power where it's useful to have it.
And better efficiency, too.
Old 03-01-2011, 12:37 PM   #52
supershaft
because I can
Oddometer: 6,046
I still don't understand what good a torque figure is going to do you when you achieve it while the engine is self destructing via pinging. Supercharged engines for instance, if it were not for pinging their torque would be amost unlimited. Why go there? It isn't doable.
I caution everybody shooting for best power too. It's real close to trouble. But best power, however close to trouble, is not trouble. It is GOOD for an engine. It is efficient for an engine.
I know that 13.1 IS viable. My bike is there and a bit above that with 10% ethanol fuel. It has been for 50,000 miles now. More power, better mileage, cleaner running engine. Like I said earlier, there are reasons why people that actually tune bikes on a regular basis set their target lines where they do. What works works.
Old 03-01-2011, 12:56 PM   #53
Weaverman
Damaged goods
Weaverman's Avatar
Oddometer: 58
What bike is running 13+:1 reliably?
In research or development of an engine design, MBT is a crucial study. Maybe it can't be reached intially...that's why you continue development. Dick with the factors until you need less advance to achieve the torque (mod the chamber to increase burn rate, swirl, tumble, etc.). If you don't know what's possible, you'll never find a way to get there.
Old 03-01-2011, 01:04 PM   #54
anotherguy
anotherguy's Avatar
Oddometer: 4,309
I have found that an engine with a great pull from early in the rev range that sacrifices a couple ponies up top will out accelerate an engine that makes more peak. Which means it will likely have a higher top speed and better economy as well. It's all about the highest average power. That was a real eye opener.
Oh and 14.7:1 is great if you wanna heat the house cheaply.
Thomas Jefferson
Old 03-01-2011, 01:22 PM   #55
Weaverman
Damaged goods
Weaverman's Avatar
Oddometer: 58
Anotherguy - yes! It's about the area under the curve (in the horizontal axis range you use...RPM). A nice peak is good if you run right up there and then stay there for the duration...like a drag car with a high-stall converter, or a racing snowmobile with the variable drive dialed in correctly. If you're roadracing on a hilly course, you'll probably want a fatter torque curve since you'll be pulling long and hard. Consider a 2-stroke with light-switch powerband port timing...goes like a bitch in the narrow range where it makes power (which you often can't use). Ask King Kenny about it after he rode the TZ-based flat track bike at Indy way back when...never again he said! Actually, if I remember correctly, he said "they don't pay me enough to ride this".
Supershaft, I'm not saying you can't run 13.1:1 A/F. But my money says if you can, you've left power on the table because the spark advance curve is not optimum. First you develop the timing curve for MBT, then you fuel it. HP is a function of torque, so more is better anytime and anywhere. You make torque by optimizing spark advance. What kind of EGT readings are you getting? I bet they're way up there.
MBT is an acronym where "best" means "the most"...maximum. Your definition of "best power" seems to be best for your application. In my mind, you always want the most torque you can get with the fuel you use (octane). Period. If you need a different powerband, then you mess with valve timing.
Weaverman screwed with this post 03-01-2011 at 01:32 PM
Old 03-01-2011, 03:29 PM   #56
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 15,971
What do you knowledgeable fellows think about this?
Old 03-01-2011, 03:32 PM   #57
supershaft
because I can
Oddometer: 6,046
I completely agree with anotherguy his time. My main tuning slogan has always been, "High rpm hp? First you have to get there!"
Weaverman, MY bike is running 13.1 plus reliably. That is what it sniffed with pump 10% ethanol. I had it around 12.5 for about 15,000 miles but about 50,000 miles ago I leaned it out to a bit to above 13. I knew it made the most power there from the seat of my pant dyno but I had gone back one step richer just to be safe. Then I dynoed it and saw I had plenty of room to go back to what I thought felt the best. The Highly experienced dyno operateor thought the same thing. It's not an exception, it's the norm according to him and others I talk to including anotherguy. I like to think my seat of the pants dyno is fine tuned some since I have been test riding just dynoed bikes since I was a little kid. My dad wasn't really into getting some of our race bikes up on the pipe when they were between his legs!
IMO, developing the ignition curve beyond accepted norms takes some serious dyno time that I don't have. I learned that back in junior high helping my dad run his dyno and have had that notion reinforced workin with a couple of other dyno tuners since then. One being Chris from San Jose. I am running absolutely stock timing. I know all about the benifits of being able to achieve more power with less advanced ignition. I preach it all the time on this forum. Long rodding airheads is a perfect example of that. It's not just the combustion chamber! I also know all about adjusting the curve for best power. I advocate that all the time here on advr when dual plugging airheads and have done it myself numerous times for a real gains on and off the dyno. Single plug, the factory got it close enough for me. I fine tuned my advance to the factory specs. They very often are not even close. Mine wasn't.
supershaft screwed with this post 03-01-2011 at 03:50 PM
Old 03-01-2011, 05:12 PM   #58
Weaverman
Damaged goods
Weaverman's Avatar
Oddometer: 58
Fair enough. I don't now all about anything!
But since you do, tell us how rod length impacts spark timing?
Old 03-01-2011, 05:21 PM   #59
Weaverman
Damaged goods
Weaverman's Avatar
Oddometer: 58
No Googling now...explain it in your own words!
Old 03-01-2011, 11:23 PM   #60
supershaft
because I can
Oddometer: 6,046
I don't know all about this but I have actually been there and done it some. I know people that have TONS more experience and knowledge about it than I do. Chris at San Jose would be one among others. My dad would be another.
I hope you are not suggesting I am a googler? I go way back before the net! I have read a bunch of Smokey Yunick though. Now there is someone with some dyno time! He contracted R+D for GM out of his own shop down in Florida! I have seen a lot of his advise WORK.
I have already tried to explain that many times on this forum. Yunick can do it better than I can. In a nut shell, it changes TDC (and BTC) piston dwell. Longer rods increase TDC piston dwell. The piston hangs around TDC longer for the flame front so you can light it later. I have helped set up and dyno tune long rod beemers. I am not claiming that I have done it near as much as some but I have done it and I tried to learn while I was doing it!
I am just sharing what I have seen work. I hope it might help someone out there. It's just that you are telling me that 13+ shouldn't work and I know that it does and I am not the only one. Not even on this thread!
supershaft screwed with this post 03-01-2011 at 11:32 PM
Times are GMT -7.   It's 01:51 PM.
