Old 03-03-2011, 11:06 AM   #91
midlman OP
midlman's Avatar
Oddometer: 25
Originally Posted by larryboy View Post
Yes, they get you back to a crank reading...a little misleading, but the whole tune on the same dyno still works and is a great tool. Do you really want to go looking for power with 85,000 on the clock?
Funny you ask...the bike runs great, but I always tinker...so why not fix it till it's broken LOL I've even tossed around the idea of dual plugging/40mm bings/exhaust etc..
Tom
91 BMW R100 GS/PD
04 Ducati 998 Matrix edition
93 Kawasaki ZX-11D
midlman is offline   Reply With Quote
Old 03-03-2011, 01:55 PM   #92
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,122
Sure.
Why not?
Old 03-03-2011, 02:18 PM   #93
supershaft
because I can
Oddometer: 9,116
What model Dynojet is suppose to get you back to a crank reading? Is it an option an the printout? I think their inertia dynos read high but not 20% high. Does their software have an at the crank button? No one has ever showed it to me. Is it a new feature? Where did you get the 20% figure. What about Dynojet brake dynos? They don't just make inertia dynos. Some don't even consider an inertia dyno as being a real dyno. Torque isn't really measured on an inertia dyno. It is estimated by a computer.
Old 03-03-2011, 02:51 PM   #94
anotherguy
anotherguy's Avatar
Oddometer: 6,387
Any of you guys experienced operators? 'Cause some of that stuff is just plain wrong.
You can do a negative run on a DynoJet and figure parasitic drag but it's not part of a roll on run. You must go into the software and select it. On some bikes it's a bad idea to do. Like a 2 stroke.
The DynoJet uses drum weight/diameter,gear ratio,RPM and time to calculate HP.
you don't see luggage racks on a hearse..........act accordingly
Old 03-03-2011, 04:28 PM   #95
supershaft
because I can
Oddometer: 9,116
I'm not! I have helped with many a dyno run but I have never actually run the dyno.
Oops! Does Dynojet ONLY make inertia dynos? I thought their brake dynos were eddy current dynos? I don't understand how an inertia dyno brake works? I guess it is a combo electric/enertia that still depends on a computer model reading?
Back in the early seventies, our shop's dyno had a torque meter and a tach. No computer. No printer. Of course, it wasn't an inertia dyno. They hadn't been invented yet? If I understand it right, inertia dynos HAVE to have a computer?
supershaft screwed with this post 03-03-2011 at 04:38 PM
Old 03-03-2011, 05:01 PM   #96
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,122
As far as I understand it, the Dynojet dynos work with a speed sensor tracking speed/acceleration of the drum, which is a known weight.
All power and torque figures are derived by the dyno's computer from that collected acceleration data and monitored engine RPM.
Anyone know different?
Old 03-03-2011, 06:27 PM   #97
anotherguy
anotherguy's Avatar
Oddometer: 6,387
You have the gist of it. The load control DynoJets are hybrids. It's an eddy current brake used to load the engine for writing maps but isn't capable of steady state torque readings. It has a load cell that needs to be calibrated via an arm and weights. So it's physically capable of it. Not sure why they didn't go all the way.
It really doesn't matter (within reason) how accurate the numbers are as long as they're consistent. I don't consider it done until I get 3 consecutive runs with the same result. It's use is as a comparator so you can see the results of changes. An increase/decrease will give evidence of the path your on being right..................or not.
The DynoJet uses RPM,gearing and the acceleration rate from A to B to calculate the numbers. The RPM comes from an inductive sensor attached to a plug wire. Gearing is calculated by RPM vs. drum speed rate that is read via Hall Effect sensors. On set up it asks how often spark occurs,i.e. 180/360/720 degrees to help determine gearing. The software is calibrated for each machine via the drum serial number that allows them to determine the exact weight and diameter via records from manufacturing. The DynoJet dyno is better than it's detractor would have you believe. It's a solid tool that in the right hands allows the best to be extracted from and engine. The operator is the standard that makes it right. A good operator takes care of his machine and knows how to use it.
That being said notice the Factory Pro EC997 is my favorite. It's faster,lighter and easier to get consistent results from. It uses a far more reliable 5 gas analyzer vs. the DynoJet O2 sensor which has serious shortcomings. However those standards come with a price. A very steep price.
Old 03-03-2011, 07:29 PM   #98
supershaft
because I can
Oddometer: 9,116
I am guessing the Pro Flow is an eddy current? Does anybody still use hydraulic? I would think hydraulic dynos would be the most consistent?
It baffles me why Dynojet didn't go all the way with their brake dyno's. I would think steady state would occasionally be handy.
Old 03-03-2011, 08:50 PM   #99
supershaft
because I can
Oddometer: 9,116
I have had people tell me that they thought their dyno itself changed more than a little when it warmed up and then got hot. It seems to me that hydraulic would do that the least.
Old 03-04-2011, 08:14 AM   #100
anotherguy
anotherguy's Avatar
Oddometer: 6,387
It's the engine that makes the difference. As the insides heat sink it reaches an equilibrium. That's accounted for in the engineering/design phase of development. Ever held a Harley TC88 cylinder head? Massive. Designed to hold the heat for emissions reasons. Takes 3-4 WFO runs after a 5 minute warm up to reach true operating temperature.
Old 03-06-2011, 05:20 PM   #101
supershaft
because I can
Oddometer: 9,116
Everyone that told me that about their dyno was full well aware of the effects of the engine getting hotter. They were talking about the dyno itself.
Times are GMT -7.   It's 07:05 PM.
