Old 03-24-2011, 10:47 AM   #1
LukasM OP
Oddometer: 4,923
How long to remove and replace the engine?
Title says it all, just wondering if anybody has already done it...
Proud member of the HUSABERG ADVENTURE TEAM!
'12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6
Old 03-24-2011, 02:21 PM   #2
JoelWisman
JoelWisman's Avatar
Oddometer: 1,353
Took about 4 hours, not hard on this bike.
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250
I love and miss you Jeneca and I'm sorry.
JoelWisman is offline   Reply With Quote
Old 03-25-2011, 10:54 AM   #3
LukasM OP
Oddometer: 4,923
Thanks Joel, that's good to know. Is there anything special to watch out for?
I already swapped the subframe on this bike and was surprised how straight-forward it was.
Cheers,
Lukas
Old 03-25-2011, 12:50 PM   #4
JoelWisman
JoelWisman's Avatar
Oddometer: 1,353
Nearly every bolt that attaches the engine to the frame has a spacer, they are all different, record locations as you remove them.
The engine is sorta heavy, help from a friend and support from a jack is better then catching it with your toe.
The engine likes to cock and scratch things, tape on frame tubes is advised.
Electrical connectors aren't all keyed. There are neumerous combinations that will fit together but only one combination is advised :)
Nothing special, just normal disassembly recording and caution.
What has you dropping the motor if I may ask?
Old 05-05-2011, 11:17 AM   #5
LukasM OP
Oddometer: 4,923
Hi Joel,
Sorry for the late reply, must have missed your last answer.
The reason I was asking is because I bought (another) crashed F650 twin, and it has a damaged engine. It was hit hard from the right side so that case and stator are busted, and I suspect that the crank might be damaged, too. I have a F8 engine that I am going to swap in for the time being, and will then take the original apart to see how the crank is doing. Hopefully it can be fixed, otherwise I'll have at least have a spare clutch.
Old 05-05-2011, 11:20 AM   #6
markymcd
markymcd's Avatar
Oddometer: 877
while we're talking engines, do you think it's possible to swap out the cams on the 650twin and get the same horsepower as the 800? I'm sure it's insanely more complicated but... maybe not?
cheers,
Mark
www.adventuredecals.com
markymcd is offline   Reply With Quote
Old 05-05-2011, 11:29 AM   #7
LukasM OP
Oddometer: 4,923
cheers,
Mark
Hey Mark,
Shouldn't be a big deal at all, the cams are in fact the only different part between both engines. And the programming of the BMS-K, that's why I was I trying to figure out if I can simply put the F8 map on the F650 computer here: http://www.advrider.com/forums/showt...2#post15834372
The only question is the timing chain, I don't see a separate rivet link listed on the microfiche. Maybe there is enough room to take the cams out with the tensioner removed?
Lukas
Old 05-05-2011, 11:49 AM   #8
markymcd
markymcd's Avatar
Oddometer: 877
kind of what I would have thought.
I also wonder what would happen / not happen without changing the mapping.
Old 05-05-2011, 12:54 PM   #9
huckleberry
BACK ROAD BOMBER
huckleberry's Avatar
Oddometer: 1,105
perhaps it would be more like the 8 map to run on regular?
“An adventure is misery and discomfort, relived in the safety of reminiscence.” Marco Polo
09 F 650 GS twin
XR 400
Beta Techno
huckleberry is offline   Reply With Quote
Times are GMT -7.   It's 03:03 AM.
