Old 06-20-2012, 10:20 AM   #181
ian408
Oh?
ian408's Avatar
Oddometer: 14,542
Originally Posted by Nut Clutch View Post
Not the material that makes the difference. The collector on the 2 into 1 on the Roxx merges to a much larger smoother diameter. Look earlier in this thread. I posted photos and measurements. I have had a FMF Q4 with the adv 2 into 1 and also the Roxx. Big difference between the two.
Read the post I quoted.
ian408 is offline   Reply With Quote
Old 06-20-2012, 04:44 PM   #182
hvman
Oddometer: 184
popping update
reinstalled 2 into 1 roxx pipe with high temp silicone gasket sealant: no better, no change, dang it!
hvman is offline   Reply With Quote
Old 06-21-2012, 09:02 AM   #183
RLCanon
Adventure Arrrrr!
RLCanon's Avatar
Oddometer: 368
I have the SAS plates/cannisterectomy done and recently installed the Roxx system with no sealant etc. I'm even using generic throttle return springs in place of the exhaust springs that weren't included when I ordered the system. Sounds great (wind it to red line and it absolutely wails, absolutely no decel popping).
I had a carbon Remus with an adv 2-1 previously. The rivets holding together the intake side chewed into the carbon can enough that l had to epoxy it back together before a 3 state trip last fall, which worked well. I had several issues sealing that system, both were the can bolts to the 2-1 and where the 2-1 fits onto the header pipes. The Roxx appears tight as a frogs sphincter first time on.
I personally don't think the adv 2-1 construction affects anything significantly, but there is no doubt that the fabrication of the Roxx 2-1, really the whole system, is much more precise and the design seals better than what I had on there before.
What can I say? Life has been everything to me. Was it good or bad? It was just life, everything was in it. I suppose my advice for the living might just be: Live! And when it is time to die, die! - Ozymandias
We're all contributing factors to our own demise... - Lovin' it Strom
RLCanon is offline   Reply With Quote
Old 06-21-2012, 10:07 AM   #184
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 429
Took out the restrictor / spark arrestor and rode to work with the Roxx. The top end ROXX!
'07 KTM 990 Adventure Long Road to Dug Bar
Nut Clutch is offline   Reply With Quote
Old 06-21-2012, 10:22 AM   #185
RLCanon
Adventure Arrrrr!
RLCanon's Avatar
Oddometer: 368
How much louder is it on a scale from "Not much" to "Holy shit!"
Old 06-21-2012, 11:37 AM   #186
Katoom72
Katoom72's Avatar
Oddometer: 902
i bet it's: Holy shit that crap is loud as fuck! (and i toned it down profanity wise)
Katoom72 is offline   Reply With Quote
Old 06-21-2012, 11:40 AM   #187
JGE
Oddometer: 17
Without the insert the ROXX is definitely not quiet but still sounds great. I haven't ridden mine with the insert yet so will have to try it out one day to hear what it is like.
JGE is offline   Reply With Quote
Old 06-21-2012, 02:57 PM   #188
Nut Clutch
was Steve Lavigne
Nut Clutch's Avatar
Oddometer: 429
Without the insert it is quite loud, but not stupid loud. It is a very sweet sound. Has a real strong top end to it. It breathes so free that there is a bit a of a stumble with a large quick throttle opening off idle with no secondary throttle butterflies installed.
It is a little too reasonable with the Euro compliant restrictor / spark arrestor. Just the right thing for a moto trip though. I'm trying to get a friend of mine to make a less restrictive spark arrestor. The top end performance suffers a bit with the restrictor, but there is no stumble off idle.
Old 04-06-2013, 09:38 AM   #189
Masa
Masa's Avatar
Oddometer: 301
Old thread, but informative enough to resurrect.
When you buy a 2 into 1 pipe, check inside how it looks. I got this from Adventure Spec, but had to send it back. Very small opening inside and the end of the pipe coming from the rear cylinder had been hammered partially flat to make it easier to weld on the other half.
Next I ordered pipe from our Polish friends, 21Brothers. It is rough on outside - and inside, but openings are somewhat ok-ish.. It doesn't fit very well, but good enough for now.
Bike runs fine, a bit louder and rougher sound, but it sounds good on a forest leg I have a Wings can with the small insert, not sure if that is too restrictive.
Masa is offline   Reply With Quote
Old 04-06-2013, 10:46 AM   #190
crazybrit
crazybrit's Avatar
Oddometer: 8,556
I originally had the AdvTank 2:1. It was better than your AdventureSpec one but there was still a pronounced restriction where the rear cylinder joined (i.e the opening wasn't large enough). The AdvTank also had poor fitment, a known issue that I believe still has not been fixed, see: http://www.advrider.com/forums/showp...28&postcount=9
I got a CJ Designs 2:1, fit was perfect (since it's based on an OEM header). There was a little bit of cruft (similar to your Polish one) that I removed with a dremel extension.
I'd recommend the CJ one.
crazybrit is offline   Reply With Quote
Old 04-06-2013, 11:26 AM   #191
Masa
Masa's Avatar
Oddometer: 301
I'm not sure if the AdventureSpec's pipe is the same as ADVTank, but they use same pics and info for marketing. After I got the pipe, did some digging and found some of your posts mentioning that people haven't been happy with their ADVTank pipes. So I figured it's the same scheisse.
I knew about CJ, but was trying to find something I didn't have to pay customs.
I could've made my own from the stock collector (still might), but it's worth of 300 euros and might want to use it some day.
Old 04-06-2013, 11:32 AM   #192
crazybrit
crazybrit's Avatar
Oddometer: 8,556
Hmmn I would not have thought they were that expensive but you're right, $340. I guess the prevailing used price is $225 as that's what CJ charges for core. I just paid the core and kept my original, like you, I figure I might need it someday (go back to 2:2).
Old 04-06-2013, 12:23 PM   #193
Masa
Masa's Avatar
Oddometer: 301
Yeah, an expensive piece of art. Should clean from the inside to see how it looks there.
I was actually surprised to read that you felt the need to clean after CJ's work.
It's one thing to do your own, it might look like a porcupine with all the MIG wires sticking out and you'd be happy with your work, but to buy one that was advertised to be a piece of art that it certainly isn't, is an other.
Old 04-06-2013, 01:31 PM   #194
crazybrit
crazybrit's Avatar
Oddometer: 8,556
There was a little bit of beading but (looking at your pics again) it was much better than your second Polish one. I'm sure it would have been fine as is, but since I have a dremel extension it was easy to take 10 mins and clean it up.
Old 07-31-2013, 01:14 AM   #195
montibank
Happy
montibank's Avatar
Oddometer: 2,825
No metion of jetting ... Anyone run any of these 2-1 setups on a 950? If so did the manufacturer supply a starting point for jetting setup?
montibank is offline   Reply With Quote
Times are GMT -7.   It's 01:24 PM.
