Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 03-03-2011, 07:14 PM   #16
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,425
My 640 is running, smooth & strong , I sparked it back up last week, done about 300km on the rebuild now & it is going very nicely. Hopefully all good for another 6yrs of fun.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 03-03-2011, 11:20 PM   #17
Oaters
Oaters's Avatar
Oddometer: 641
Thumb Cool Rallye Cockpit
Pablo - saw your bike in the flesh today - looks cool - momentarily thought such a cockpit would look good on my 1150 - then realised that bike and rider would remain unchanged
Oaters is online now   Reply With Quote
Old 03-04-2011, 01:45 AM   #18
pampaX OP
pampaX's Avatar
Oddometer: 416
Mate, its not out of need I'd done it ... purely cause I like it ... so you can do it on yours without need to adjust rider not that you need it. I've seen you going to the same places I had been and heard of you going to many more
One day may be able to get a real rally bike in the meantime I customise what I have. Also have fun in the process learning to do some things and to work on the bike.
The copkit is temporary. I need to get a better version of the bracket, with better holding for the fairing, speedo, also plastic weld lateral holding points, etc ...
pampaX is offline   Reply With Quote
Old 03-07-2011, 01:53 AM   #19
pampaX OP
pampaX's Avatar
Oddometer: 416
Side support for the fairing
Next on my list is to plastic weld the side support for the fairing, to enhance stability ...
this is first plastic welding I do on something real so won't be great but hopefully will do the job
Old 03-07-2011, 04:19 PM   #20
pampaX OP
pampaX's Avatar
Oddometer: 416
Today received the front fender and did quick installation ... will need to build a bracket to adapt it to the clamp ...
pampaX screwed with this post 03-08-2011 at 02:08 AM
Old 03-08-2011, 02:02 PM   #21
.chris
690 Advenduro
.chris's Avatar
Oddometer: 93
Looking good, I love the colour scheme. Makes me wish my bike was white so I could do something unique.
I am interested in the future, because it's where I am going to live
.chris is offline   Reply With Quote
Old 03-08-2011, 06:29 PM   #22
clintnz
clintnz's Avatar
Oddometer: 3,425
Does look good, you need some blue/red/white white fork guards to finish off
Lots of frontal white is also great for visibility.
Cheers
Clint
Old 03-08-2011, 07:18 PM   #23
pampaX OP
pampaX's Avatar
Oddometer: 416
Cheers
Clint
havent really considered visibility but good point ... fork guards mhhh not bad idea ... would need next budget tho
Old 03-08-2011, 07:35 PM   #24
clintnz
clintnz's Avatar
Oddometer: 3,425
They sell duct tape in red, white & blue
Clint
Old 03-12-2011, 02:39 AM   #25
pampaX OP
pampaX's Avatar
Oddometer: 416
Built the fender bracket as the BM has only two bolts that match the standard fenders ... pictures soon
All together
pampaX screwed with this post 03-15-2011 at 01:41 AM
Old 03-13-2011, 03:05 PM   #26
pampaX OP
pampaX's Avatar
Oddometer: 416
Plastic welded side mounts, pictures soon ...
This is what I added, bit more welding on top ...
How it looks all together ...
pampaX screwed with this post 03-16-2011 at 02:36 AM
Old 03-17-2011, 05:17 PM   #27
pampaX OP
pampaX's Avatar
Oddometer: 416
Airbox cleanup
This is the airbox with the two top covers removed. I actually don't have the inner cover
Top removed, after 10 bolts out
The inside is relatively clean, not so the butterfly
My G650X Challenge, Bike build thread on
http://www.advrider.com/forums/showt...7#post15320987
pampaX screwed with this post 09-01-2011 at 03:21 AM
Old 03-17-2011, 05:19 PM   #28
pampaX OP
pampaX's Avatar
Oddometer: 416
Kutch Hardparts
Kutch designed hard parts to cover pegs, rear brake and frame. I had the design file gently sent by Kutch and got a few made.
Left View:
Right view:
pampaX screwed with this post 09-01-2011 at 03:12 AM
Old 03-17-2011, 05:22 PM   #29
pampaX OP
pampaX's Avatar
Oddometer: 416
Cheap fuel tank 1galon almost 4 liters = over 100K
On one of my trips I was alone so wanted to have some more fuel range. Not that is often needed over here but just for peace of mind. I normally get over 200K of 9.3 ltrs so figured with 4 more would get around 300 ...
Back:
side:
pampaX screwed with this post 09-01-2011 at 03:19 AM
Old 03-17-2011, 05:27 PM   #30
pampaX OP
pampaX's Avatar
Oddometer: 416
Rear swing arm dissasembly
In my previous bike had trouble with swingarm bearings, thus I decided to check this one just in case. They where fine.
Remove shock, bolt
Remove left side cover, those ones can be problematic cause they're little
And out
Bushes, bolts and tools
Right bearing
Bushes, and the rear swingarm "axle"
pampaX screwed with this post 09-01-2011 at 03:27 AM
Times are GMT -7.   It's 06:00 PM.
