Old 03-07-2011, 07:06 PM   #1
plane_ben OP
plane_ben's Avatar
Oddometer: 56
Trials conversions
Anyone out there in the trials world that remembers a trials conversion using a '72/'73 XL250 Honda? I have access to a pretty cheap XL250 and was thinking of doing such a project.
I know, I know. I could find a cheap TL250 and save myself the trouble. But I like doing stuff the hard way.
plane_ben is offline   Reply With Quote
Old 03-07-2011, 10:06 PM   #2
grizzzly
The Pre-Banned Version
grizzzly's Avatar
Oddometer: 3,432
i am pretty sure that i have ridden one back in the day and honestly i think you would be better off trying to convert a 250 ninja into a trials bike and you wouldnt be killing an old thumper, i have put a 54 tooth rear on my 82 xl500 and that does make it slow but it still wont turn or balance very well, and the clutch is not meant for that type of abuse, and when you get it into the tight stuff it develops this buick like feel
you actually expect people to take responsibility for their actions in today's society?!
grizzzly is offline   Reply With Quote
Old 03-07-2011, 10:50 PM   #3
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,633
Any bike is a Trials bike, if you ride Trials on it.
Gear it down, grind the steering stops, put good tires on it and go!
lamotovita is offline   Reply With Quote
Old 03-08-2011, 03:37 AM   #4
Brunow - 007
Bantam Fever
Brunow - 007's Avatar
Oddometer: 313
Hell yeah!... Would be cool to win a trails event on a 250 ninja
Working on the D14/4 Bsa Daily Driver .
Brunow - 007 is offline   Reply With Quote
Old 03-08-2011, 11:13 AM   #5
plane_ben OP
plane_ben's Avatar
Oddometer: 56
That Ninja stuff is pretty funny. But in reality, trials motorcycle were developed over time from regular motorcycles modified for the task. Being a Honda mechanic back in the mid '70s I owned and rode both XL and TL 250s. XLs had a heavier flywheel and different internal gearing, TL had a smaller carb. But overall they were identical. Most of us that rode the TLs in compertion bored our cylinders for 305cc and stole the flywheel off an XL for better grunt, a little trick I learned at the Honda tech center in Gardena. The factory trials and MX teams were right next door to the tech school building.
Anyway, with that being said. I'm more interested in a trail bike with some minor trials ability, than a trials bike. I had two modern trials, a Gas Gas and a Montesa 4RT. They are not to trail worthy when you can't sit down, and I'm old. I also have a pretty ragged XL250 of '72 vintage that would be a money pit to restore, but would make a nice trials/trail bike conversion. Our trials club would let me ride the vintage twin shock class on it, and they ride the novice sections. So it wouldn't be like I was going after some big narley sections, doing the stop and hop type of riding.
I do remember a cycle mag did an article on this very subject about a year before Honda came out with the original TL 250. So any old timers/trials historians out there to lead me in the right direction would be of great help.
Old 03-08-2011, 01:03 PM   #6
Ross Brown
One AU out
Ross Brown's Avatar
Oddometer: 70
Try Googling for this: Peter Gaunt and Alan Jeffries converted several XL Motorsport Enduros to trials. They changed the angle of the head, cut the bottom tube, put the engine higher in the frame and dropped the weight to around a little over a 100+ kg I believe.
Ross Brown is offline   Reply With Quote
Old 03-08-2011, 02:16 PM   #7
Thumpermeister
roost maker
Thumpermeister's Avatar
Oddometer: 2,818
Xl?
TL's started out as XL conversions, however with any number of the former available these days it's hard to see the appeal of going through a whole bunch of trouble to end up with a trials bike still inferior to a TL?
If you want a project, start with a TL and perhaps a Miller or Seely type kit frame to make a better trials bike then a stock TL!
Thumpermeister is offline   Reply With Quote
Old 03-08-2011, 04:03 PM   #8
GarageRat
GarageRat's Avatar
Oddometer: 160
This is an interesting idea. I have an old motosport worth experimenting with, a few DT1's as well. The DT may be a better prospect just based on weight, or lack of weight.
GarageRat is offline   Reply With Quote
Old 03-08-2011, 04:32 PM   #9
PSchrauber
PSchrauber's Avatar
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 872
Just go ahead, it will be very interesting to see the result, the main problem will not be the engine as I understood.
There you have a lot of knowledge. But the frame and the weight, this is the tricky part I think.
Here a conversion with a 350ccm Husqvarna engine, just to see what is possible. The frame was made around the engine:
Bike was still a little bit overpowerd.
PSchrauber is online now   Reply With Quote
Old 03-08-2011, 05:56 PM   #10
roninwva
roninwva's Avatar
Oddometer: 467
I've been thinking about the same thing so keep us informed and show some pics of the progress. I think it would be as good as some of the old thumper trials bikes from years ago. Maybe a little twin shock, vintage, novice trials for fun.
Check this out. I like it!
http://www.twnclub.ch/classic_trial_...friesXL250.htm
SO MANY ROADS, SO LITTLE TIME
CMA
PGR
HOG
91 FLHTC
04 Kodiak 450
06 Wee-Strom
roninwva screwed with this post 03-08-2011 at 06:36 PM
roninwva is offline   Reply With Quote
Old 03-08-2011, 06:58 PM   #11
roadholder
roadholder's Avatar
Oddometer: 2,538
Neil Gaunt has done some interesting projects as well...even getting heavyweught pre-65 classic trials bikes down under that weight.
http://www.classicdirtbike.co.uk/news/gaunt-ariel-classic-expert
roadholder is offline   Reply With Quote
Old 03-08-2011, 08:50 PM   #12
grizzzly
grizzzly's Avatar
Oddometer: 3,432
the engine isn't the big problem its the suspension it sucked on those bikes.
there were several people in our club (i think Bud Cole built most of them) took the engine out of a TL 250 and put it into a bull taco frame we called them hontaco's i was riding one before i got my first mono shock the 86 TY350
try to find a copy of "how to ride Observed Trials just for fun!" by Carl Shipman, there is a section "how to improve your enduro bike for riding trials" (page 117)
it is a great book
another good book by the same guy
Old 03-08-2011, 08:51 PM   #13
plane_ben OP
plane_ben's Avatar
Oddometer: 56
Thank you gentlemen. That is exactly the info I'm looking for. I'm going to go aquire an XL250 tomarrow.
Old 03-09-2011, 04:08 AM   #14
GarageRat
GarageRat's Avatar
Oddometer: 160
Good luck Ben, I know I'll be watching!
Old 03-09-2011, 10:54 AM   #15
plane_ben OP
plane_ben's Avatar
Oddometer: 56
Well, it was still there and I had a green light from the wife, just have to finish her CT90 first. So here it is.
plane_ben screwed with this post 07-02-2011 at 04:32 PM Reason: Added pics back in
Times are GMT -7.   It's 03:34 AM.
