Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 03-02-2011, 05:04 PM   #1
pampaX OP
pampaX's Avatar
Oddometer: 354
Laugh G650X Challenge RS
Maintenance and mods of my G650X Challenge. it currently is at 40000K.
Maintenance done:
* Steering head bearings -> TODO-Document
* Valve clearances -> TODO-Document
* Front Rotor replacement
* Brake pads
* Air box cleanup http://www.advrider.com/forums/showp...3&postcount=27
* Swingarm dissasembly http://www.advrider.com/forums/showp...2&postcount=30
Hard parts installed:
* Kutch hard parts -> http://www.advrider.com/forums/showp...7&postcount=28
* Rear disc rotor touratech protector -> TODO-Document
* Case saver -> http://www.advrider.com/forums/showp...7&postcount=57
* Steel Wheel spacers from Stephen Schelheimer
* Case saver from Stephen Schelheimer
Other:
* 14x47 gearing, front lasts around 5000K by that time it has a very noticeable wear
* Gear lever: http://www.advrider.com/forums/showp...8&postcount=48
* Scott oiler
* Pivot Pegz
* Benelli clutch and brake lever: http://www.bs-motoparts.com/Brake-_a...i3754_7183.htm
Performance enhancement:
* Air filter
* Airbox inner cover and sort out disparity of screw heads
* Throtle spring
* Slip on
Other enhancements:
* Cheap extra fuel http://www.advrider.com/forums/showp...5&postcount=29
* Lets start with fairing, this is what I'm working on
* Front forks changed for Marzocchi (Real ones)
* Rally-like fairing with custom tower bracket
That is with my bracket version 0.9 - all working.
Features I'm interested was:
* few bolts to remove fairing
* no cables
* no nuts (use self lock nuts)
pampaX screwed with this post 03-15-2012 at 12:28 AM
pampaX is offline   Reply With Quote
Old 03-02-2011, 08:15 PM   #2
topo
topo's Avatar
Oddometer: 168
Looks good, how have you made the fairing? foam mold or bits of roadbike fairing stuck together? Looks a bit high, maybe it's just the lack of the mudguard.
How hard did you have to whack the bash plate to make it that shape
KIWISAFARITEAM
GO BRO GO.......
topo is offline   Reply With Quote
Old 03-02-2011, 08:19 PM   #3
Eddieb
Eddieb's Avatar
Oddometer: 760
I thought I saw you going through town yesterday with something large on the front of the bike.
02 & 05 DR650's
67 Ducati 250 Mark 3 Narrow Case
94 Beta Techno 250
Facebook Adventure Riding NZ Group
Facebook Adventure Riding NZ News
Eddieb is offline   Reply With Quote
Old 03-02-2011, 09:17 PM   #4
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 1,431
Saw it yesterday parked in the commute spot. Looking good.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 03-03-2011, 12:52 AM   #5
pampaX OP
pampaX's Avatar
Oddometer: 354
I wish I had ability to do something like that. The fairing was sourced, my job was to strip the bike build the bracket (not that easy for me at least), install the new lightning.
The fairing is made by a guy in Lithuania, out of fiberglass, modeled by an artists.
Well the lack of mudguard certainly accounts for most of that. I like how it looks once all is in place.
Old 03-03-2011, 12:55 AM   #6
pampaX OP
pampaX's Avatar
Oddometer: 354
A picture of my first bracket, this is version 0.1 which is meant to verify clearances and stability of whole thing, as well as accommodate lights.
pampaX screwed with this post 03-03-2011 at 01:08 AM
Old 03-03-2011, 01:02 AM   #7
Eddieb
Eddieb's Avatar
Oddometer: 760
You need to shrink those pics a bit, I can't actually see your work on one screen so it's a bit hard to take in.
02 & 05 DR650's
94 Beta Techno 250
Old 03-03-2011, 01:11 AM   #8
pampaX OP
pampaX's Avatar
Oddometer: 354
done, but you need to upgrade your screen
Old 03-03-2011, 01:54 AM   #9
Eddieb
Eddieb's Avatar
Oddometer: 760
got a front on shot with the fairing mounted?
02 & 05 DR650's
94 Beta Techno 250
Old 03-03-2011, 08:33 AM   #10
slowbike smallpenis
Tester of Tooheys Old
slowbike smallpenis's Avatar
Oddometer: 18,678
Every day you should try and be as happy as a Dog with two dicks
slowbike smallpenis is offline   Reply With Quote
Old 03-03-2011, 02:26 PM   #11
pampaX OP
pampaX's Avatar
Oddometer: 354
I actually do ( even one small picture for your little screen)
Old 03-03-2011, 02:45 PM   #12
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 2,703
The BMW in it's natural environment
Looks good though, I like the colours. Did you have to weld a bracket on the frame to mount the fairing etc?
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 03-03-2011, 04:32 PM   #13
pampaX OP
pampaX's Avatar
Oddometer: 354
i believ e have some pics on Ktm environment ....
Bracket goes like this
welded like this
where you can also see the BM on Ktoom natural environment
Cheers
Clint
Old 03-03-2011, 05:34 PM   #14
clintnz
clintnz's Avatar
Oddometer: 2,703
...where you can also see the BM on Ktoom natural environment
Ow! That was harsh!
Especially since my bike has spent most of the last 3 months in the shed
It was interesting to see the inside of Colebatch's motor which has done about the same km's as mine, quite a bit less wear than the 640. All that extra metal they put in obviously does something good. I'm not complaining too much though, 95K km without a breakdown on what was, when I bought it, the most powerful bike in it's class is ok by me.
Cheers
Clint
Old 03-03-2011, 05:49 PM   #15
pampaX OP
pampaX's Avatar
Oddometer: 354
Yeah not too bad at all. I have a Ktm on the garage as well
I do complain about mine from time to time ... although in the end its a good bike ... with cheap suspension the main issue ... the rest is fairly simple and not a lot of work
So you haven't got your bike running yet?
Ow! That was harsh!
Cheers
Clint
Times are GMT -7.   It's 05:02 PM.
