Go Back   ADVrider > Riding > Regional Forums > New Zealand
Old 02-25-2013, 04:34 PM   #106
pampaX OP
pampaX's Avatar
Oddometer: 431
Originally Posted by aslan View Post
excellent little vid Pablo - riding the 'Pram Track' vicariously with you - enjoyable - I'm reminded how much these tracks change with the vagaries of the elements - have to pinch myself to think that I once took an 1150GS through there - thanks for posting
Hi long time since we rode together aye, the track wasn't too bad i has been graded recently so its quite good, although a bit loose for road tyres.
I heard you 1150 has gain 50 extra cc
My G650X Challenge, Bike build thread on
http://www.advrider.com/forums/showt...7#post15320987
pampaX is offline   Reply With Quote
Old 02-27-2013, 11:21 PM   #107
pampaX OP
pampaX's Avatar
Oddometer: 431
Main Bracket - Draft 2 #1
After a while of finishing this finally got around to post the pics.
After some trial an error this is what I ended up with
Installed looks like
Now for the power box position on the bracket
view from above
front
all the parts at this stage, the looser cutter was getting tired
this two pieces are the mountings for the dashboard, route holder, or map, etc (it turns out they don't work quite well but that's what I have now) ... they're have the rubber mount for vibration dampening
pampaX screwed with this post 02-28-2013 at 11:43 PM
Old 02-27-2013, 11:34 PM   #108
pampaX OP
pampaX's Avatar
Oddometer: 431
Main Bracket - Draft 2 #2
ok accidentally hit submit oh well (amateur)
another close up
now to the assembly line, this is the main part the backbone if you like
next step is putting the side holders
the rest
all together ready for another test
fitting test, anyway
and it does fit
Then installed with all the lights, spacers, zip-ties for cables, loc-nut nuts etc
So, next is a modification to indicator holders and cable tidy up. Note its done however haven't got pics yet
I'm still not happy with the dashboard holder, but will have to wait as I'm working on something else that also has 3 letters like BMW and has one letter in common but in different position, also has 2 wheels
Things I was considering where in no particular order
1. weight
2. strength
3. support vibration
4. access to all the bits
5. space to put cables tidy
6. use as little bolt and nuts types as possible
7. Make it a single unit that can be fully detached from the bike without having to put the biek apart
8. Clear for steering, mirrors, handlebars, cables etc
pampaX screwed with this post 02-28-2013 at 11:51 PM
Old 02-28-2013, 11:22 AM   #109
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,584
The 4 square centimeters of your bracket that is filling my entire screen looks pretty good. Any chance of resizing the pics so we can see the whole job at once?
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 02-28-2013, 02:16 PM   #110
Rosie!
Little MissAdventure
Rosie!'s Avatar
Oddometer: 464
Cheers
Clint
See, if you had two monitors like me the pics would still be too wide
The road to hell is paved...
Rosie! is offline   Reply With Quote
Old 02-28-2013, 06:23 PM   #111
pampaX OP
pampaX's Avatar
Oddometer: 431
Cheers
Clint
Ok ok I thought that was going to be the case ... tonight or tomorrow
Old 02-28-2013, 11:52 PM   #112
pampaX OP
pampaX's Avatar
Oddometer: 431
Ok pics are now smaller hope I don't get told of by the moderator again
Old 05-31-2013, 03:24 PM   #113
Bli55
Oddometer: 398
pampaX,
any news on your 2nd version?
Also, re-read your thread and the adjustable levers really got me thinking!!
Except the spacer for clutch lever, did it fit OK?
Reason I ask is that X-Ch uses a clutch cable with a thicker than average outer sheath and it won't fit some universal levers - is this one able to accept stock clutch cable?
How about the brake - fit OK?
Cheers!
Bli55 is offline   Reply With Quote
Old 05-31-2013, 11:36 PM   #114
pampaX OP
pampaX's Avatar
Oddometer: 431
Originally Posted by Bli55 View Post
pampaX,
Cheers!
Hi the second version got bent on incursion to a very nasty uphill section or rather on the way out of there when the battery went flat and had to push bike. I made another version #3, it seems slightly better although I'm yet to take some pics.
The levers went ok. the only thing was the clutch side were the pin didn't fit. However it had alloy bush which I replaced with a narrower one I made out of spare bit of alloy I had laying around . I may have some pics somewhere, but it wasn't a big problem.
Old 05-31-2013, 11:53 PM   #115
pampaX OP
pampaX's Avatar
Oddometer: 431
Rear disk rotor
It was surprisingly hard to get a rotor for the rear finally got the one from Stephen
Old 05-31-2013, 11:57 PM   #116
pampaX OP
pampaX's Avatar
Oddometer: 431
Wheel nuts
The problem with the axle nuts on the bike is that they're of an unusual size. Then I also have another bike thus I decided to buy the ktm ones someone recommended as they're only $12 for both. That way I only have one tool for wheels for both bikes on my bumbag
front
sorry for crappy pics
Old 06-01-2013, 12:41 AM   #117
pampaX OP
pampaX's Avatar
Oddometer: 431
pampaX,
Cheers!
This is the pin I was talking about
Old 06-04-2013, 08:09 AM   #118
BikerBobber
Trying to get lost
BikerBobber's Avatar
Oddometer: 846
front
Do these fit the stock axle?
Where did you buy the nuts from?
Bob
Edit - never mind. Needed to read the whole thread ;)
From my mobile
Bob
'05 Honda 1800 Goldwing
'01 Kawasaki Concours
'07 Bmw X challenge
My rider profile
BikerBobber is offline   Reply With Quote
Old 06-04-2013, 09:52 AM   #119
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Any idea what size socket fits the KTM nuts?
Also, what size axle and threading are they bolting on to? I have a F650GS w/ YZ250F front end and I'd love to reduce the 3 different sizes I need to make a change.
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 06-04-2013, 02:47 PM   #120
Bli55
Oddometer: 398
Gangplank,
ktm wheel nuts are M20 * 1.5 , 27mm socket, part number 50310099000
Times are GMT -7.   It's 09:22 PM.
