View Results: Should I Replace it?
Yes 0 0%
No 3 100.00%
Voters: 3. You may not vote on this poll
Old 03-13-2011, 08:19 PM   #1
wmax351 OP
Oddometer: 743
Question Airhead Spline Collars
Hi everyone. I am working on restoring an R75/5 toaster. I just had the final drive rebuilt by Hansen's, and I am wondering about the spline dog/collar on the rear wheel. It seems to be in okay condition, but should I replace it as a matter of course? Will a slightly worn one affect the new splines?
Basically, what I want to know, is it worth 100 bucks to replace it. I have access to a machine shop at my college, so the difficulty of replacing it is not an issue. I will probably use Hi-Lock/shear Aircraft fasteners or tight tolerance bolts to install the new one, after knocking out the rivets. (At the suggestion of the Machinist at UC Berkeley.)
wmax351 is offline   Reply With Quote
Old 03-13-2011, 08:24 PM   #2
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,477
I would leave it alone. If you do replace it I like using the /6 and later one. It uses a larger rivet and a deeper spline.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 03-13-2011, 08:37 PM   #3
Beamer Bum
Beamer Bum's Avatar
Oddometer: 296
Most wear is usually on the ring gear splines, but those rivets holding the wheel cup get loose. That is not good. If the cup is loose and you have to replace the rivets, then replace the cup. Otherwise grease the splines and ride it.
Beamer Bum is offline   Reply With Quote
Old 03-14-2011, 02:24 AM   #4
wmax351 OP
Oddometer: 743
Okay, I will just clean it out, and re-grease it with some moly-60. Thanks for the quick reply.
Times are GMT -7.   It's 01:06 AM.
