Old 03-11-2011, 06:22 PM   #1
mfp4073 OP
mfp4073's Avatar
Oddometer: 2,538
/6 /7 front disk interchangeability?
Is the only difference in the disk that the one on my bike is solid and the others are drilled? Could I take a drilled one and install it with no other mods?
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is offline   Reply With Quote
Old 03-11-2011, 06:28 PM   #2
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
Yes.
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 03-11-2011, 06:30 PM   #3
mfp4073 OP
mfp4073's Avatar
Oddometer: 2,538
Originally Posted by mymindsok View Post
Yes.
Thanks! Suspected, but wanted to double check.
Old 03-11-2011, 09:37 PM   #4
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,651
I don't know if it's a /6 or /7, but I replaced my solid rotor on my '74 R90/6 with a drilled one. No mods necessary.
crazydrummerdude is offline   Reply With Quote
Old 03-12-2011, 10:07 AM   #5
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,570
All 74-84 front and rear brake discs are interchangeable except the R65, R80ST and R80GS which look the same but they have a deeper dish(more offset).
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 03-16-2011, 10:22 PM   #6
supershaft
because I can
Oddometer: 9,116
What about the discs that have a slightly different diameter such as I have seen and are in the Hanes and Clymer manuals? 264 versus 260mm diameter. I have run into bikes that had the wrong disc diameter on them. I just looked at the ETK and apparently BMW is listing the same PN for a lot of bikes that use to have diffent diameter brakes if I remember right. What's up with that? Right now I just put some EBC 602's on a R65LS and the button washers are hitting the brake pads. The pad looks like it will hit its backing on the buttons as the pad wears. Whats up with the new PN's all being the same? Does anybody kow?
Old 03-16-2011, 11:00 PM   #7
Boxer Metal
Mad Scientist
Oddometer: 3,570
There was no difference in diameters from 74-84. I spent years staring at hundreds of used ones from all of the pre 84 bikes.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 03-17-2011, 10:08 AM   #8
supershaft
because I can
Oddometer: 9,116
Not according to my memory and the Clymer and Haynes manuals.
They are hard to tell apart being just 4mm difference. I could always tell by how the brake pad rode on the disc. The wrong size disc would have the pad slightly missing the disc one way or the other depending on the mismatch.
Old 03-17-2011, 02:35 PM   #9
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
SS: D
Do you have parts we can compare? That might help...
Hawkdude
Old 03-17-2011, 03:19 PM   #10
supershaft
because I can
Oddometer: 9,116
Compare what? Some are 260mm. Some are 264mm. That's the difference. They're in the old micro fische. They're in the old parts books. They're in the manuals. Why aren't they in the new ETK?
Times are GMT -7.   It's 08:04 AM.
