Old 03-05-2011, 10:00 AM   #1
rwiles OP
Oddometer: 81
VDO Vison Speedo in GSPD?
Anyone tried a VDO Vison 437153 electronic programmable speedo as a drop-in replacement in a GSPD? Size seems right, diameter anyway. It requires 91mm of deptch - I think the stock speedo can is at least the deep.
And, I wonder if it can be made to work with the BMW tranny hall effect sender - don't see why not. The instructions say that it is auto-programable - put it in program mode, press start at the begining of a measure mile, stop, press stop, and it's programmed for both speed and distance AND it has a 'fine-tune' feature, where you can incrementally move the speedo needle, up or down, to where you think it should be, GPS or whatever. The BMW tranny hall effect makes a signal, and I guess the auto-feature just calibrates off that.
Anyone tried this? About $120 plus the hall effect sender.
rwiles is offline   Reply With Quote
Old 03-05-2011, 10:22 AM   #2
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,809
Thanks for pointing this out. I need a speedo for my project bike. This looks ideal
Rob Farmer is offline   Reply With Quote
Old 03-05-2011, 11:27 AM   #3
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,904
Have you sourced a BMW tranny Hall sensor?
The speedo's are easily calibrated, yes... I have done it with an Acewell, and the principle is the same...I am still trying to track down a tranny sensor: I'm all ears!
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 03-05-2011, 11:44 AM   #4
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,809
I've got a tranny hall sensor.
http://www.acewell.co.uk/Acewell%20A...ion=full&id=61
Old 03-05-2011, 02:00 PM   #5
rwiles OP
Oddometer: 81
Tranny Hall Sensor
http://bmwboxersupplies.com/
Old 03-05-2011, 02:47 PM   #6
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,809
The boxersupplies unit is nearly double the cost of Acewell UK
Times are GMT -7.   It's 07:40 AM.
