Old 03-09-2011, 11:28 AM   #1
65bmwr50 OP
65bmwr50's Avatar
Oddometer: 535
It's alive!!!!
After 8 years living in various rubbermaid totes, and getting moved to two different states my 1965 R50/2 runs again.
This bike has a great history with me. My dad and mom were living in Hawaii and bought this bike to get around the island. When they moved back to the mainland in 1970 they shipped the bike with them. It cost the same as a seat on the plane. They flew into Seattle, got some gas for the bike, and started riding. About a week later they got to western Pennsylvania where our family is from. My dad and my uncle rode the bike for the next 5 years and then the floats in the carbs went bad. Fast forward 27 years. Dad gives me the bike to restore it. I lived in Illinois at the time and my Brother-in-law brought it out to me. I bought floats for it and got it running again. I then tore it down to fix it up. While it was in thousand of pieces, my wife gets transferred to Virginia. That was almost 3 years ago. Now it is back together and running. I still have a few things to do such as tuning it and trying to figure out why the brake light and the neutral indicator is on all of the time. Right now I can get it to run but when I try to accelerate it falls flat on its face.
1965 BMW R50/2 (RUNNING AGAIN!)
An adventure is only an inconvenience rightly considered. An inconvenience is an adventure wrongly considered. - G. K. Chesterton
65bmwr50 is offline   Reply With Quote
Old 03-09-2011, 01:00 PM   #2
Beater
Airheaded, eg Simple
Beater's Avatar
Oddometer: 3,252
Fred
'85 R80RT G/Sified <|> '73 R75/5 LWB
Simply Simple and getting more so.
Beater is offline   Reply With Quote
Old 03-09-2011, 01:12 PM   #3
Beamer Bum
Beamer Bum's Avatar
Oddometer: 296
Another one on the road. You will love riding it and the family history is unbeatable. Welcome to the Slash 2 world.
Beamer Bum is offline   Reply With Quote
Old 03-09-2011, 01:16 PM   #4
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,325
Sweet.
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 03-09-2011, 01:19 PM   #5
danedg
Horizontally Opposed
Oddometer: 6,616
Brake lite
I'll take a stab at the brake lite problem. In the picture, you can see the lever that depresses the brake light switch. It's right behind the clutch lever with the stout spring. You can't see the switch in this pic, it's mounted with them teeny nuts on the back side of the plate, and no matter what you do, it's a pain in the ass to get to it. I remember having to get the 5?mm nuts off from the other side to service the switch.
ANYWAY, the arm is supposed to depress the switch, and keep it there which "breaks" the circuit. When you step on the rear brake lever, the switch post moves forward and "makes" the circuit, actuating the lamp.
Often, the brake lever, the small lever, or the switch itself are misaligned after 46 years, and the small lever doesn't fully depress the switch, and your brake light stays on...
I, stuck a teeny little crutch tip, [visible in photo] on the actuator lever to make up the misalignment. It worked for a while, until I sucked it up and dismantled the whole shebang and set everything up right. You can see the elongated holes for adjustamento...
I'll guarantee you that switch is filled with goopy,tarry,oily grit and grime. Take it off and soak it electrical contact cleaner for a day. If it's ON, then it still works. Or you buy a new one from Vech, it was pretty cheap.
PS, Your headlight ears are upside down
Just a reminder, ride every chance you get. You just don't know how soon it can be taken from you. T.Low
danedg screwed with this post 03-09-2011 at 01:59 PM
danedg is offline   Reply With Quote
Old 03-09-2011, 04:58 PM   #6
65bmwr50 OP
65bmwr50's Avatar
Oddometer: 535
Huh, that's what you get for leaving it in pieces for 8 years...
Thanks for the info on the brake switch. I'll have to check it out. I know the switch moves freely but maybe something else is misaligned.
Old 03-09-2011, 05:23 PM   #7
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Looks great and I appreciate the good story and historical background.
I hope it runs great and you can pass it to the next generation.
datchew is offline   Reply With Quote
Old 03-09-2011, 05:34 PM   #8
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,346
That is great to see an old veteran back on the road. Particularly sweet that you've left the original "patina" live! I'm taking possession of an old 1954 Zundapp soon and hope to do the same. Great job and a great story.
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 03-11-2011, 06:04 AM   #9
65bmwr50 OP
65bmwr50's Avatar
Oddometer: 535
Thumb Thanks danedg!
Brake lite was way out of adjustment, now fixed and the ears are flipped. I'm going to go for a ride on the Suzuki and come back and work on her, see if I can get it running better.
Old 03-11-2011, 09:55 AM   #10
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,410
Congrats and many happy miles ahead to you!
"The turd follows the fart as surely as the rain follows the plow."
Emily Bronte
Mista Vern is online now   Reply With Quote
Old 03-11-2011, 10:08 AM   #11
danedg
Oddometer: 6,616
R50,
A more detailed description of the "falling flat on it's face" problem, might help to pinpoint where you can start looking for the fix....
Let us know
Old 03-11-2011, 10:32 AM   #12
65bmwr50 OP
65bmwr50's Avatar
Oddometer: 535
More details
I can get it to idle nice and smooth. When I try to increase the throttle on it it will stumble and cough and then it will start to rev. At that point it will rev fairly easily and smoothly. Now when I let the clutch out it will start rolling then it just dies. I pull in the clutch and goose it and it is back to coughing and popping. I also need to add that I have done nothing when it comes to timing or tuning the carbs so far.
Old 03-11-2011, 11:50 AM   #13
danedg
Oddometer: 6,616
Nothing is good, and how it should be. Adjustments should be made one at a time. Take it for a ride, and then make another one. If you try adjusting 8 things at once, you'll never figure out which part is screwin' up the works. Don't ask me how I know this!
Let's start by determining that your throttle cables are connected, and connected correctly. It's possible that you're not lifting a carb slide. Maybe late, maybe not at all...it would start and idle, but cough and die under load. Which is what you described.
Pull the intake tubes off. Check to see that the slides in the carbs are both lifting at the same time, when you twist ze throttle.
Set two swizzle sticks, [mini tongue depressors] under each slide. Gently engage the throttle, the 2 sticks should start moving at the same time. There's an adjustment if they don't.
Make sure the slides are returning to their bottom position as well...
These bikes are well made and dead simple. If something ain't right, there are only a few things that can go wrong. Start with the obvious.
danedg screwed with this post 03-11-2011 at 12:02 PM
Old 03-11-2011, 12:00 PM   #14
danedg
Oddometer: 6,616
Old 03-11-2011, 12:09 PM   #15
lemieuxmc
lemieuxmc's Avatar
Oddometer: 3,360
It might be running OK on the idle jet, but you have a plugged pilot jet, then its OK on the slide/needle/main jet.
Pluck a strand out of your wire brush and clean the orifices with that and some spray cleaner.
lemieuxmc is offline   Reply With Quote
Times are GMT -7.   It's 06:01 PM.
