03-06-2011, 02:42 AM
#1 |
Oddometer: 138
GPS cradle for a Navman MY60
Hi all, having difficulty finding a decent cradle to mount on a ram mount for a Navman MY60, only option so far are using a similar sized Garmin cradle..
Anyone using the same GPS? |
04-13-2011, 03:04 AM
#2 | |
Oddometer: 34
http://www.advrider.com/forums/showthread.php?t=578027 ? As for it fitting in Garmin mounts that's going to depend greatly on the mount. You might be able to fill some extra space with strips or sheets of dense foam (which would also reduce the vibration a little, these are consumer automotive units after all.)
"Sure, nine out of ten people would want a Harley if you asked them, but then again, nine of ten people don't know #### about bikes." --JGullato |
05-11-2011, 04:28 AM
#3 |
Oddometer: 138
Measured up a Garmin cradle and fits perfectly with a RAM mount.
05-12-2011, 03:16 PM
#4 |
Nipple boy
Oddometer: 4,101
Did you try the Navman with the Garmin cradle ?
Very small differences can make them unworkable RAM do not do Navman cradles because Navman change the uinit shape on almost every unit whereas Garmin will use the same shape on half a dozen models . |
08-01-2011, 09:21 PM
#5 |
Oddometer: 138
Yeah tried and used many times with no issues, perfect fit and can still run the usb charger...
