Old 09-11-2012, 08:26 AM   #1
Mayhem_Unlimited OP
Oddometer: 52
Kouba links on a KTM 625 SXC - how to file swing arm or spring for clearance?
Last night, I installed the Kouba lowering links on my 2004 KTM 625 SXC. It was pretty straightforward. I'm now at the point where I need to either file down the rear spring or file down (about .040") the swing arm to gain clearance between the swingarm and spring. I have a few questions:
1. Should I file down the spring or the swing arm?
2. How do you guys get in there with everything assembled? Or does this require disassembling a portion of the rear suspension?
3. What's the preferred tool for the job? Is a metal file sufficient?
Thanks for any help. I'm such a n00b. :(
Mayhem_Unlimited is offline   Reply With Quote
Old 09-13-2012, 09:07 PM   #2
Mayhem_Unlimited OP
Oddometer: 52
Anyone?
Old 09-14-2012, 01:11 AM   #3
timg
timg's Avatar
Oddometer: 37
Hi, been there, done that. Take it off the swing arm - it's soft aluminium. Use a file. Doesn't need much. Chalk the area and file until the chalk doesn't get worn of. Cheers
If its not Orange, its a Lemon!
timg is offline   Reply With Quote
Old 09-14-2012, 03:07 AM   #4
Mayhem_Unlimited OP
Oddometer: 52
Thanks, Timg.
Times are GMT -7.   It's 06:30 AM.
