Old 12-27-2013, 01:22 PM   #151
Brtp4 OP
Powdercoat it.
Brtp4's Avatar
Oddometer: 1,990
Originally Posted by dlhuddie View Post
How does the Balance compare to the Forma Boulder? Forma seems a little more feature-rich, with a little more ankle protection. But everyone raves about the Gaerne's. Thoughts anyone?
Though the Forma Boulder has some detail in the ankle area, it is only a stamping in the leather, not a hard insert. So, the ankle area is similar in support to the Balance:
The Formas are slightly stiffer in the sole area, and a little taller. Because of the additional shaft height, they are a little more supportive rotationally. They do have a few more features plastic heel counter, bi-compound sole, a real burn guard, etc.
The Gaernes look awesome, but frankly, some (me) like the look of the Formas even better. The brown color is darker, and the bi-compound black sole with the red insert looks more rugged. Plus they come in black:
You are correct, they have a few more features. That said, they are still roughly similar to each other functionally. Both are great. FWIW I sold my original test pair of Boulders to a friend that has been wearing them for at least two years without any issues.
Hope that helps!!
BP
BP
Atomic Moto.com
Bend, OR
Brtp4 is offline   Reply With Quote
Old 12-27-2013, 04:38 PM   #152
NortwestRider
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 4,209
After about 3,000 miles of everyday use. ( about 50% of those miles in the wet. ) I still LOVE my balance oiled boots.The ONLY thing I would change would be to add a shift pad on the left boot, but other than that they are great boots.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Old 12-27-2013, 05:24 PM   #153
kag
Wander Lust
kag's Avatar
Oddometer: 1,809
Just sold my Balanced Oil
So will be looking for some Formas
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 12-27-2013, 08:34 PM   #154
dlhuddie
Oddometer: 58
thanks y'all! Now if I can just scrape together the cash on my student budget…
dlhuddie is offline   Reply With Quote
Old 01-12-2014, 07:54 PM   #155
dlhuddie
Oddometer: 58
Hi Brian, thanks for all the great info you put on here.
I tried on a pair of the Balance Pro-Techs and they pinch in on the lateral malleolus - my outer ankle - where that stitch is sewn between the bottom and middle buckle. (I've read of some others having the same problem w/ the Gaerne's.) I think it may be b/c my heel is kind of skinny creating some extra room so that the leather caves in there where it's intended to just flex. Having worn a lot of full-grain leather hiking boots I suspect the problem would just get worse with time as the crease continues to break in.
Looking at the Forma's, they don't have that stitching and the bottom buckle looks further down on the foot so as to create a wider space between the buckles. I'm wondering if you think that would alleviate or altogether keep the leather from creasing?
Hope that helps!!
BP
Old 01-12-2014, 08:24 PM   #156
hanksmybuddy
hanksmybuddy's Avatar
Oddometer: 410
BoooooYaaaaaa....... they're still out there. Custom boot made especially for me by Atomic-Moto. No, they are not for sale!
hanksmybuddy is offline   Reply With Quote
Old 01-13-2014, 08:35 AM   #157
Brtp4 OP
Powdercoat it.
Brtp4's Avatar
Oddometer: 1,990
Dear gawd. Please help me un-see those.
BP
BP
Atomic Moto.com
Bend, OR
Old 01-13-2014, 09:24 AM   #158
dlhuddie
Oddometer: 58
I posted this follow-up question about the Forma's but I don't know if you saw it so just wanted to repost it and get your thoughts if you have time…
Old 01-13-2014, 12:33 PM   #159
Brtp4 OP
Powdercoat it.
Brtp4's Avatar
Oddometer: 1,990
Hello dhuddie.
Understand your explanation. That creasing can take place for several reasons: design, how the boots are stored, or excess room in the ankle. I have not seen that issue occur with frequency on the Balance, only in a few small cases. For some reason, I have a gut level feeling that I have seen it more with the Pro Tech than the Oiled. Not really sure, but this would make sense because 1. the leather is stiffer on the Pro Tech, and 2. because the WP liner on the Oiled is thicker, adds some padding, and cushions the inside more.
Because that area is leather, it will probably go away after time. I bought 2 pairs of Gaerne hiking boots that flat out hurt when I got them. But because they were special ordered from Italy, I was stuck with them (yes, it happens to me too). Because my, ahem, "business partner" frequently pointed out my less than ideal judgement, I stubbornly continued to wear them, but because they were 100% leather, with no plastic, eventually they became comfortable.
That said, any time you have a significant pinch point, if you can, you should move on to the next pair or model. Usually it just creates a bruise, and makes the boot unwearable. Again, I think Pro-techs are one of the better boots for comfort, but you were right to move past them.
Regarding the Forma Boulders: they are more slim through the ankle, which will reduce the possibility of pinch points. Frankly the Boulders are slimmer through the ankle, which you can visibly see in photos. Additionally, the leather is a softer oil-tanned one, which should also help. Lastly, there is a PVC insert on the outer side at the flex point, specifically to mitigate what you experienced. FYI the Balance USED to have this also, but they removed it on the last redesign.
Anyway, I am not able to be 100% certain, but I think you will be better off with the Boulders.
http://www.atomic-moto.com/Forma-Bou...ots_p_792.html
Sorry for the long reply. Really, I just wanted to vent my $400 worth of Gaerne hiking boots story.
Hope that helps.
BP
BP
Atomic Moto.com
Bend, OR
Old 01-13-2014, 01:02 PM   #160
dlhuddie
Oddometer: 58
Hello dhuddie.
Hope that helps.
BP
Not at all! Thanks for the in-depth reply! I'll be ordering a pair of Forma's from your site momentarily.
Old 01-18-2014, 05:53 PM   #161
kag
Wander Lust
kag's Avatar
Oddometer: 1,809
I sold my Gaerne Balanced Oils and bought the Forma Adventures......love them already. The Forma 46EU size fit my 11W foot extremely well
Old 01-18-2014, 05:59 PM   #162
NortwestRider
Oddometer: 4,209
Still love my balances !!
2,000 miles of SEATTLE weather and still the most comfy pair of boots I have ever owned !!!.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 01-23-2014, 05:49 PM   #163
Savk
Oddometer: 13
I just bought a pair of Gaerne balance oiled boots but haven't gotten them yet. Do most of you guys use riding pants that tuck in or wear over the boot pants? Which seem most comfortable with these boots?
I'll be using the for trials bike and mx enduro riding...
Savk is offline   Reply With Quote
Old 01-23-2014, 06:00 PM   #164
telejojo
telejojo's Avatar
Oddometer: 479
I just tuck in but I guess it don't matter....................
08Concours,09KLR, 80CBX 79KZ1300 , 2013 Zuma 50 04 V-Strom,1974 KZ900 04 ZRX,09 KYMCO 500
telejojo is offline   Reply With Quote
Old 01-23-2014, 06:02 PM   #165
Mr Dual Sport
Roamer
Mr Dual Sport's Avatar
Oddometer: 1,962
I wear over the boot pants with mine. Helps keep water from getting in the top of the boot.
I've had mine for 2 years and over 20,000 miles of abuse. Still very waterproof and feel like slippers! Love them!
Kinda stink though...
Brian can attest to that!
You're never lost till you run out of gas....
Mr Dual Sport screwed with this post 01-23-2014 at 06:13 PM
Mr Dual Sport is offline   Reply With Quote
Times are GMT -7.   It's 10:16 PM.
