Old 03-24-2011, 08:05 PM   #1
Snowbound OP
Oddometer: 877
1150 GS Fuel Filter
Searched this forem .I have an external fuel filter from the OP .Is there a thread on this . What have you done ?
BMWMOA
ABC
Pikes Peak BMW Riders
2001 R 1150 GS 1978 R 100RS 1976 XT-500 1964 CL-72
1955 CJ-5 1975 F-250 Highboy
Snowbound is offline   Reply With Quote
Old 03-24-2011, 08:51 PM   #2
vintagerider
vintagerider's Avatar
Oddometer: 1,962
Originally Posted by Snowbound View Post
Searched this forum .I have an external fuel filter from the OP .Is there a thread on this . What have you done ?
Nothing remarkable. It may help you to sketch the fuel flow circuit so that you can identify the combination tank vent/overflow circuit, the fuel distributor, pressure feed line from pump out put, pressure regulator, and fuel return aka "by-pass". The boxers employ a run of the mill fuel by-pass/fuel return fuel injection system. Pressure is maintained at apox 43 1/2 psi at the injectors. The factory regulator opens as a relief valve and excess flow and pressure return to the tank via the fuel return line.
Any external fuel filter rated for fuel injection will work. You may wish to stop by Hasenwerk's thread. He has the Fram G6563 installed. This filter will locate nicely in the steer head above the horn. External filters are fine as long as they are safely installed using high grade fuel line and proper clamps.
vintagerider is offline   Reply With Quote
Times are GMT -7.   It's 06:40 AM.
