Old 03-28-2011, 09:02 AM   #1
JJJZJ OP
JJJZJ's Avatar
Oddometer: 187
Slow speed vibration on deceleration
I cant get the search to work here, but has anyone ever run into the problem I am having where their bike(mine is a 2010 F800) develops a slow speed vibration on deceleration? It seems to occur from 25mph - 18mph. I can feel it run through the entire bike. It has me slightly worried that the problem might the wheel bearings possibly as I am slightly paranoid thanks to this forum
It might occur at acceleration, but I cant tell with the engine doing its thing...
Initially I thought it might be the tires I put on, but it feels more pronounced as time goes on. Its not bad to live with, but I just want to avoid catastrophe if possible. The bike has about 12k miles on it right now.
Thanks for any ideas!
2010 BMW F800 GS.
2003 DRZ400s.
Pics: http://jjjzj.smugmug.com/
JJJZJ is offline   Reply With Quote
Old 03-28-2011, 10:23 AM   #2
OldPete
Be aware
OldPete's Avatar
Oddometer: 5,662
Just a thought.
I've had several bikes do this but at a slightly higher decell speed, 45-20.
Carefully try this.
With a very, very light hold of the hand grips... Is the steering head shaking upon decell?
If so, adjust or replace the steering head bearings.
If the stock bearings are ball, replace with tapered roller if avalible.
Inexpensive bearings are sourced from China, like all balls.
Use quality bearings like USA, German, etc. sourced.
OldPete is offline   Reply With Quote
Old 03-28-2011, 05:57 PM   #3
johnparjr
johnparjr's Avatar
Oddometer: 203
Mine does that on my new shinko's from 20-25mph then goes away for me I just figured it's the block pattern on the tires.
johnparjr is offline   Reply With Quote
Old 03-28-2011, 06:44 PM   #4
JJJZJ OP
JJJZJ's Avatar
Oddometer: 187
I cant remember if mine did it with the stock pirelli scorpion tires, but i have Shinkos on there currently as well. I think they are the 705s?
2010 BMW F800 GS.
2003 DRZ400s.
Old 03-28-2011, 07:35 PM   #5
bloochdog
Itinerant jackass
bloochdog's Avatar
Oddometer: 5,921
My 800 tended to have that deceleration vibration ending in an increasing front wheel wobble. It seemed to worsen when heavily laden and with top box.
Tangohopper's R1200gs adventure does the same thing.
" You need a new sig line."- H14
"I despise you and want my refrigerator magnet back!" - VB Divers ex-girlfriend
bloochdog is offline   Reply With Quote
Old 03-30-2011, 11:11 PM   #6
CheckerdD
CheckerdD's Avatar
Oddometer: 1,305
Put the bike up on the centerstand; add enough weight to the rear wheel to lift the front tire/wheel off the ground and spin the wheel. Does the wheel, tire or brake rotor seem to wobble. That can point to the one causing the problem Re the steering head bearing, in my experience is unless it gets notchy if you slowly move the bars side to side, with the wheel up, it's something else.
Note if the tire is out of round that ought to be visible when spinning the wheel. I have never had a new tire go out of round, but I never bought one made in China either. Dave
Pavement! We don't need no stinkin pavement.
CheckerdD is offline   Reply With Quote
Old 03-30-2011, 11:17 PM   #7
johnparjr
johnparjr's Avatar
Oddometer: 203
Shinko's are S Korean not Chinese
Old 03-30-2011, 11:33 PM   #8
Tosh Togo
Oddometer: 1,594
Who cares?...the bike's German.
The way thngs are going, it'll be a part of southern China in a few years anyway.
Tosh Togo is offline   Reply With Quote
Old 03-31-2011, 04:02 AM   #9
swimmonkey
JMS
Oddometer: 54
Vibes
Have the same thing when I run TKC 80's. When I run Metzler Tourance, it goes away.
swimmonkey is offline   Reply With Quote
Old 04-04-2011, 02:52 PM   #10
KuRi
Oddometer: 23
I have a similar problem on mine. I notice it too when keeping the speed at ~20km/h, with a very small gas usage.
The thing is that I notice it only on the left side of the bike :(
KuRi is offline   Reply With Quote
Old 04-05-2011, 05:37 PM   #11
johnparjr
johnparjr's Avatar
Oddometer: 203
Mine is starting to fade so Im assuming it's the block pattern of the tire which is now getting worn down after 800 or so miles the vibration is almost gone.
Old 04-05-2011, 05:38 PM   #12
johnparjr
johnparjr's Avatar
Oddometer: 203
Because everyone likes to Bash shinko tires even though they have probably never had a pair on.
Old 04-05-2011, 06:01 PM   #13
JJJZJ OP
JJJZJ's Avatar
Oddometer: 187
They were cheap and there are so many mixed reviews on here that I gave them a whirl.
3500 miles later with a trip to Baja and rear ending a chevy pickup under their belt with no flats or failures, Im sufficiently impressed.
Wish I could say the same for those junk ass Pirelli(read: fancy Italian) tires that came on the bike.
Ill keep an eye on the vibrations, but will just assume its due to the tires tread pattern.
2010 BMW F800 GS.
2003 DRZ400s.
Times are GMT -7.   It's 03:52 AM.
