02-27-2012, 05:11 PM
#91 |
Oddometer: 354
and this arrived some time afterwards ... good service for BS motorcycles on germany
you can almost see the content here
--- My G650X Challenge, Bike build thread on http://www.advrider.com/forums/showt...7#post15320987 pampaX screwed with this post 02-27-2012 at 05:55 PM |
02-27-2012, 05:13 PM
#92 |
Oddometer: 354
voila
the content looked very good
![]() they're adjustable and foldable and extensible
--- My G650X Challenge, Bike build thread on http://www.advrider.com/forums/showt...7#post15320987 |
02-27-2012, 05:14 PM
#93 |
Oddometer: 354
brake lever installed
03-13-2012, 01:48 AM
#94 |
Oddometer: 354
and after over a year - fully painted
and put BM badge and my stickers
03-27-2012, 01:03 AM
#95 |
Oddometer: 354
Vario benelli Clutch lever - not perfect fit but close enough
So the problem with the clutch lever is that the sleeve it comes with is too small for the bolt on the bike
![]() without the sleeve is too big. Also note the original sleeve is not good enough cause the new lever is thicker Here pic of both sleeves and the bolt ![]() the bolt doesn't go through the new sleeve ![]() solution is to build a thin wall sleeve with same diameter and same height of the lever haven't got a pic at hand 4 mine tho
03-27-2012, 12:43 PM
#96 |
Oddometer: 98
Thanks for the info!!!!
04-26-2012, 08:14 PM
#97 |
Oddometer: 354
Solid Battery Li-iron
A week or so ago my battery left me stranded ... again .. and decided to change the battery for one of these
![]() according to my research it seems to be a good one. The research was pointed out by alpi here http://www.advrider.com/forums/showp...postcount=1568 well today it arrived so looking forward to try it out. It certainly looks very very small and light
12-22-2012, 04:49 PM
#98 |
Oddometer: 8
I like the looks of the front fender, Make, Model?
12-22-2012, 09:24 PM
#99 |
enamoured
Oddometer: 2,489
12-26-2012, 05:18 PM
#100 |
Oddometer: 354
Its actually a Ktm front fender, bought in Oz but I believe you can get them here. I'll check brand when I get back home
01-01-2013, 11:24 AM
#101 |
Oddometer: 354
Redoing the bracket, disassemble
After a long time after doing first draft bracket
I'm now attempting to do an improved version .Lets start with disassemble First the bracket out of the bike ![]() ![]() The weight of the whole unit ![]() Here having removed the lateral fairing holder, i.e. the part I will start with ![]() Some rust forming on one of the lights for some reason (besides the fact that water is hitting it the other one is not quite as bad) ![]() The rubber mounted light holder bolt ![]() Another take at the main bones of the tower, now without anything else ![]() So what I'm trying to do is 1. to build one main bracket bone like the ones above this time tidier, also lower. The reason to be lower is I'm going to build a separate part to hold dash, road book holder and GPS holder .... ![]() 2. reuse the other bits, like fairing holder and indicator even maybe the dash holder 3. allocate space for the fuse box 4. maybe some space for tools 5. devise a way to cover water coming from the front wheel
01-01-2013, 11:41 AM
#102 |
Oddometer: 354
Redoing the bracket, build step 1 main bone cut
So clean out of laser cutter
![]() ![]() ![]() put main bolts and verify it fits ![]() closer ![]() so far so good, next drill rest of the holes and verify it goes together otherwise redo
02-24-2013, 04:37 PM
#103 |
Ev.
Oddometer: 70
pampaX, loving your thread!!
![]() How about some more laser-cutting goodness? And in more manageable screen size? |
02-25-2013, 01:11 AM
#104 | |
Oddometer: 354
I have a few pics of all put together, version #3 that I need to filter and make available ... will get to do it soon ... the screen size its not bad some people believe it gets on the way however it doesn't happen. Only problem I have is on rough offroad it may come close to your chest . I want to build a low screen for that sort of application, but need to do more mods to the tower so it doesn't protrude that much if I had a lower screen or it can be moved ...On the next video you can see one of the problems with the tower as it is now although the wiring seems much better now
02-25-2013, 11:45 AM
#105 |
Aslan
kewl vid - top riding skills
excellent little vid Pablo - riding the 'Pram Track' vicariously with you - enjoyable - I'm reminded how much these tracks change with the vagaries of the elements - have to pinch myself to think that I once took an 1150GS through there - thanks for posting
