Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 03-19-2011, 01:45 AM   #31
kiwipeet
Uber Cyber Loafer
kiwipeet's Avatar
Oddometer: 3,014
Just saw this thread. nice project man
kiwipeet is offline   Reply With Quote
Old 03-19-2011, 01:50 PM   #32
pampaX OP
pampaX's Avatar
Oddometer: 422
Thanks still working to finish it, going bit slow at the moment ...
My G650X Challenge, Bike build thread on
http://www.advrider.com/forums/showt...7#post15320987
pampaX is offline   Reply With Quote
Old 03-23-2011, 03:09 AM   #33
K Slider
K Slider's Avatar
Oddometer: 85
Coming along nicly Pampa how did you get over the bracket problem.
Lifes journey is not to end well presented at the grave but rather to slide in sideways totaly worn out yelling shit that was a hell of a ride!
K Slider is offline   Reply With Quote
Old 03-23-2011, 12:36 PM   #34
Timpo
NORTH WALES TRF.
Timpo's Avatar
Oddometer: 2,108
Looks good so far......
Have you a plan to address the cooling issue?
I seem to have the fan running all the time once i have left tarred roads..... how are you finding it?
Timpo.
The Rave Generator......
Timpo is offline   Reply With Quote
Old 03-24-2011, 02:16 AM   #35
pampaX OP
pampaX's Avatar
Oddometer: 422
I have a version of the bracket to kinda cover all the bits I wanted. I will try to make it better, may get you over some time for some advice ... doing little bits of work due to lack of time though, so slow progress
Old 03-24-2011, 02:19 AM   #36
pampaX OP
pampaX's Avatar
Oddometer: 422
Timpo.
Hi Mate, seen your bike and looks impressive. Haven't done anything yet, had the idea of cutting the fender using the pattern of the original fender, but only if I could see it was a problem. I haven't had the chance to leave tarred roads yet other than very mild gravel so couldn't tell if it is real problem.
My current riding consists on 99% commuting and doing that had never had the fan starting ...
Old 03-24-2011, 02:39 AM   #37
pampaX OP
pampaX's Avatar
Oddometer: 422
More pics of bracket and mounts
Some more pics
1. Bracket without the fairing - draft 1
Upgrade for easy maintenance to use self lock nuts (or whatever right name is for this)
Again side mounts this time with self lock
This is new addition to the bracket, instead of holding it from the lights, I added piece of metal to hold it. It needs more work to be perfectly centered
here we can see its not 100% there yet
Looking from above
And again front view
pampaX screwed with this post 03-24-2011 at 02:45 AM
Old 04-03-2011, 06:53 PM   #38
pampaX OP
pampaX's Avatar
Oddometer: 422
Position light bullets
Trying to get bit more visibility provided this wasn't expensive I had this previously installed.
More details on the light: http://www.webbikeworld.com/lights/bikevis-led-lights/
All together again
The holder
Closer look
The other bracket, to support fairing
Old 04-23-2011, 02:37 AM   #39
pampaX OP
pampaX's Avatar
Oddometer: 422
What about the forks ...
I'm working on getting this instead of OEM ...
they're on its way ...
Old 04-26-2011, 02:17 AM   #40
pampaX OP
pampaX's Avatar
Oddometer: 422
Forks Marzocchi shiver 45 - real thing
So this is what arrived today
and in there
mmh, more detail
black coated Stanchion
Adjustable compression
Diameter at the top
Size bottom clamp
stanchion opened full extension
seal
both stanchions
rebound at the top
size of axle
size axle on the other side
stanchion size
left side boot, caliper bracket
pampaX screwed with this post 04-26-2011 at 02:28 AM
Old 04-26-2011, 12:45 PM   #41
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,143
Nice. Still tempted to put the 46mm usd's on my TT350.
I know it'll look cool but how much better can a set of cartridge forks with compression and rebound adjustment and a bigger brake disc work than some state of the art damper rod 41's from '85.
NordieBoy is offline   Reply With Quote
Old 04-26-2011, 03:25 PM   #42
pampaX OP
pampaX's Avatar
Oddometer: 422
well there is only one way to find out
Old 04-28-2011, 02:09 AM   #43
pampaX OP
pampaX's Avatar
Oddometer: 422
Found this nice PDF on how to disassemble WP forks but I guess it applies to all USD forks.
Reference:
http://slorider.com/KTM/manuals/WP4860MXMA2003.pdf
Old 05-09-2011, 02:22 PM   #44
Kiwi Tinkerer
Ross
Kiwi Tinkerer's Avatar
Oddometer: 389
Beatiful
I saw your bike in town recently. the new faring looks great. I used to walk past your bike every day and when replacing my R1200GS I had a good look at your bike. I spoke to you about the bike and how you got on with adventure touring. You helped me with my decision to get the Xch.
You were absolutely right. It was a sound decision. I love the bike.
Kiwi Tinkerer is offline   Reply With Quote
Old 05-11-2011, 07:46 PM   #45
pampaX OP
pampaX's Avatar
Oddometer: 422
Hi thanks, yeah I remember talking to you ... haven't seen your bike around though
I'm trying to get some more stuff done, hope to get the forks done on incoming weeks ... and also finish the painting work, and also finish the mounting to allow the original light on ...
Cheers,
PampaX
Times are GMT -7.   It's 04:11 AM.
