Old 07-09-2011, 09:07 AM   #46
PSchrauber
PSchrauber's Avatar
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 872
Originally Posted by lamotovita View Post
Wow, I've got fork envy!
Are the fork brace mounts custom or from another bike?
Nothing to be envy for, actually I'am also a little bit impressed that it
turned out so well, I think I've got a fork flash and this mod turned into a pimp my Bultaco ride.
The mounts are from older GasGas, you can also take Sherco's from befor
2000. You have to get them first, just to know how much you have to turn
down the lower fork tubes.
I was inspired by the PUMA or Vasquez Bultacos, but these bikes where mostly rebuild with Paoli or other I do not know where they come from forks, (which are and will be far better too). I wanted to use the old standard Betor, these are cheap and easy to get.
I took a pair for a low price, now I would not try to get the cheapest, better to get one which is in a very good technical condition.
Without the corrections and chromeplating of the stanchions it is a really
priceworthy modification and a good fork from a newer bike of the end 80' or 90's is as twice as expensive.
PSchrauber is offline   Reply With Quote
Old 07-12-2011, 07:02 PM   #47
plane_ben OP
plane_ben's Avatar
Oddometer: 56
Got alittle farther along with my trials mods. I made the subframe much skinnier. After looking at the Peter Gaunt bike for a few more hours, I realized how they did it. First was to cut off outer down support from the shock mount to the outer swing arm mount tab. I refitted the down support by shortening the required amount and rewelded onto the top corners of the rear engine mount.
Then I made two plates for either side and located the holes for the swingarm bolt, and used some smaller dia. tube to slide into the rear engine mount cross tube. These I welded to the bottom of the side plates. I also welded the footpegs on and made the rear brake lever pivot.
Having lots of fun with this project. Next on the agenda is shorting the swingarm 1". Then I'll tackle the biggy, front fork rake.
plane_ben is offline   Reply With Quote
Old 07-17-2011, 08:50 AM   #48
plane_ben OP
plane_ben's Avatar
Oddometer: 56
As for badass trials conversions, this one takes the prize in my eyes. Totally cool!
Old 07-17-2011, 09:47 AM   #49
roadholder
roadholder's Avatar
Oddometer: 2,529
OK...what is it?
Honda engine. Frame?
roadholder is offline   Reply With Quote
Old 07-17-2011, 01:34 PM   #50
plane_ben OP
plane_ben's Avatar
Oddometer: 56
Honda TL250 engine bored to 280. Frame looks to be one off custom.
Here is a link. http://www.honda-trials.com/_sgg/m1ma_1.htm
Old 07-17-2011, 01:55 PM   #51
plane_ben OP
plane_ben's Avatar
Oddometer: 56
Finished up the steering stem angle mod. Came out straight as an arrow.
Old 07-21-2011, 02:54 AM   #52
Brunow - 007
Bantam Fever
Brunow - 007's Avatar
Oddometer: 313
Some great posts here! Nice!
Working on the D14/4 Bsa Daily Driver .
Brunow - 007 is offline   Reply With Quote
Old 07-23-2011, 05:19 PM   #53
Pete-NZ
Pete-NZ's Avatar
Oddometer: 763
Dam you lot...
Giving me ideas..
As if I need another project...
This really isn't a conversion
Other than converting a pile of
bits into a trials bike....
So after a hunt though the storage
/crap shed.. well I could build a trials
bike from this
one complete single shock rear end/
forks,clamps from a Chinese Shinray 200.
Motor.. well after a hunt around for a used one
I came across these...NO laughing..found a out fit
that was all but giving away these new chinese 125cc
Honda copys.. 4 speed box ,auto clutch power houses .
So I ordered one..
managed to flog a pic from this site of the specs..
rake/trail/wheel base etc of a gasgas ..
Now 1st to build a jig to bolt all the main componets in
at the right hights / angles etc.. then build a frame
around them..sounds easy when yer say it fast..
just lucky I have more toys in the shop than yer can
poke a stick at....lathe / mill / welders / plasma
It will give my boy 9 and me a some thing to do on wet days..
Pete-NZ screwed with this post 07-23-2011 at 07:36 PM
Pete-NZ is offline   Reply With Quote
Old 07-23-2011, 08:23 PM   #54
plane_ben OP
plane_ben's Avatar
Oddometer: 56
Awesome, we need some more action on this thread.
Old 07-24-2011, 05:10 PM   #55
Pete-NZ
Pete-NZ's Avatar
Oddometer: 763
The motor turned up ....
looking at it...I think
the best aproce is to make
the engine plates & set the
swing arm up on them..Prob
the easyest way to get it all
alined....
i think when the build starts I
mite start a new thread for it...
"with smaller pics"
pete
Old 09-17-2011, 05:58 PM   #56
Mythic State Rider
Oddometer: 20
Ben & Pete, is there any progress to report on your builds?
Mythic State Rider is offline   Reply With Quote
Old 09-17-2011, 07:17 PM   #57
Pete-NZ
Pete-NZ's Avatar
Oddometer: 763
Not on the bike....just got to get the side car done
then its all go...
side car build here....
http://www.advrider.com/forums/showthread.php?t=716993
Old 09-26-2011, 09:14 AM   #58
plane_ben OP
plane_ben's Avatar
Oddometer: 56
My project is on hold for awhile. Need to get my '58 VW van on the road.
Old 07-05-2013, 05:30 PM   #59
plane_ben OP
plane_ben's Avatar
Oddometer: 56
Pulling this project out of moth balls. Just finished up a Yamaha XS650. Updates soon.
Old 07-06-2013, 04:27 AM   #60
wb22rules
Bourbon Tester
Oddometer: 198
2001 Gas Gas 321 TXT
1980 Yamaha IT 250G
wb22rules is offline   Reply With Quote
Times are GMT -7.   It's 01:27 PM.
