Old 03-03-2011, 02:05 AM   #1
7575KK OP
KK
7575KK's Avatar
Oddometer: 105
Any new info about KTM 990 fuel pump replacement
There are few threads and few posts abut 990 fuel pump but I do not see any of you posted infos about fuel pump replacement (like infos about Facet pump for 950).
So, have anybody replaced successfully OEM fuel pump for 990 with some other manufacturer pump so that pressure and flow needs are satisfied?
I have idea quite some time to replace OEM pump with something else and take it outside of tank simply because there will be small extra capacity of fuel in left tank and more important if left tank is damaged pump can still work with right tank (like on 950) ;)
... and let not forget that filter set for OEM pump cost more than 100$
So... any new infos
KK
7575KK is offline   Reply With Quote
Old 03-03-2011, 08:01 AM   #2
scapegoat
Pushin forward back
scapegoat's Avatar
Oddometer: 2,876
Does the 990 have the same issues the 950 had? Seems FI systems are pretty bullet proof as far as failures.
Reality is merely an illusion, albeit a very persistent one.
scapegoat is offline   Reply With Quote
Old 03-03-2011, 09:45 AM   #3
tomdubz
getting there
tomdubz's Avatar
Oddometer: 493
Last I heard, Head2Wind was working on it...
This is my signature: TD
tomdubz is offline   Reply With Quote
Old 03-03-2011, 10:08 AM   #4
catalina38
Contrarian
Oddometer: 1,600
The pumps don't seem to be the problem, the cost and availability of filters does. The KTM filter kit is more like a pump rebuild kit with a lot of extra stuff.
The pump is probably used on other brands of motorcycles, so there should be other sources of cheaper filter kits with out all the extras. I spent some time trying to search for bikes with Keihin FI and looking up their pumps/filters with out success, I'm sure someone else will find the right bike and source.
A mangy man chasing a cautionary tale
Lurking more and posting less
KTM 990R 500EXC
catalina38 is offline   Reply With Quote
Old 03-03-2011, 01:43 PM   #5
7575KK OP
KK
7575KK's Avatar
Oddometer: 105
Well..
So I hope so :)
What about second part, to keep it outside tank so i wont be tank-side dependent...
.. so that one of tank sides can be closed at will (no matter what, left or right) and pump will get fuel from other one open (like it is on 950)
KK
Old 03-03-2011, 02:09 PM   #6
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,160
I heard the same thing. I'd be interested as well.
I'd like to have it outside of the tank...
bikyto is offline   Reply With Quote
Old 03-03-2011, 11:28 PM   #7
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
working on it. if you want, PM me and we can discuss ideas.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 03-03-2011, 11:35 PM   #8
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
It would make sense that the pump assembly is shared with other production machines, however I have yet to find the cross over PNs. I also want to address a couple other design issues that I believe should be different for a machine that should be able to consume questionable quality fuels without significant and/or immediate reduction in performance of the heart of the FI system, the fuel pump; the flow and pressures associated.
Old 03-03-2011, 11:45 PM   #9
bikyto
bikyto's Avatar
Oddometer: 2,160
I'd be happy to help. It certainly isn't an area of expertise but I am willing....
Old 03-03-2011, 11:47 PM   #10
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
I have a BUNCH of irons in right now and a new wrinkle has just developed that will be reducing my available time for ~3-4 weeks, however I am very interested in working on developing a working solution, just need to find the extra time to make it happen.
Old 03-04-2011, 12:13 AM   #11
7575KK OP
KK
7575KK's Avatar
Oddometer: 105
Time...
Maybe Stones can help about time
http://www.youtube.com/watch?v=PHVey...eature=related
KK
Old 03-04-2011, 12:31 AM   #12
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,568
KK
You have NO IDEA how absolutely ironic that you chose the "Stones" for me to gain perspective..... "Stones" are what are making my near term available time.. um less than optimal.. one of those "well we can pull the dip stick or drop the pan" situations.... "won't know until we get in there"
Old 03-04-2011, 08:36 AM   #13
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,024
Good luck with that H2W.
Max
Da oggi la strada
é senza limiti
MAXVERT is offline   Reply With Quote
Old 06-11-2013, 06:10 AM   #14
GrenDesb
Oddometer: 320
Any development?
GrenDesb is offline   Reply With Quote
Old 06-12-2013, 06:47 AM   #15
Hipster
Hipster's Avatar
Oddometer: 1,768
Gefr sells both an aftermarket 990 fuel pump and filter kit in the vendor forum http://www.advrider.com/forums/showthread.php?t=874262
2008 KTM 990 Adv & 2007 KTM 640 Adv
Hipster is online now   Reply With Quote
Times are GMT -7.   It's 08:07 AM.
