Old 03-28-2011, 06:31 AM   #1
charlie264 OP
charlie264's Avatar
Oddometer: 8,270
K60 Scout???
The Heidenau K60 Scout I ordered just arrived, I was expecting the tyre with the tread pattern with more central rubber for the road, advertise as a K60 Scout on Heidenau. I got this, can any shed some light, does the tread pattern differ with size of the tyre or have I got an older tread pattern?
Old 03-28-2011, 06:32 AM   #2
charlie264 OP
charlie264's Avatar
Oddometer: 8,270
This is what I thought I was getting....
Old 03-28-2011, 06:50 AM   #3
randel
randel's Avatar
Oddometer: 315
What size did you order? I've heard that 150 has new pattern while 140 has still old pattern, both are called K60 Scout.
950SuperEnduroR
Beyond clouds 2011
Beyond arctic circle 2010
randel is offline   Reply With Quote
Old 03-28-2011, 06:55 AM   #4
codys
Lost in the Vizcaino
codys's Avatar
Oddometer: 1,249
Is there a date stamp on the sidewall??
If that's a 150 tire then I bet you got an old design tire. I think I read the new rubber compound doesn't wear as good as the old so the center stripe is there for increased durability. That old tire is like the Mefo that everyone over hear has and is ga ga over.
The 140 doesn't have the strip( I believe ) if you went for a smaller tire.
05 ktm 950 adventure
11 Husqvarna TE630
codys is offline   Reply With Quote
Old 03-28-2011, 07:07 AM   #5
charlie264 OP
charlie264's Avatar
Oddometer: 8,270
Cheers guys, its a 140. So the older pattern tyre is better wearing? The reason I went for the Scout over a Sahara was the bigger central rubber pattern.
If it's better wearing, I'll keep it, if not bugger. Anyhow the pattern thats advertised on Heidenau web site is the tyre I thought I was getting.
There are some numbers on the side, whether they are date's.... one says 4910?
charlie264 screwed with this post 03-28-2011 at 07:17 AM
Old 03-28-2011, 07:26 AM   #6
Garp
Garp's Avatar
Oddometer: 2,445
49th week of 2010, so the tail end of last year.
Garp is offline   Reply With Quote
Old 03-28-2011, 09:05 AM   #7
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
The 140/80-17 Scout/Enduro is different (as you now know) than the 150/70-17 and different still from the 150/70-18 Scout/Enduro. The 150 17" and 18" are similar in the pattern, the 18" center rib is recessed ~1cm below the lug surface. Not only are the patterns different the compound is too between the 17" and 18"s. At present, the 150/70-17 is not available in the US. Is it available in the UK/Europe?
BTW, Im running the 150/70-18 on my 950. Presently really like it, time will tell how well it wears, has ~500 miles on it.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 03-28-2011, 09:34 AM   #8
charlie264 OP
charlie264's Avatar
Oddometer: 8,270
Cheers H2W. Here’s an idea Heidenau, K60, K61, K62 etc...Get the picture.
I know I know, “enduro” tyres are such a compromise but in yesteryear off road tyres were as hard as nails if a little skatey in the wet.
I should have bought shares in a gumtree, this SE’s appetite is busting my wallet, and all I want is a tyre I can get 5 k miles out of, is that too much to ask?
Old 03-28-2011, 09:47 AM   #9
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
I hear you, there seems to be several different versions within the same designation, it gets confusing. Especially when the cover picture shows the "neu" pattern. The one pictured as the overall general on Heidenau's website is the 150/70-18, however the 130-140/80-18 are not, nor are the 150/70-17 same. In addition to the differences between the rear tires, the 19" front is different than the 21" front. Personally I prefer the 19" pattern, however I have a hot knife that can solve that pretty quickly
You must have a 17"/19" rim combo on the SE?
Head2Wind screwed with this post 03-28-2011 at 10:00 AM
Old 03-28-2011, 10:49 AM   #10
charlie264 OP
charlie264's Avatar
Oddometer: 8,270
Quicky....? The tyre has two red dots on the sidewall, is that the same as one red or yellow dot? Lightest part of the tyre?
Old 03-28-2011, 10:57 AM   #11
SOILMAN
DIRT-HOG
SOILMAN's Avatar
Oddometer: 479
Attachment 255978
That looks like a MEFO
SOILMAN is offline   Reply With Quote
Old 03-28-2011, 10:58 AM   #12
charlie264 OP
charlie264's Avatar
Oddometer: 8,270
Same company.
http://www.mefo-shop.de/Reifen/Enduro_Strasse/
charlie264 screwed with this post 03-28-2011 at 11:08 AM
Old 03-28-2011, 11:06 AM   #13
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
Yes.
Old 03-28-2011, 11:14 AM   #14
charlie264 OP
charlie264's Avatar
Oddometer: 8,270
Originally Posted by Head2Wind View Post
Yes.
Old 03-28-2011, 12:35 PM   #15
dmn0507
dmn0507's Avatar
Oddometer: 352
K60 scout looks like this:
I have one at home, pic found here:
http://www.advrider.com/forums/showt...568324&page=27
dmn0507 is offline   Reply With Quote
Times are GMT -7.   It's 05:05 PM.
