Go Back   ADVrider > Riding > Regional forums > New Zealand
Old 05-11-2011, 09:30 PM   #46
canadius_maximus
Quaere verum - Seek truth
canadius_maximus's Avatar
Oddometer: 539
Excellent project!
Hola Pablo!
Just wanted to drop by and say what a wonderful job you're doing here. Some real inspiration for my own "DRZ400RS" project I'm thinking about.
Best regards,
Daniel
By grace alone. Through faith alone. In Christ alone. From Scripture alone. Glory to God alone.
KTM 690 R Rally Raid Evo 1 (and 2) Kit Build for Dummies
canadius_maximus is offline   Reply With Quote
Old 05-25-2011, 03:32 AM   #47
pampaX OP
pampaX's Avatar
Oddometer: 416
New for me forks
Haven't been on the bike yet
ready to go to the suspension specialist
and this was on the bike couple of days later
forks upper part
another view
rebound at the top
lst one
My G650X Challenge, Bike build thread on
http://www.advrider.com/forums/showt...7#post15320987
pampaX is offline   Reply With Quote
Old 06-26-2011, 04:17 AM   #48
pampaX OP
pampaX's Avatar
Oddometer: 416
New Gear lever
The original is as too stiff, I had few holes drilled but consensus is that a new one is better from a Yamaha WR, so checked and they're not too expensive so decided to try this
  • Lever and tools for the Job
old one installed here:
side by side, original is longer ... errr maybe new one is too short for my #12?
and all together again
While doing this also noticed multiple heats on the protection from Kutch and TT rear rotor
this one definitely took a few hits ...
i do little bit of practice ride on river bed which is quite rocky, also to try the new forks surely this bits are doing their work
Old 07-06-2011, 02:30 AM   #49
kiwipeet
Uber Cyber Loafer
kiwipeet's Avatar
Oddometer: 3,010
Question
Originally Posted by pampaX View Post
What are the main headlights? Brand? Bulb type? measurements?
How well do they work? are they a wide beam or a pencil beam? Do you like them?
kiwipeet is online now   Reply With Quote
Old 07-11-2011, 02:57 AM   #50
pampaX OP
pampaX's Avatar
Oddometer: 416
Hi, they are dominator twin dual headlight bought on 3buy http://cgi.ebay.com/ebaymotors/DOMIN...item2c5de0bd1a like those ones. It uses H4 60/55w bulbs (included). According to seller they're 8.5 inches wide and use 8mm bolts (confirmed by me).
They work ok, I had one of those enhcanced h4 on the standard one, which was nice, but I guess if I put two of those here they would also work better. I do like them though one of them is not properly sealed and accumulates some humidity.
Now in all fairness I have only done commute rides and it only takes 30' to get home so lights are not a big issue, I'm overall happy with them at this point. The quality is ok, nothing too fancy though.
Hope that sheds some light to your question
Old 07-16-2011, 02:59 AM   #51
pampaX OP
pampaX's Avatar
Oddometer: 416
Fuel efficiency
this thing is not too bad, last week I did
with only 9.14 ltrs
which is by the way kind of the average fuel consumption ... non offroad riding
Old 07-16-2011, 04:08 AM   #52
pampaX OP
pampaX's Avatar
Oddometer: 416
replaced my front sprocket today and
at 6000K of mild use and found this uneven wear
the other side looks fine
so anybody has any idea what can cause this?
Old 07-16-2011, 04:35 AM   #53
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,139
Slightly tweaked swingarm?
My TT350 does it to the inside of the sprocket. My brothers one doesn't.
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 07-16-2011, 02:52 PM   #54
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,182
Misalignment. Also try running uneven spocket combinations, such as 15/42, so that the chain doesn't land on the spocket in the same places all the time.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 07-16-2011, 07:35 PM   #55
pampaX OP
pampaX's Avatar
Oddometer: 416
I guess is possible, but last time It was chequed 6000K ago bearings were correct the rest seems in good shape and the bike is not that old ...
Old 07-16-2011, 07:41 PM   #56
pampaX OP
pampaX's Avatar
Oddometer: 416
How can be out of alignment, the sprocket fits in only one way, wheel spacers are knew and best quality, bearings are new or almost ... the chain and both sprockets were new 6000K ago too ...
the sprocket combination is 14-47 which is very commonly used on this bike ...
the other thing is the shaft itself being bent ( ) .....
Old 07-16-2011, 08:24 PM   #57
pampaX OP
pampaX's Avatar
Oddometer: 416
A closup pic of the chainsaver
this is made by Stephan a German engineer, very good stuff
Old 07-16-2011, 11:46 PM   #58
Eddieb
Eddieb's Avatar
Oddometer: 960
Looking at the wear you can see on the even toothed sprocket how the teeth are hitting the chain links the same way each time, one tooth is worn down in a point and the next in a gentle arc.
05 farkled DR650 - 86 BMW R80 with Velorex sidecar - 67 Ducati 250 Mark 3 Narrow Case
www.AdventureRidingNZ.co.nz Free GPS tracks for New Zealand, over 60 Owners and workshop manual downloads, ADV bike specs chart & more
Eddieb is online now   Reply With Quote
Old 07-18-2011, 01:26 AM   #59
pampaX OP
pampaX's Avatar
Oddometer: 416
and what do you conclude out of that?
Old 07-18-2011, 02:23 AM   #60
Eddieb
Eddieb's Avatar
Oddometer: 960
I'm not smart enough to know if that means anything, I just found it interesting. Nordie should turn up shortly with some insightful knowledge.
Times are GMT -7.   It's 01:56 PM.
