09-01-2002, 06:16 PM
#1 |
Oddometer: 8
F650GS change oil question
Hi,
I just changed the oil on my new F650Gs after 1,280 kilometers. Question: 1. Why is it difficult to drain out the oil? Seems not everything comes out in one go. 2. Is it normal for the oil to have bubbles thru the peep hole after a run? Thanks in advance!
02 BMW f650GS 96 Kawasaki KMX 125 Ex bikes: 02 Honda Silver Wing 00 KTM Duke 2 01 Yamaha XT225 |
09-01-2002, 07:32 PM
#2 |
Oddometer: 4,752
oil change
did you remove the left side cover and drain the resevoir? bubbles?
I |
09-01-2002, 08:33 PM
#3 |
Urban Adventurer
Oddometer: 221
i see bubbles in my sight-glass after a run as well. i have an '02 GS, still on the original tank of oil.
09-02-2002, 06:13 AM
#4 |
Jetmechs' Winston Wolf
Oddometer: 505
Scavenge pumps pump more oil than pressure pumps. If/when pressure pump gets behind scavenge pump on oil flow, the scavenge pump will suck some air. Some dry sump engine oil tanks have a de-airetor (sp?) to keep the froth down.
So tiny bubbles in your oil is a "design feature".
"Never should have destroyed the Bamiyan statues." - Popular sentiment of those partaking in the Gitmo Resorts vacation tour |
09-02-2002, 01:35 PM
#5 |
Oddometer: 278
Check out the oil change FAQ at f650.com.
You'll be very happy that you did. Robin |
09-02-2002, 10:01 PM
#6 | |
Who is Cockeye?
Oddometer: 2,556
Re: F650GS change oil question
If I run it till its hot, use the sidestand to drain the res, centerstand for the sump and filter, I can get most of the oil out. As for bubbles, yes quite normal. My explanation mirrors the pot-head's with the addition that the oil shoots back into the res from the top through an air gap of a few inches and it stirs things up quite a bit.
Racing in life's own Class 11 |
09-02-2002, 10:46 PM
#7 |
Oddometer: 47,709
and here's bird showing off his technique...with a little help from
dr. choopenstein and mully.
09-03-2002, 07:36 AM
#8 |
Oddometer: 505
Pot-head?
Nice pix. You all got sump thread stuck in your fingers? Three for one oil change? "I'll take the resevoir, you get the sump, and you get the filter."
09-03-2002, 09:45 AM
#9 | |
Who is Cockeye?
Oddometer: 2,556
09-03-2002, 05:31 PM
#10 |
Oddometer: 505
Apology accepted. Let's move on to the beer drinking.
I thought for a second it was from my being close to Ann Arbor, a liberal stronghold and home of the dreaded EPA (We can't even get Speedvision on local cable. Must be verbotten, or something.)
09-06-2002, 06:39 AM
#11 |
Oddometer: 8
Thank you guys!
Robin, I printed out the oil change faq. It was of great help!
