Old 03-23-2013, 12:09 PM   #421
Kelly_O
Oddometer: 320
Thanks for the taillight tips. I found them to be very illuminating! I'll look into them when the snow stops.
Someone is wanting to buy a TT600 rear wheel in the general FM section, if anyone has one. Good Day, Kelly.
Kelly_O is offline   Reply With Quote
Old 03-24-2013, 01:36 PM   #422
oliwoof
Pyrenees - paradise
Oddometer: 12
no spark TT600R
I have no spark on my 1998 Belgarda and suspect a faulty CDI unit, does anyone know if anything else bar Denso 071000-1211 / Yam no. 5CH-01 will fit? Does anyone know how to test the unit?
Before it failed completely the bike was missing/hesitating very occasionally and the symptoms were not unlike fuel starvation or something electrical breaking down under load, she would run on a throttle very slightly open but then cut out on anything more than that. This happened three times in about 600 miles. Came home with the bike running perfectly, washed her the next day and failed to start a week later.
Any help much appreciated:)
Have done all the obvious checks like coil, kill switch, side stand switch and stripped back the loom for problems in the steering head area. Every connector has been apart and cleaned. Only area I haven't looked at is the mag.
oliwoof is offline   Reply With Quote
Old 03-25-2013, 12:21 PM   #423
Lc8er
Oddometer: 165
I had the exact same bike until it was sadly stolen last year, the red white and black beast, great bike. I had a very similar problem with no spark and asked at a Yamaha garage, spoke to one of the mechanics thinking it was the cdi as well. He said I had gotten something in the fuel and fouled the plug, I realized it might have been from a jerry can on a camping trip...
Drain the carb, fit new plug and boom, started first kick and really surprised me. I ran a few tanks of carby / engine cleaner and then fitted a fuel filter, I highly recommend one. Any trouble starting then adjust the auto decomp, hold the lever just off max and adjust the cable, it slowly stretches and gets harder to start.
Another great tip I learned from at a guy at a garage when I flooded the engine which I sometimes did was- fuel tap off, lower the bike on it's side to drain the carb, with the ignition OFF and the throttle wide open give the bike one light kick over to clear the cylinder then start as normal. Always remember to NEVER EVER touch the throttle when starting or it could kick back and hurt you allot. And never start with the fuel tap on, turn it on when it starts, I used to regularly adjust the idle for cold mornings.
Hope this helps, good luck!
Lc8er is offline   Reply With Quote
Old 03-26-2013, 12:48 AM   #424
oliwoof
Pyrenees - paradise
Oddometer: 12
Thank you for that but I think my problem is different, I can kick it over and hold the plug lead without a tingle, definitely no spark.:(
Old 03-26-2013, 01:00 PM   #425
karlsons
Oddometer: 18
hi guys, anyone familiar with hpi cdi units?
karlsons is offline   Reply With Quote
Old 04-02-2013, 12:57 PM   #426
Gian
dreamer
Gian's Avatar
Oddometer: 1,231
Originally Posted by Gian View Post
Well, I found many info about this interesting bike. I hope to see one of this very soon, in the meantime I got myself this Belgarda TTS/TTE mix
when finished, it will look a little bit closer to that wonderful "prototype"
a few changes
and a bit dirty after a first offroad ride
Gian is offline   Reply With Quote
Old 04-02-2013, 01:27 PM   #427
karlsons
Oddometer: 18
to be installed
Old 04-02-2013, 09:14 PM   #428
BIG ED XT FAN
BIG ED XT FAN's Avatar
Oddometer: 1,251
a few changes
You got one good TT600 there!! E-Start, upside down forks, Discs brakes front and rear, Long-range Fuel tank. Looks like a Street-Plate too!! My 59X is not even in the same league!!!
BIG ED XT FAN is offline   Reply With Quote
Old 04-02-2013, 09:16 PM   #429
BIG ED XT FAN
Oddometer: 1,251
Originally Posted by karlsons View Post
to be installed
What year TT600 is this??
Old 04-02-2013, 11:04 PM   #430
karlsons
Oddometer: 18
1995.
Old 04-03-2013, 12:28 AM   #431
stteve
Oddometer: 371
I assume you checked the keyswitch, and the sparkplug?
My TTR had a problem with the stator, switched that with a stator from a 1996 XT600K, and is was fine again.
Now-1977 YAMAHA XT500 - 1996 HONDA XR400R - 1991 YAMAHA XTZ660
Sold-1983 XT250/1991 TT350/1996 TT600E/1985 XT350/1999 TT600R/2002 TT600R
stteve is offline   Reply With Quote
Old 04-03-2013, 12:58 AM   #432
Fantuzzi
Fantuzzi's Avatar
Oddometer: 180
a few changes
Beautiful bike
Is this an original Belgarda Rally fuel tank?
Belgarda Yamaha TTR600
Yamaha XT660Z Tenere
Fantuzzi is offline   Reply With Quote
Old 04-03-2013, 01:44 AM   #433
Gian
dreamer
Gian's Avatar
Oddometer: 1,231
Originally Posted by Fantuzzi View Post
Beautiful bike
No, it was made by Rigo Moto in Milan, who also prepared a few bike for Belgarda for the Nevada Rally '95 and the Australian Safari '96.
Old 04-03-2013, 01:45 AM   #434
Gian
dreamer
Gian's Avatar
Oddometer: 1,231
@Stteve: have you seen my PM? (many thanks in advance!)
Old 04-03-2013, 02:01 AM   #435
Gian
dreamer
Gian's Avatar
Oddometer: 1,231
Well this is e belgarda TT600E with Belgarda TT600S suspension and kickstarter, and of course here in Italy all these bikes were street legal, the 59X too, which has much more power than this one and was totally made in Japan
Times are GMT -7.   It's 03:47 PM.
