Old 07-31-2013, 03:07 AM   #196
Unruled
950S
Unruled's Avatar
Oddometer: 120
Originally Posted by montibank View Post
No metion of jetting ... Anyone run any of these 2-1 setups on a 950? If so did the manufacturer supply a starting point for jetting setup?
I have the 2-1 GPR Rally system on my otherwise stock 950, no mention of re-jetting anywhere (in fact they state it's not necessary).
That said, it's defenitely running a bit lean.
If you can't fix it with a hammer, you've got an electrical problem.
Unruled is offline   Reply With Quote
Old 07-31-2013, 03:48 AM   #197
mousitsas
mousitsas's Avatar
Oddometer: 2,913
160/165 for that one @sea level
mousitsas screwed with this post 07-31-2013 at 04:45 AM
mousitsas is online now   Reply With Quote
Old 07-31-2013, 05:23 PM   #198
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,123
Any one got a left hand akro hexagon or ti oval muffler they want to sell
Birth of a Rally Bike - KTM525
Mudguts is offline   Reply With Quote
Old 07-31-2013, 08:22 PM   #199
montibank
Happy
montibank's Avatar
Oddometer: 2,825
After many tears, bloody knuckles, and a thrown wrench or two my home made 2-1 FMFQ (modified) 2004 950 is finally running decent.
158
155
Alt: 328'
Temp: 100 F
RH: 30%
Clips @ 3
IMS @ 2.0 and 1.75
Pre-filter on and K&N style oil/cotton filter
EPC removed, SAS removed, cats gone otherwise stock :p
Feels like clips may need fine tuning but it runs
montibank screwed with this post 07-31-2013 at 08:29 PM
montibank is offline   Reply With Quote
Old 07-31-2013, 10:49 PM   #200
Qwik
Adrenaline Addict
Oddometer: 6,868
On my 05 950 I have a 2-1 with a ti Remus and a prefilter. Stock jetting and it runs great.
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 07-31-2013, 11:56 PM   #201
mousitsas
mousitsas's Avatar
Oddometer: 2,913
Note
GPR and the typical moded 2-1 are quite different
Old 08-01-2013, 01:53 AM   #202
montibank
Happy
montibank's Avatar
Oddometer: 2,825
Yes.
Mine started with 148 and 152 mains clips at 3.5 and was stupid rich. Had other issues too, but it got me from southern cali to central cali on one cylinder. Haha... That was the WORST ride over the grapevine @ 1 am I have ever been on.
Old 10-05-2013, 05:58 PM   #203
556baller
Oddometer: 23
I didn't see anyone mention whether or not the FMF Q4 Ti cans will handle the heat and pressure from a 2 to 1 conversion.
556baller is offline   Reply With Quote
Old 10-05-2013, 10:23 PM   #204
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
The Q4 is a popular option for the 2-1
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 10-05-2013, 10:48 PM   #205
NWMotohead
Motojunkie
NWMotohead's Avatar
Oddometer: 24
I have been running the FMF Q4 Ti and a 2-1 on my 950 SE-R for over 4,000 trouble free miles. Many miles were at highway speeds, no issues and running H2W Jetting (thanks Ken).
07' KTM 950 SE-R, 09' KTM 450 XC-W
NWMotohead is offline   Reply With Quote
Old 10-06-2013, 06:58 PM   #206
556baller
Oddometer: 23
thats good enough for me, thanks...
Old 03-01-2015, 06:42 AM   #207
leesbian
Oddometer: 179
Question HELP! - can't remove OEM manifold
Originally Posted by Hodgo View Post
Anyone here change to a 2 into 1 and keep one of the Akro's ?
Firstly, apologies for resurrecting an old thread
Yes, that's exactly what I'm in the middle of doing. I have both a 950SE (with 2 Titanium Akro's) and a 990 ADV (with OEM silencers)
I've bought two 2-into-1 manifolds (from ebay) with the intention of putting 1 of the Akro's from the 950SE onto the 990 ADV. I'm a little concerned about those at the moment, because they look pretty much identical to me, and from reading comments in the thread they should be somewhat different between the two bikes... when I get further into it, I may get bitten by that
At this point, I should mention that I'm quite a mechanical novice...
I've currently got both bikes mostly stripped down, but I'm a little stuck. I can't seem to remove the old manifold from the SE.
Is there some kind of trick to freeing it up? all the clamps and bolts are removed, the silencers are removed, and I've also removed the rear mudguard and lower subframe bolts so I can get more access... but the manifold is pretty tightly stuck on to the engine side
Is the trick to completely flip up the subframe, so that the mountings for the manifold are no longer fouled by the subframe, and then start rotating back and forth?
I've got the 990 sitting with a load of penetrating fluid on the bolts for the silencers before I progress with that, but having read the comments in the thread it seems that the trick with that is to drop the subframe rather than raise it
Thanks in advance...
'12 KTM 990 Adventure
'09 KTM 950 Super Enduro Erzberg (41/100)
'04 KTM 525 MXC
'00 Ducati 748 Biposto
'89 Honda Camino (The Adventure Moped)
leesbian is offline   Reply With Quote
Old 03-02-2015, 06:46 AM   #208
WIsixfitty
ceiling unlimited
Oddometer: 2,303
It's been a while since I removed these from a 950 as that bike is slong gone.
You may need to pretty much remove the subframe to get the "H" pipe off.
Also the SE and ADV are definitely 2 different 2>1 manifolds.
sideways and smiling
WIsixfitty is offline   Reply With Quote
Old 03-03-2015, 03:54 AM   #209
leesbian
Oddometer: 179
I managed to get the SE's H pipe off by fully taking off the subframe - with it in place, the mounts for the pipe kept fouling themselves on the pillion footpeg mounts. With the subframe removed it didn't take that much effort at all
Going to tackle the 990 in a few hours... penetrating fluid has been sitting on the silencer bolts for a few days now, so hopefully they'll come off without a problem, at which point I'll be able to get a good look at the H pipe
Sounds like I probably have two manifolds for the SE :-/
'04 KTM 525 MXC
Old 03-03-2015, 04:00 AM   #210
leesbian
Oddometer: 179
Hmm... I've just checked the Adventure Spec website for the 2>1 manifolds.. it's the same part for all bikes (http://www.adventure-spec.com/defaul...t-adapter.html). This is what mine look like (although not quite as shiny!)
If you click the technical info tab, it says "* Will work with any exhaust designed for the 950/990 except those requiring a different midpipe such as the Leo Vince."
I've checked the KTM fiche-finder, and yes - the OEM H pipes ARE different, and different part numbers. However, it seems that the 2>1 H pipe is the same for all bikes
If this turns out not to be true, then I'll be sure to update the thread... and to inform Adventure Spec
'04 KTM 525 MXC
Times are GMT -7.   It's 08:40 AM.
