Old 11-29-2011, 08:26 AM   #16
scott9057
Oddometer: 31
Well I'm rebuildimg the engine right now anyways, so I'll try the fix and see if it helps any. Give me a week or two and I'll report back here any improvements!
scott9057 is offline   Reply With Quote
Old 12-11-2011, 02:08 PM   #17
pfb
Riding, not skiing.
pfb's Avatar
Oddometer: 5,517
I have a new-to-me 2010 450 six days with 30 hours on it. It's Winter in Denver, so I've only been able to get it out for one test ride and I had this exact problem.
Very difficult to get a hot restart in-gear. Put it in neutral, fires up. Huge PITA.
I haven't dug into the jetting yet, and honestly assumed it was a jetting issue, possibly even a clutch bleed issue, but this sounds like a more likely culprit.
Thanks for documenting this issue...
950 Adventure 950 Super Enduro 450 XC-W Six Days
pfb is offline   Reply With Quote
Old 12-22-2011, 05:04 AM   #18
MItrnsplnt
PllnGs tillthey puke
MItrnsplnt's Avatar
Oddometer: 671
Hodakaguy......you are the f-ing man!!! My beloved 530 recently started doing this and really began to scare me that something was wrong after I coddle the bike in maintenance after everytime I ride her!!! How you figure these things out, is a puzzle to me....guessing you are an engineer of some sort, right? Well I'll be doing this and also the oil pump gear change at the same time to keep the 530 running in tip top shape! Thanks for the info and guidance!!!!
And as my signature says, this bike is the one and only and just plain RIPS at anything you throw at her!
'09 KTM 530EXC (do-it-all workhorse)
'04 KTM 250EXC (ST switchblade)
'13 Sherco 3.0 (trials billy-goat)
Rocky Mountain Ride 2011: Aspen to Crested Butte and back
http://advrider.com/forums/showthread.php?t=723271
MItrnsplnt is offline   Reply With Quote
Old 12-22-2011, 08:40 AM   #19
ABuck99
0.0
ABuck99's Avatar
Oddometer: 651
Nice write up- and pictorial. You helped me find the cure to this issue last year, and I appreciate your help. I actually was able to get KTM to warranty this, even though I was just a month or two out of warranty. I noticed from my spare parts manual to the online fiche, the have subsequently updated the torque limiter part number, so they must have had a bad run of these.
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 12-23-2011, 05:54 AM   #20
Hodakaguy OP
NorthWest Adventure Rider
Hodakaguy's Avatar
Oddometer: 2,096
Thanks, I didn't figure the problem out though. I had read on other forums where people had the same problem and the torque limiter ended up being the issue. I just thought I would type up a how-to for others to follow if they were having the same issue so it could be more widely known.
I'm getting ready to upgrade the oil pump gears in my new 530 and noticed there is a updated oil pump shaft as well now, I'll install the new shaft and see if there is any difference between it and the old version then update the oil pump how to accordingly.
Hodakaguy
NV 2012 - In Memory of the Crewmen RR: CLICK HERE
Adventure Is Out There - NV RR: CLICK HERE
Riding Through History - NV RR: CLICK HERE
And Then There Were Four - OR RR: CLICK HERE
My VW Syncro Westy Build Thread: CLICK HERE
Hodakaguy is online now   Reply With Quote
Old 12-23-2011, 05:56 AM   #21
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,096
Would be interesting to see what was changed between the two part numbers. Thanks for the heads up
Hodakaguy
Old 12-23-2011, 09:13 AM   #22
Capp
Resident
Oddometer: 88
About to replace the oil pump shaft and gears myself. Just waiting on the oil pump cover that has been backordered. Should be here next week. I also ordered the 125 oil jet as the 08s came with 100. More oil for the crank.
2013 KTM 350 EXC-F
Capp is offline   Reply With Quote
Old 12-23-2011, 09:31 AM   #23
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,096
Yep a good upgrade for the 08's on the oil jet, I'll add that to the oil pump upgrade thread when I revise it with the updated shaft.
Hodakaguy
Old 01-26-2012, 08:40 AM   #24
PLATAPUS RIDER
Oddometer: 1
Hello Hodaka Guy,
I ride a 2011 530EXC. I need to remove my inner clutch cover in order to helicoil the stripped out gear oil sight hole. It appears that once I remove the brake lever and kick starter, and loosen the bottom radiator hose from the water pump assembly, the entire cover comes off as one. Is that correct? Do I need to remove the water pump and outer clutch cover first, or can they stay on? You've posted really clear pictures, but it's hard to tell for sure.
My local shop wasn't much help with this. They're reluctant to give advice to a DIY mechanic. Any advice you can give me is appreciated.
PLATAPUS RIDER is offline   Reply With Quote
Old 01-26-2012, 11:51 AM   #25
akarob
Green Cantern
akarob's Avatar
Oddometer: 7,940
Originally Posted by PLATAPUS RIDER View Post
Hello Hodaka Guy,
Your question is off topic, but I'll help you out. Your easiest fix will be to use JB Weld to glue that screw in place. It's not necessary to set the level of the tranny oil that precisely. It takes almost exactly one quart. Just add that much oil and be done with it. No need to check.
akarob is offline   Reply With Quote
Old 01-26-2012, 12:23 PM   #26
Hodakaguy OP
Hodakaguy's Avatar
Oddometer: 2,096
Hello Hodaka Guy,
If you decide to remove the clutch cover it's pretty simple, no need to remove the water pump cover. Just remove the kick starter, brake lever and water pump coolant hose...then remove the bolts. The whole cover will just slide off. When re-installing the cover take your time and don't force it...if it doesn't want to slide back on easily move the water pump gear a tiny bit and try again until it slides on without hanging up.
On a side note I like to torque everything to spec but don't try and torque the oil fill bolt for the trans...it will strip. I just snug it up lightly by hand and call it good.
Hodakaguy
Old 03-25-2013, 10:14 AM   #27
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,900
Huh,so I guess its the clutch drag causing the Torque limiter to not allow the engine to spin hard enough? My 2011 530 starts instantly unless its in gear with the clutch in.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 03-25-2013, 11:00 AM   #28
akarob
Green Cantern
akarob's Avatar
Oddometer: 7,940
No, it is independant of the clutch. I fixed my starter using this guide. It was very easy.
Old 03-25-2013, 03:38 PM   #29
Foot dragger
singletracker
Oddometer: 12,900
Im still in the dark then,why does it turn over and start real easy in neutral?
And then not start in gear with the clutch in?
How is the torque limiter affected by clutch drag?
I was also wondering,if it does pop back on starting,and the torque limiter doesnt limit torque as intended,what then?
Im mechaniclly curious
Old 03-25-2013, 03:49 PM   #30
akarob
Green Cantern
akarob's Avatar
Oddometer: 7,940
Well, mine wouldn't start whether it was in neutral or not. Perhaps your torque limiter is still good enough to work in neutral. The clutch does add a certain amount of drag to the system, even when the bike is warm and the lever is pulled in.
Tightening it is easy once you get it out. About a quarter turn or so will do it. I was even able to re-use the cover gasket, although I had a new one on hand in case it ripped.
Times are GMT -7.   It's 06:52 PM.
