03-08-2011, 12:46 PM
#1 |
Howling around...
Oddometer: 122
TT locking oilf filler cap - removal ?
I lost both keys for Touratech locking oil filler cap in my F8GS. And, guess what, I cant open it !
Anyone got similar problem and managed to open it WITHOUT KEYS ? Tried to dismantle it but with no luck (removing lock does not help much)... TT offered no help so far...HELP ! As I cant use my bike
03-08-2011, 01:08 PM
#2 |
Oddometer: 190
does it have pieces that secure it inside the filler neck (like a door lock that has pieces that extend when locked to keep it from being removed), or does the locking mechanism keep it from being removed by allowing the top to spin freely unless the key is used?
if the top just spins freely without the key inserted, you may be able to drill through that top part and into the portion that is in the threads of the filler neck - then insert a screw or something strong enough to "lock" the two halves together (free spinning outer part, and the rest that is in the filler neck) so you can remove it just an idea... |
03-08-2011, 03:08 PM
#3 |
Drunken Squirrel
Oddometer: 2,587
Get a locksmith...
![]() Cutting into this thing and potentially getting metal chips in your engine sounds like a bad idea.
Check out my F800GS Ride Reports: Colorado (F800GS and 640ADV) Sep 2010 Riding to Colorado Solo! June 2011 3000 miles New Mexico and Texas! Arkansas Nov 2009 | Arkansas June 2010 | Arkansas Oct 2010 |
03-08-2011, 03:11 PM
#4 | |
Citation Collector
Oddometer: 403
It would be really hard to ensure nothing falls into the sump.
"An expert is someone who has made every mistake possible within a very narrow field of inquiry" -Niels Bohr |
03-08-2011, 03:40 PM
#5 |
Oddometer: 44
take it to a lock smith
Just take the lock to a lock smith to get a new key made or take the entire bike to them if the lock is still attached to the bike. A good locksmith should be able to make you a new key. Hopefully you have not fuped the lock by taking it apart.
03-08-2011, 06:32 PM
#6 | |
Drunken Squirrel
Oddometer: 2,587
03-09-2011, 04:34 AM
#7 |
Oddometer: 3,434
The answer awaits in the later posts of this thread:
http://f800riders.org/forum/showthre...r-cap-dipstick Simple to remove once you know the trick
03-09-2011, 06:25 AM
#8 |
Oddometer: 190
bah, cant' be that thick of metal - drill enough to get a self tapping screw going (if the design is the free spinning top).
03-09-2011, 08:38 AM
#9 |
Ciao, Marco
Oddometer: 1,006
are you able to see a serial number on the lock?
i know for some things, like givi bags, you can buy spare keys based on the serial number on the lock...... |
12-07-2012, 03:34 PM
#10 | |
Oddometer: 59
Nothing LOCKING about this cap.
What a waste of money! What a waste of money! What a waste of money!![]() I just got one as a gift... - I screwed it in lightly. Locked it. - Then reached down under the spinning cap and unscrewed the stationary dip stick cap, with my fingers! And my oil filler port was open - for anyone! - Is this a novelty? Someone can easily get into this oil filler port. What a joke. If yours is on tighter, use a adjustable end wrench and simply unscrew the non spinning part of the cap. I suppose it could fool the average bozo, in a hurry, to do some tampering, on the sly. There is nothing LOCKING about this filler cap in my opinion. What a waste of money! What a waste of money! What a waste of money!
THE CENTER FOR LAND USE INTERPRETATION http://clui.org/ludb ![]() Earthquake, Weather, Radiation LINKS
http://sincedutch.wordpress.com/1ear...diation-links/ |
12-07-2012, 04:16 PM
#11 |
Oddometer: 734
Yes the whole idea seems like a wait of brain space. if your putting a lock on your oil filter... what about them steeling your GPS, wheel, or you.....
12-09-2012, 03:42 AM
#12 |
Oddometer: 2,397
First, don't listen to anyone who doesn't own one of these damn things.
Locksmith, serial numbers, forget about it. I did it already so you can learn from my visit to Senor Locksmith here and save your money! JR has the right idea, read my write up about it and you will understand the workings of it. The fix is very simple when you understand how it works. Take a look at the area of the locking cap that sits flush with the hole. That part can be grasped with a pair of pliers and you simply turn it and it will come out. If you still have difficulty, send me a PM and I will help you. As for anyone else contemplating the purchase of this item, think long and hard before wasting your money. I doubt I would even sell mine to someone used. |
