Old 03-14-2011, 06:44 PM   #1
Grider Pirate OP
Grider Pirate's Avatar
Oddometer: 1,669
Bing issue
My '95 GSPD has always missed slightly under very low load conditions. I've been fighting it for years. New Metering Needles, New Needle jets, new Diaphragms, etc. etc.. By contrast, my '88 RS has always run wonderfully. Last week I swapped carbs between the two bikes, and, as expected, now the GSPD runs sweetly and the RS.. not so much. The book calls for all the same parts (jets, needles, etc..) but I tore down both sets to compare. Needles in the same grooves, same jets (135, 2.66, 45)... everything I could find was identical. WTF?? Then I noticed on one of the GSPD carbs that the little domed piece in the center of the carb top is LOOSE.
It's loose enough to pass some significant air in a highly scientific 'suck' test. I've never heard of this before. Is it common?
I'm thinking of floating some epoxy into that junction. Anybody have experience with this?
Please don't tell Mom I'm a pilot. She thinks I play piano in a whorehouse.
http://griderpirate.smugmug.com/
http://www.youtube.com/my_videos?feature=mhum
Grider Pirate is offline   Reply With Quote
Old 03-14-2011, 06:52 PM   #2
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,297
Fairly common problem.
Rather than try to recrimp it when that happens, I use JB weld.
Works like a dream
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 03-14-2011, 06:52 PM   #3
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 7,935
Mine were loose and I used some gasket maker, epoxy sounds like a better way to go. The loose tops definitely had a negative effect on how my bike ran
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 03-14-2011, 06:55 PM   #4
bmwrench
Oddometer: 1,465
I'd use Loctite 290, formerly known as Wick'n'Lock. Just put a drop or two around the plug and watch it disappear. Don't get carried away with the quantity, and apply with the engine stopped.
bmwrench is offline   Reply With Quote
Old 03-14-2011, 06:58 PM   #5
supershaft
because I can
Oddometer: 6,080
Has anyone ever sent them to Bing USA to get re-crimped?
Old 03-14-2011, 07:11 PM   #6
Tosh Togo
Oddometer: 1,594
Nope.
Short, sweet, and effective.
Tosh Togo is offline   Reply With Quote
Old 03-14-2011, 07:14 PM   #7
bmweuro
Mad Scientist
bmweuro's Avatar
Oddometer: 2,966
I like using epoxy. The top piece will always look shiny. BTW. Check your choke gaskets.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
bmweuro is offline   Reply With Quote
Old 03-14-2011, 07:20 PM   #8
Hawk Medicine
Coyote's Brother
Oddometer: 3,299
If you're running 32mm Bings, an old rally pin with some silicone under it works perfectly.
I haven't found the perfect object to glue onto 40s yet.
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine screwed with this post 03-14-2011 at 07:26 PM
Hawk Medicine is offline   Reply With Quote
Old 03-14-2011, 08:18 PM   #9
Grider Pirate OP
Oddometer: 1,669
All new. BTW, I followed yer link. You're selling real PARTS again?? Whoohoo!
Old 03-14-2011, 08:20 PM   #10
Grider Pirate OP
Oddometer: 1,669
I like that, but I don't have any such devices.
Old 03-14-2011, 08:59 PM   #11
bmweuro
Mad Scientist
bmweuro's Avatar
Oddometer: 2,966
The only other thing I can think of is throttle shaft o-rings. Yep back in the biz. I missed you guys to much!
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 03-14-2011, 09:24 PM   #12
Grider Pirate OP
Oddometer: 1,669
Also new.
Epoxy is setting now. Didn't have any JB weld, so I used the epoxy that I use for glider repairs.
Old 03-14-2011, 09:33 PM   #13
bmweuro
Mad Scientist
bmweuro's Avatar
Oddometer: 2,966
Also new.
The epoxy will yellow over time but it is easier to remove and re-due than JB weld.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 03-15-2011, 07:27 AM   #14
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 1,602
BING bling.
A Euro.
boxerboy81 is offline   Reply With Quote
Old 03-15-2011, 11:09 AM   #15
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 7,356
I've epoxied them from the inside, but that's a bit tricky avoiding any buildup on the slide walls - definitely a no-no. I like wrench's idea.
Times are GMT -7.   It's 01:12 PM.
