Old 03-13-2011, 01:40 PM   #1
chanhkyle OP
Oddometer: 2
1974 Yamaha RD350 Timing and Autolube
Hello Everyone,
Newbie here with a '74 RD350 fouling plugs. I've been reading on this site about the importance of setting the timing and making sure that the autolube is adjusted correctly for this situation. My knowledge of setting the timing and the autolube is very lacking. A dial gauge is in the mail and I've got a makeshift timing light on hand. Can anyone tell me how to set the timing and adjust (make sure) that the autolube is correctly working?
Thanks a million.
chanhkyle is offline   Reply With Quote
Old 03-13-2011, 02:14 PM   #2
JonnyCash
turd polisher
Oddometer: 1,603
I'll get back to you on this, meanwhile walk this way.....2strokeworld.com. I freaking love my RD, it's so fun it's hilarious!
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 03-13-2011, 02:59 PM   #3
chanhkyle OP
Oddometer: 2
Thanks JohnnyCash,
I just took a visit at 2strokeworld.com and the timing instructions. Great info! I'll give it a try when the dial gauge gets delivered (probably tomorrow). But, I didn't really find info on the autolube.
I was just concerned that these instructions are general for two-strokes and not specific to the RD350.
Old 07-04-2011, 07:52 PM   #4
troutslayer
Oddometer: 1
autolube
Did you ever find any info on adusting the autolube? I have a '73rd350, and also would like to know how to adjust it.
Cheers,
troutslayer is offline   Reply With Quote
Old 07-05-2011, 03:57 AM   #5
noman
Oddometer: 904
timing
try these guys, great resource when i had my 72dt250 a coupla years back.
yamahaenduro.com
1976 r75/6 -- mine since 1980, thx lloyd!
1985 vf500f -- v4, 6 spd, 16v, triple discs, water cooled
1997 900ss -- full sp spec
noman is offline   Reply With Quote
Old 07-05-2011, 10:47 AM   #6
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,339
Have a look at this one..
http://justyamahard350.com/articles/bill.htm
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 07-05-2011, 11:29 AM   #7
klp
Oddometer: 254
Cheers,
You can verify that it is pumping oil by removing the bleed screw on the pump. Take the oil pump cover off then run the bike with the screw removed. At idle it will move some oil, if you rotate the plunger around to max stroke it should drip out at a pretty good clip.
As far as adjustments the book says to adjust the stroke of the pump. You do this by adding or removing shims. You need to rotate the pump to full stroke then you will see a small notch on the pump pulley. The gap between that and the pump body should be .040" I think. If you want I can check later.
Lots of old Hondas, 2 Yamahas, 2 Kawi's.
klp is offline   Reply With Quote
Times are GMT -7.   It's 09:22 AM.
