Old 03-25-2011, 04:42 PM   #1
davemon OP
High Speed Airhead
Oddometer: 113
No starter action on Airhead
1978 R100S Replaced the starter in August with a nippondense and put on an Enduralast charging system this January. Has run since then great putting on over 2K miles with no problems. Went to start and nothing to the starter and the idiot lights dim and the tach needle bounces. Pulled the starter works good, checked the wiring looks good replaced the starter relay and same thing when hitting the starter button. Ideas anyone? Dave
davemon is offline   Reply With Quote
Old 03-25-2011, 04:49 PM   #2
Grider Pirate
Grider Pirate's Avatar
Oddometer: 1,686
It's the battery
Please don't tell Mom I'm a pilot. She thinks I play piano in a whorehouse.
http://griderpirate.smugmug.com/
http://www.youtube.com/my_videos?feature=mhum
Grider Pirate is offline   Reply With Quote
Old 03-25-2011, 04:52 PM   #3
fishkens
Further...
Oddometer: 5,147
What's the health of the battery? Put the voltmeter on it to see what happens to the voltage when you hit the starter button. It shouldn't drop below 10 or so (and that's borderline)
How's the ground cable? Clean and tight at both ends? Does it heat up at the lugs at all when you hit the starter button? They've been known to corrode at the lugs and you'll get this symptom. If you have a jumper cable, jump the ground on the battery to a known good ground on the engine.
Likewise, check the pos cable to the starter (I'm assuming that you've looked at that since you had the stater out.
That's a start.
fishkens is offline   Reply With Quote
Old 03-25-2011, 04:54 PM   #4
blaine.hale
blaine.hale's Avatar
Oddometer: 3,070
Sounds like the battery to me
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 03-25-2011, 04:56 PM   #5
Mista Vern
Knows all - tells some.
Mista Vern's Avatar
Oddometer: 16,128
Originally Posted by Grider Pirate View Post
It's the battery
It's always the battery.
"The turd follows the fart as surely as the rain follows the plow."
Emily Bronte
Mista Vern is offline   Reply With Quote
Old 03-25-2011, 05:19 PM   #6
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,472
Yes, that's what ADV has taught me, it's always the battery!!
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Old 03-26-2011, 08:41 AM   #7
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,419
I had a recent problem where the starter wouldn't work...clack, clack, clack.
Battery tested ok. Bike wouldn't jump from the car to the bike battery or even directly to the starter.
Replaced the starter. The old starter worked fine on the bench. The new starter worked better in the bike.
It's not "always" the battery, but it's the first place to check.
boxerboy81 is offline   Reply With Quote
Old 03-26-2011, 09:05 AM   #8
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,083
Another place to look is the large lead that attaches to the right side of the diode board. Not sure why it can cause symptoms like this, but it's the only other place I'd think to check. It's gotta be one of the already mentioned possibilities or this.
BTW, test the starter in place by running jumper cables directly from the battery to it. Attach the ground lead to the starter's mounting lug. Use a jumper to bridge 12V to the solenoid connection. If it cranks as it should this tells you the starter and battery are working properly.
Old 03-29-2011, 08:49 AM   #9
davemon OP
High Speed Airhead
Oddometer: 113
Thanks for all the info picking up a new battery tonight and will let you know.
Blue Skies and cool rides
Old 03-29-2011, 06:02 PM   #10
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,181
I this thread.
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 03-31-2011, 05:52 AM   #11
davemon OP
High Speed Airhead
Oddometer: 113
Dropped in a new Westco from Bommbars and all is working well. Worked out some wiring issues at the starter relay.Installed a DF005 relay from Advanced Auto that cost $1.49 so cheap got a spare for the tool bag and a couple for the shop, serviced the starter, so should be ready for some warm weather adventures.
Thanks for the help
Dave
Times are GMT -7.   It's 02:15 AM.
