03-02-2011, 04:57 PM
#76 |
Damaged goods
Oddometer: 58
Yes, it's the acceleration that increases.
03-02-2011, 05:28 PM
#77 |
Along for the ride
Oddometer: 912
So does ring flutter become a factor with higher piston acceleration or does the slow start from stopped tdc help here?
__________________________________________ "There's a fine line between a skinning and a shearing" |
03-02-2011, 06:38 PM
#78 |
because I can
Oddometer: 6,087
03-02-2011, 06:51 PM
#79 |
Along for the ride
Oddometer: 912
Lets try and keep to the theory and forget the "bonehead" remarks please.
03-02-2011, 09:04 PM
#80 | |
Lost In Place
Oddometer: 15,984
![]() Out esteemed colleague has suggested otherwise. ![]() edit: okay, just getting caght up in this thread and noticed WM's additional information.
Across Canada on a '83 R80G/S-PD Across Canada on a '71 R50/5 My Garage Of Doom Wear The Fox Hat Lornce screwed with this post 03-02-2011 at 09:12 PM |
03-02-2011, 09:23 PM
#81 | |
Lost In Place
Oddometer: 15,984
Venolia 1050 pistons mated to modded '77 R100S "squish band" heads at approx 12:1 (measured pressures, not cc'd). Torque, mid range power and fuel efficiency are all up by significant margins. Now if only I could find a way to control distorting cylinders that have been bored too thin to maintain dimensional stability... ![]() It never ends. |
03-02-2011, 09:27 PM
#82 |
because I can
Oddometer: 6,087
03-02-2011, 11:10 PM
#83 | |
Paint it black.
Oddometer: 12,888
I got it, been a good topic to read on. The initial poster doesn't seem aware that a Dynojet factors in 20% more which should read about 39 HP at the wheel, not the inflated 'factored' dyno sheet. An 85,000 mile twin isn't putting 48 HP to the ground...since we're talking numbers. |
03-03-2011, 04:09 AM
#84 |
soreass
Oddometer: 123
[QUOTE=Stagehand;15305970]Yeah me too, even if I dont understand a thing and just like the way the words sound
Chuckled when I read this; that's me too. |
03-03-2011, 06:41 AM
#85 | |
Oddometer: 25
either way..maybe not correct to compare to the factory crank numbers..but this was a baseline..from which I hope to optimize a few parameters...and then at some point..go back on the same dynojet dyno...to see how it did...
Tom 91 BMW R100 GS/PD 04 Ducati 998 Matrix edition 93 Kawasaki ZX-11D |
03-03-2011, 08:34 AM
#86 | |
because I can
Oddometer: 6,087
03-03-2011, 09:37 AM
#87 | |
Oddometer: 4,314
And a calibrated DynoJet will give good HP numbers. I've run SuperFlow SF-901,FactoryPro EC997 and Dynojet from 100 to 250i. Favorite is the EC997. The SuperFlow is an awesome tool but difficult to use for motorcycles. Harleys are the easiest to mount to the 901 but not close to easy. When all is said and done the numbers only matter at the bar. Results speak far louder than numbers. The proper use of the tool is what you seek. As I alluded to earlier it's the area under the curve that gets the job done and the only way to see that is a dyno printout no matter where it comes from.
When injustice becomes law,resistance becomes duty. Thomas Jefferson |
03-03-2011, 09:40 AM
#88 | |
Paint it black.
Oddometer: 12,888
Didn't say that, they're measuring power at the wheel and their software gives you back 20% for parasitic losses. If you're on a Dynojet you need to take away 20% from what they tell you. Look around the 'net, it's pretty common knowledge. |
03-03-2011, 09:56 AM
#89 | |
Oddometer: 25
ok.not 20% over factory..but still..I've not seen anything that says a dynojet gives back 20%.... I'll go look around the internetz to see..but what you are saying is that dynojet numbers should in theory be close to or greater than the factory crank numbers? (assuming drivetrain loss is 20%)..(in a non-locking automatic..for sure....manual..maybe 15% losses).
03-03-2011, 10:03 AM
#90 | |
Paint it black.
Oddometer: 12,888
Yes, they get you back to a crank reading...a little misleading, but the whole tune on the same dyno still works and is a great tool. Do you really want to go looking for power with 85,000 on the clock? |
