11-03-2011, 12:30 AM
#166 |
Butler Maps
Oddometer: 14,444
R1100RT had plastic tanks way back when.
DOT requirement does not say metal tank, only it does not permeate gas vapors through the plastic. RT tank has an extra to seal layer to make it like a metal tank.
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
11-03-2011, 03:50 AM
#167 |
Oddometer: 874
11-03-2011, 08:26 AM
#168 |
EX-MX Adv Tourist
Oddometer: 94
Aleeoop's reply to Gnarly Adventurer
Hey Gnarly,
Yes, the tail/stop lights on the Pelican cases do work and they are BRIGHT. I found them at "etrailer.com" for around $30. The wires have simple trailer plug connectors for quick disconnects for case removal. The instrument cluster is made from a piece of 1/8" thick aluminum plate, cut to the desired shape and drilled for the desired switches and mounts. I used a RAM articulated arm and attached their handlebar clamp on the bottom end and mounted it to the middle of the handlebar between the bar clamps. I used another RAM mount for attaching the instrument cluster plate which consists of a 2.5" round disk with a 1/2" ball molded to it for attaching to the articulating arm. The disk sticks to the underside of the instrument cluster plate with double side sticky antenna mount material (usually used for mounting antennas to glass on cop cars). With the articulating arm, you can move it and tilt it as needed for sun glare, placement etc. another one could be built but it would need to be drilled for switches and whatever else would be mounted to it and a drill press should be used for clean accurate holes.
Aleeoop70 |
11-03-2011, 08:46 AM
#169 |
Oddometer: 1,023
Aleeoop, I'm seriously impressed with your setup. It's a fantastic looking (and probably running!) bike for all terrains and topos, that must have taken you a while to get just right!
I may need to copy you if/when I get my own DR650.
Sarah 2012 R1200GS Rallye - Gypsy 2003 R1150GSA with DMC sidecar Ask A Self-Publisher "Life is like riding a motorcycle: to keep your balance, you must keep moving." |
11-03-2011, 08:59 AM
#170 | |
Big Bearded Boy
Oddometer: 1,071
RAM mount is a good idea for the instrument cluster. I have that same thing for my RAM Medium-Wide Aqua box here (holds my Droid X and headphone amp): ![]() I'm intimidating by the wiring, but eventually i'm going to do away with my keyed ignition system, add a vapor speedo/tach unit, and build a dash with switches for everything I want to control. The ability to run lower wattage lights during the day as running lights is smart - more juice to run heated gear.
Current: '07 B1250. ![]() Former Steeds: '99 DR650, '02 DR650, '09 DL650 First Trip on 2 Wheels. 10,000 miles. 21 years old. |
11-03-2011, 10:59 AM
#171 |
EX-MX Adv Tourist
Oddometer: 94
Aleeoop's dash/control center
Gnarly,
I have what appears to be the same Ram arm and handlebar clamp you used for your GPS mount for mounting my dash panel. The only difference is that for mounting the dash plate, I used one of the RAM 2.5" disks with a molded in 1/2" ball mount. The flat surface of the disk is stuck to the dash plate with double side sticky antenna mount material (similar to servo tape/two sided foam tape). I also used a separate Ram arm to mount my GPS. You can see the Garmin mount on the left side of the controls (without the GPS in it). Didn't want to smash it up in the event of a "digger". Fell once in deep sand but the GPS mount wasn't touched.
Aleeoop70 Aleeoop70 screwed with this post 11-03-2011 at 12:41 PM Reason: to hide license # |
11-03-2011, 12:26 PM
#172 | |
Butler Maps
Oddometer: 14,444
do those tank bags get in the way of your knees?
that's right where i squeeze my tank w/ my legs at times for control. Quote:
11-03-2011, 12:32 PM
#173 | |
fNg
Oddometer: 779
leverage is king.
2006 DR650SE, daily commuter + a StripleR and a bunch of 2 strokes that you dont want to read about. :) http://www.advrider.com/forums/showthread.php?t=829203 |
11-03-2011, 12:51 PM
#174 |
EX-MX Adv Tourist
Oddometer: 94
Aleeoop's DR650
The tank saddle bags are from Cycle Pro and work great. They were taped to hold them forward, away from my knees because the glue that sticks the velcro panels for the bags to the side of the tank failed after 100 miles of rain. The bags do need to be held forward. I'm going to make some web straps to fix that and then they will stay out of the way of my knees. The duct tape did work in a pinch though.
The big zip ties used to hold the fuel cell mount in place are handcuffs and never budged during 2,000 plus miles on the road and a couple hundred miles off road on the White Rim Trail in Moab which was an excellent test. A more permanent mounting system could be made but the handcuffs work great and are easily removed with side cutters. You just need a new set of cuffs for the next trip.
Aleeoop70 |
11-03-2011, 12:53 PM
#175 |
EX-MX Adv Tourist
Oddometer: 94
Aleeoop's DR
The handcuffs.
Aleeoop70 |
11-03-2011, 12:58 PM
#176 |
EX-MX Adv Tourist
Oddometer: 94
Aleeoop's DR650
I got rear ended by a little old lady while sitting at a stop sign which resulted in a broken arm. Since then, I have installed flashing stop lights and stop/tail lights on my Pelican cases. I also wear a neon yellow jacket on the street.
Aleeoop70 |
11-03-2011, 02:29 PM
#177 |
Big Bearded Boy
Oddometer: 1,071
Yeah, my knees do come up about halfway into the bags. Didn't think about it when I attached the velcro. Haven't loaded them up with anything more than my wallet and cell phone prior to now, so I can still squeeze with my knees if needed. If I wanted to really load them up for a trip i'd need to move them forward. Too bad they look good as they are....
11-03-2011, 05:48 PM
#178 |
Oddometer: 9
Smart move. Definition of insanity/lack of intelligence? Doing the same thing repeatedly and expecting a different result.
11-03-2011, 07:03 PM
#179 | |
plainsman
Oddometer: 89,127
I had a 14-tooth on the DR, but I swapped it out for a 16-tooth. I think I'm going to like it.
_______ |
11-03-2011, 08:29 PM
#180 |
Oddometer: 737
bump??
2000 Suzuki DR650 - 790cc Big bore kit, V-Strom seat, Warp 9 Supermoto rims, TM-40 carb. 1985 Yamaha CA50 - My Hot Rod 2009 Piaggio BV-250 - Escusi, Babba be bo-bee |
