Old 03-17-2011, 07:58 PM   #46
HighFive
Never Tap-Out
HighFive's Avatar
Oddometer: 2,774
Hhhhmmmm....I could get interested in this deal, pending what you come up with. List me as a potential.
That "KTM" comment is very interesting thought, as well. Hope grandpa does it and keeps us tightly posted on the result.
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 03-17-2011, 08:36 PM   #47
GeckoRider
GeckoRider's Avatar
Location: Oakland, CA, USA, Thrid Rock from the Star Sol
Oddometer: 447
Put me down as a potential buyer depending on final cost.
F800GS Mag/Black 2009 "Faucon GriS"
Farkles; Garmin GPSMap478 in a TT cradle, Airhawk seatpad, Pivot Pegs, SW-motech bars, MOD skid plate, Altrider headlight guard, HDB handguards, Maier Mudguard.
GeckoRider is offline   Reply With Quote
Old 03-18-2011, 07:43 AM   #48
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,248
Originally Posted by grandpa_ken View Post
Well on second thought......take me off the “want list” for now.
I was in the shop looking at the brake line on my '07 KTM 450 EXC and I think two of these lines will fit the F800GS with no additional parts required. The KTM lines are about 50” long with 10mm banjos on each end. If I use one line on each caliper and connect them to the ABS output with the double-long banjo screw from the left caliper and use the single banjo bolt from the ABS connector at the left caliper. The 2007 450EXC is street legal so the brake lines must be DOT approved and have the stiff outer cover where it runs up the fork. The KTM lines are about $70 each ($140 pair). This will eliminate the tee and short connecting hose. I need to make some final measurements.
I think that is prety much how Bartron ended up doing his in his high fender swap. Ask him how its working.
I chose to go with the tee set up and extra line to minimize the flexing and twisting of the lines. By using just the two lines, they have to both move for suspension compression and steering. There's not a lot of free space for them to clear all the instruments, fairing, forks, triple clamps and such in there, so using the three lines and the tee means that the two long lines only have to move for suspension, the third line only has to flex for steering. Changing the fourth line from the M/C to the steering head was just to make it clear the others. Long term might be the tell on this which way is best. I wanted to limit the stress and chaffing on the lines as much as possible for durability and longevity so the extra cost will hopefully prove worthwhile.
MCMXCIVRS is offline   Reply With Quote
Old 03-18-2011, 08:57 AM   #49
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,248
I've spoken to Mathias at Spiegler to help him get this kit sorted. I am going to be giving him all the additional info for the setup and some photos to help him see what I've done. He is thinking that he would like to do this as a complete kit ready to install with no further fabrication or pieces needing to be sourced. That would mean the braket for the tee and the clamps to secure the lines at the fork protectors as part of it all.
He also suggested that it would be very helpful to have someone in the area near their location in Dayton, Ohio with an F800GS that could work with them first hand to make sure they get everything right. This might be an opportunity for someone to save some work and possibly some cost.
Old 03-18-2011, 09:08 AM   #50
dendrophobe
Motorbike Junky
dendrophobe's Avatar
Oddometer: 859
Hmm, I'm only seven hours away from there... If nobody's closer, it might be worth a drive to help out and get some money back!
Doug
Semper Fi
2009 BMW F800GS, Olive Drab
2006 Ducati Sport 1000, Black
Custom built Ducati GT1000 Scrambler, Red
dendrophobe is offline   Reply With Quote
Old 03-18-2011, 09:32 AM   #51
dendrophobe
Motorbike Junky
Oddometer: 859
As far as brake line clamps/guides for the fork guards, I wonder if something like this would work?
You'd have to figure out a way to mount it to the fork guard (or get another set of fork guards with mounting points already on them...) but it might be a decent solution.
Doug
Semper Fi
Old 03-18-2011, 09:34 AM   #52
OlyRider
Oddometer: 1,297
Spiegler
Damn it, I *knew* I shouldn't have moved from Dayton to Seattle!!!
(But it was 1967, after all....)
Olyrider
Ob-la-di...Ob-la-da
OlyRider is offline   Reply With Quote
Old 03-18-2011, 09:40 AM   #53
OlyRider
Oddometer: 1,297
Couldn't we just use a piece of angle aluminum to create the necessary bracket? Seems like that would work on the bikes where folks are using the original fender as fork guards.
Olyrider
Ob-la-di...Ob-la-da
Old 03-18-2011, 09:45 AM   #54
dendrophobe
Motorbike Junky
Oddometer: 859
I'm sure we could, that seems like the easiest solution. I plan on installing my new lines next week, so I'll give that a try and report back.
Doug
Semper Fi
Old 03-18-2011, 10:34 AM   #55
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,248
Exactly what I was thinking.
Old 03-18-2011, 07:52 PM   #56
toro618
toro618's Avatar
Oddometer: 987
Abs
I don't know the exact mechanics of the ABS pump and pressure on this bike, but does making the lines longer, shorter, or adding another line in any way alter how the ABS functions? In other words, did BMW design the ABS to work with a specific brake line lengths?
I keep looking at the whole design and still don't understand why they did not stick with a more simple setup. Someone please enlighten me if I am missing something here.
toro618 is offline   Reply With Quote
Old 03-19-2011, 01:37 PM   #57
bodhizafa
How hard can it be?
bodhizafa's Avatar
Oddometer: 652
Add me to the "maybe" list I'd like to eventually have a high fender too.
I'll have one if you do.....
bodhizafa is offline   Reply With Quote
Old 03-21-2011, 07:37 AM   #58
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,248
I've had a couple requests for pictures of my line set up and the bracket for the Tee, so here you go.
Old 03-21-2011, 07:55 AM   #59
selecus
selecus's Avatar
Oddometer: 80
Please put me down as a maybe, depends on price point...
selecus is offline   Reply With Quote
Old 03-21-2011, 08:21 AM   #60
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
I might be interested depending on the price.
I need to look at the routing of mine today.
Question: the kit will be just a replacement from ABS pump to calipers right? That and a few adel clamps should do it.
Like I posted earlier this is a typical fix on sport bikes. Remove crossover and run two new lines direct to the master cylinder. Not sure how the ABS pump plays into it but guessing that running two lines from wherever the main line out to caliper instead of crossover would do it. :??
Ride more, bark less
Gangplank is offline   Reply With Quote
Times are GMT -7.   It's 08:12 PM.
