Old 03-10-2011, 08:41 AM   #16
Grider Pirate
Grider Pirate's Avatar
Oddometer: 1,686
Originally Posted by zbg8000 View Post
My 93 gs had plenty of room for a standard 27mm socket from craftsman.
Same here.
Please don't tell Mom I'm a pilot. She thinks I play piano in a whorehouse.
http://griderpirate.smugmug.com/
http://www.youtube.com/my_videos?feature=mhum
Grider Pirate is offline   Reply With Quote
Old 03-10-2011, 03:47 PM   #17
asino OP
n00b indeed
Oddometer: 17
Nice. Good thing the Harbor Freight sidewalk sale is tomorrow!
My GS was put up in a warehouse for the last six years. Surprisingly, the battery still had a faint heartbeat according to my tester. After trying to trickle charge it back up though, it became clear that there would be no free lunch in this department.
So here is a nice sealed unit to replace it:
asino is offline   Reply With Quote
Old 03-10-2011, 03:48 PM   #18
asino OP
n00b indeed
Oddometer: 17
Who said men don't read instructions...
Came in the mail this morning, just in time:
Old 03-10-2011, 03:50 PM   #19
asino OP
n00b indeed
Oddometer: 17
Have you experimented in the past with lifting the engine out the side with a come along? Putting any motorcycle on its side smacks of preloading bad karma haha.
Originally Posted by bgoodsoil View Post
The gearbox needs to come off. You don't have to remove the swingarm to get the gearbox off but it's a heckuva lot easier if you do. To remove it you'll need a 27mm socket that's been ground down on the end a bit. The swingarm nuts are in a tight recess The clutch arm is mounted on the back of the gearbox and that's gotta get removed. There's a long rod going through the gearbox that gets in the way if you don't pull it out.
The engine's only held in with the 2 rods at the bottom(yours might have the mounts on top that go to the starter cover too). You might be able to lay the bike over and lift the engine out the side with a come-along.
Old 03-10-2011, 03:53 PM   #20
The Raven
The Raven's Avatar
Oddometer: 4,811
Come along...just hang the damn thing from the ceiling....not that heavy
The Raven is offline   Reply With Quote
Old 03-10-2011, 04:12 PM   #21
asino OP
n00b indeed
Oddometer: 17
Ooo, I like that. I think I might do some cherry picker improvisation, I can't make holes in a ceiling that doesn't belong to me...or can I
Old 03-10-2011, 11:07 PM   #22
bereahorn
Oddometer: 1,071
Fox
I have a Fox Twin Clicker on my '92 PD and sent it in to the factory last year for a rebuild. I am pleased with the job they did.
bereahorn is offline   Reply With Quote
Old 03-12-2011, 07:50 PM   #23
darklight79
scaffold builder
Oddometer: 444
shocks
So ...which shock to get? for 94 gs .... olhins wilber or fox ...? all around 7 bills out the door ..
darklight79 is offline   Reply With Quote
Old 03-12-2011, 10:36 PM   #24
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,607
I don't think you can get the fox anymore.
The options are Ohlins, WP, Wilbers, Works, YSS, Hagon, ...
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 03-14-2011, 02:03 PM   #25
asino OP
n00b indeed
Oddometer: 17
This weekend's results
Friday morning was strong, hit Harbor Freight and forged past Tsunami warnings to get to the shop an hour down the road:
Old 03-14-2011, 02:04 PM   #26
asino OP
n00b indeed
Oddometer: 17
Tsunami
Tsunami
Old 03-14-2011, 02:06 PM   #27
asino OP
n00b indeed
Oddometer: 17
First things first
Pull that bike into the garage and drain out 6 gallons of 6 year old gas, oil and gear oil.
Old 03-14-2011, 02:10 PM   #28
asino OP
n00b indeed
Oddometer: 17
Six hours later
We're down to the frame. Down to CalMoto for some nuts and bolts.
Decided to replace the selector rod seal and output shaft seal on the trans due to seriousl leakadge.
Stripped down to the fram:
Old 03-14-2011, 02:13 PM   #29
asino OP
n00b indeed
Oddometer: 17
More later!
Times are GMT -7.   It's 05:05 AM.
