09-14-2011, 03:47 AM
#76 |
Oddometer: 760
I've been thinking of doing the same thing.
02 & 05 DR650's 67 Ducati 250 Mark 3 Narrow Case 94 Beta Techno 250 Facebook Adventure Riding NZ Group Facebook Adventure Riding NZ News |
09-15-2011, 01:16 AM
#77 |
Oddometer: 354
we can always share u change the tyres I call for the pizza
--- My G650X Challenge, Bike build thread on http://www.advrider.com/forums/showt...7#post15320987 |
09-19-2011, 03:04 AM
#78 |
Little MissAdventure
Oddometer: 418
And buy the beer?
I'll help change tyres if there is free beer
The road to hell is paved... |
09-19-2011, 03:17 AM
#79 |
Oddometer: 354
sure why not ...
09-27-2011, 04:02 PM
#80 | |
Ride like a girl
Oddometer: 267
Great thread... and fantastic looking bike - thanks for sharing ![]() How did you go with the valve clearances... any pics or details on the reassembling? Cheers, GSDane.
´CAUSE IT MAKES ME SMILE |
09-29-2011, 02:36 AM
#81 |
Oddometer: 354
Hi mate, thanks.
I found left exhaust and intake were out of specs by very small margin. It was only difficult due to the range is starts from very close to zero thus makes use of my smallest feeler gauges which was kinda hard to put through and also the space on the bike doesn't help. All in all wasn't very difficult though had to removed what seemed a million bolts to get there, using several different sizes ... other than that wasn't too bad. Finally got it adjusted on a proper shop as I was running out of time, basically cause I didn't have the shims to replace it I followed instructions http://faq.f650.com/GSFAQs/Valve_Shim_Change_FAQ_GS.htm obviously disassembly is different but checking is very similar. Picture wise, didn't manage to get something useful and detailed enough to my liking, but go some 1. Airbox removed, including 2 zipties, bleeding hose, butterfly, etc ![]() 2. another look to the intake duct that is bit dirty ![]() ![]() 3. Front bolts are difficult to access due to angle ![]() Finally the inner spark plug was hard to remove, due to again space and angle Hope this helps, what do you ride?
09-29-2011, 02:45 AM
#82 |
Oddometer: 354
On another topic, last week received this
it took almost 2 months to get but in the end justice was served
![]() have even a cap
09-29-2011, 02:47 AM
#83 |
Oddometer: 354
and after another week or so installed them
and ended up with moving pegs
09-29-2011, 02:50 AM
#84 |
Oddometer: 354
then back to tyres
the pegz gave me some impetus to do the tyres and they look like this on the bike
![]() ![]() all together
09-29-2011, 02:53 AM
#85 |
Oddometer: 354
and in case u wondered about the old ones
the old ones can be argued that had finished a cycle
Rear AC10 with honourable 9000K, and front TKC80 with 20 odd thou ![]() closer look to ac10 ![]() in the end was awesome for power slides on tar
09-29-2011, 09:13 PM
#86 | |
Ride like a girl
Oddometer: 267
![]() Cheers, GSDane.
10-02-2011, 04:15 PM
#87 |
Oddometer: 354
a real ride
So thanks to Eddie have a little video of real run on the bike's new setup.
Everything worked alright except that a full lock the handlebards (the handguards actually) hit the fairing
02-07-2012, 02:05 PM
#88 |
Oddometer: 354
Bar risers
The bars tend to move out of alignment at the smallest drop (which happens very often
) anywayThis causes the rubber bushes and bolts to deteriorate. So cause the current bolts have already been straightened I though try new bolts but for that I needed to change risers the old risers were cheap Touratech ![]() so this are the new risers the new ones are also taller, though bring bars backwards. This won't cure the moving but maybe will help ... in the meantime I'm exploring optiosn for the rubber mounts
02-07-2012, 02:06 PM
#89 |
Oddometer: 354
Bar risers
view from further back
02-12-2012, 04:00 PM
#90 |
Oddometer: 354
Levers
I'd like a shorter pair of brake and clutch levers and found these that fit the bike
![]() so now i'm waiting for parcel
