Old 06-13-2011, 04:07 PM   #181
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 3,814
Originally Posted by bgoodsoil View Post
All you need is a SWAT sticker and you'd pass for law enforcement Good luck!
South American law enforcement????
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 06-22-2011, 08:47 PM   #182
StevieG
English Muffin
StevieG's Avatar
Oddometer: 53
Thread hijack here; I have the old charts & maps from a year ago, and Sam just sent me these new ones for the western sections. Question is why has he scrubbed Hancock, Monarch, Tomichi passes from Colorado altogether? On the old maps he advised not attempting them on a big dual-sport. I'd hate to miss them for no reason...
Originally Posted by Abenteuerfahrer View Post
Hi One Less Harley...
Oregon, Nevada, Colorado, New Mexico....are now available as updated versions and with coordinates. Tenn, Miss, Ark should be available when you are redy to leave. Oklahoma is pretty straight forward....Utah should be done by now. ALL WITH COORDINATES. You can get them from SAM.
Example:
NEVADA
OLD............................................... .............................. NEW
'Never judge a man until you walk a mile in his shoes - that way when you judge him, you'll be a mile away and have his shoes'
StevieG is offline   Reply With Quote
Old 06-23-2011, 09:13 AM   #183
Abenteuerfahrer
Deaf on Wheels
Abenteuerfahrer's Avatar
Oddometer: 2,049
Hancock; Monarch; Tomichi Passes...?
(2010)...Sam went up there on these passes with another guy in a 4x4 truck to re-map/update the routes and I guess saw how gnarly these passes have become. Me thinks.... that he believes that these passes tax Man n' Machine too much.
So I guess he sees no need to take the risks on Hancock or Tomichi ? Better to have a whole trip than a partial one because something gets messed up on the bike or rider there. I think the alternate is a good choice just as high up there and scenic…..
Sam was young then when he scaled these passes...he has matured and aged a bit. Different thoughts..!! You can still challenge them yourself...and tell us about it. Good luck and ride safe, ride far.
Cheers
Abenteuerfahrer is offline   Reply With Quote
Old 06-23-2011, 11:58 AM   #184
Sourjon
TAT'erd
Sourjon's Avatar
Oddometer: 1,816
They're easier on a bike than in a 4x4. I'd ride either ten times to avoid a mile of sand. Just me...
John
Sourjon is offline   Reply With Quote
Old 06-26-2011, 05:39 PM   #185
Motor 1
Motor 1's Avatar
Oddometer: 494
StevieG, I have done those passes back in '06 in mid September. The ice in between the rocks was the worst of it. It is a bit of a challenge but was worth it to me. Hancock was closed for a while. I think part of the road let loose and it was deemed 'unsafe'!
Brevity is the essence of wit
Traveling with the circus
Tattered Old Men
Ruta del Cakebaker
Motor 1 is offline   Reply With Quote
Old 06-27-2011, 01:39 PM   #186
StevieG
English Muffin
StevieG's Avatar
Oddometer: 53
Yeah but u have big kahoona's!! I'm gonna give it a go. Worst that happens is I have to turn around and re-route. Well, actually worst is I could fall off and break an ankle THats not even funny.
Still hope to meet u out there, flying to CO Sept 1st. Keep in touch.
(thread hijack over, carry on...)
Old 09-23-2011, 09:05 PM   #187
nick_rhinocycles
nick_rhinocycles's Avatar
Oddometer: 476
Originally Posted by One Less Harley View Post
Mounted the TCK 80 to the front. Got the rear one off, but the rim lock had a
Here's a shot of the tools to be carried-
1) gloves,2) tire levers and axle nut tool,3) tire pump, 4) rope, 5) front wheel bearings, 6) oil filter and o-rings, 7) nuts/bolts/fuses, 8) chain links, 9) spoke wrench & front axle nut tool, 10) patch kit, 11) wire ties, 12) electrical tape,
13) tool roll, misc, allen wrenches, combination wrenches, sockets, pliers, air gauge, test light, crescent wrench, screw driver bits, carb jets
14) Sven 15" saw and sheath, 15) wire, 16) 1/4" T wrench w/ bailing wire wraped, 17) chain tool, 18) hammer and epoxy, 19) jumper cables, 20) throttle and clutch cable, 21) coil, 22) front brake pads, 23) spark plug, 14T counter shaft sprocket, 24) 30mm counter shaft socket, and extension/adapters, 25) foot levers
Not pictured are the front and rear inner tubes, small cans of chain lube and air filter oil, and 1st aid kit
Loving your reports! Ok of the list above what would you have left behind?
Nick
nick_rhinocycles is offline   Reply With Quote
Old 09-25-2011, 06:08 PM   #188
One Less Harley OP
Oddometer: 3,814
Nick
None of it!! Those were needed tools, didn't use but you never can tell.I ended up sending back some clothes, one pair of zip off paints and a t-shirt, and sent roll charts back mid way, the ones already used.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 03-08-2012, 10:25 AM   #189
One Less Harley OP
Oddometer: 3,814
I had the idiot light and had my doubts about if the different colors were actually correct to the voltage. I found this offered on ADV. It will give the exact voltage so there won't be guess work to the volts. One problem is in decent sun light the volts aren't visible.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 03-10-2012 at 09:04 AM
Old 04-14-2012, 06:20 PM   #190
One Less Harley OP
Oddometer: 3,814
OK the volt meter, has been pulled, not good in any kind of light even when shaded behind the fairing. Going back to the idiot light.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 09-18-2012, 03:19 PM   #191
One Less Harley OP
Oddometer: 3,814
No longer TAT prep related, more of just another change to the bike.
Recently purchased a FMF Q4, and needed to make a few mods, for heat shielding.
1st to remove the old brackets from the original pipe and muffler and weld them onto the new pipes.
Tabs in place-
Shield in place-
Stage one complete-
Stage Two-
Heat shroud for the Muffler- stainless steel guard-
1st drilled for the top 3/16" closed rivets-
Then set the top three, in place and drilled the lower three.
Shield set in place, checking that the holes all line up.
Shield riveted on-
Final Touches-
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 09-18-2012 at 03:41 PM
Times are GMT -7.   It's 03:24 AM.
