Old 06-22-2014, 06:04 PM   #1
Wrebit OP
Oddometer: 45
Question red powder sticking to the chain
Since a few days, there's a red powder sticking on the chain.
Looks like its coming of the countershaft sprocket.
Anyone knows what this is ?
Wrebit screwed with this post 06-22-2014 at 06:10 PM
Wrebit is offline   Reply With Quote
Old 06-22-2014, 06:10 PM   #2
SoCaliDave
Oddometer: 37
Sounds like rust to me.
SoCaliDave is offline   Reply With Quote
Old 06-22-2014, 06:12 PM   #3
Wrebit OP
Oddometer: 45
No I doubt it ...
Its really red,...
Old 06-22-2014, 06:18 PM   #4
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,064
It's rust.
Pull the front sprocket off and lube the splines while you still can.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is online now   Reply With Quote
Old 06-22-2014, 06:19 PM   #5
jengel451
1 Cool MotherF#$cker
Oddometer: 789
What they said.
jengel451 is offline   Reply With Quote
Old 06-22-2014, 07:34 PM   #6
SOP Dirt-Rider
SOP Dirt-Rider's Avatar
Oddometer: 668
Rust from the chain itself. Once the o rings start leaking/harden the inner pins rust. Not being an ass, but maybe more chain maintenance is required? Most folks think of chain maintenance as lubing, but in all reality we are cleaning the o rings to keep them pliable to maintain a seal for the sealed/lubricated pins. Chain wax is great for street use but in off road/dusty locations the wax seals the grit to the o rings, helping rush the demise of the chain. Internet lore says WD40 wrecks chains, I beg to differ and use it as part of my almost daily off road maintenance to remove the grit.
My advice is buy a new, quality chain, check both sprockets for condition and pay more attention to your chain.
www.pssor.com
SOP Dirt-Rider is offline   Reply With Quote
Old 06-22-2014, 08:52 PM   #7
DonHS
Oddometer: 82
Yup. What SOP said. I had exactly the same issue with the "red powder". Despite what I thought was "fairly regular" chain maintenance. I wasn't being diligent enough. (And I was using wax lube.) Several links finally seized. Replaced the OEM chain with a DID plus "very regular" maintenance, no red powder since.
DonHS is offline   Reply With Quote
Old 06-22-2014, 09:19 PM   #8
Kiwi Tinkerer
Ross
Kiwi Tinkerer's Avatar
Oddometer: 383
what they said
Yep, clean with white spirits when I can. Lube before/after every ride. I use renthal chain lube. Generous oiling, then whipe off excess. Chain's last very well if you look after them.
And YES, the main thing to lube is the o-rings.
Kiwi Tinkerer is offline   Reply With Quote
Old 06-23-2014, 01:58 PM   #9
eddyturn
Wannabe
Oddometer: 1,888
Last time I had that rest dust I was in SE Utah.
All things being equal... fat people use more soap
eddyturn is offline   Reply With Quote
Old 06-23-2014, 04:21 PM   #10
The Island
Im lost.
The Island's Avatar
Oddometer: 219
Thats what my crappy oem chain looked like. I thought it was rust, too.
The Island is offline   Reply With Quote
Old 06-23-2014, 08:31 PM   #11
DonHS
Oddometer: 82
Yeah. I'd read a few posts on the crappy chain. Wasn't sure though... Did mention "the red dust" once to the dealer when I had it in for service. He didn't have an answer for it...
Anyway, new chain is sooo much smoother.
Old 06-23-2014, 09:30 PM   #12
gianni1951
gianni1951's Avatar
Oddometer: 62
It's only rust. You have to improve maintenance.
Have a look here : http://www.reginachain.it/uso_e_manu...how_to03.shtml
gianni1951 screwed with this post 06-23-2014 at 09:31 PM Reason: Subscription
gianni1951 is offline   Reply With Quote
Old 06-24-2014, 07:34 AM   #13
GREWUPIN_D11
GREWUPIN_D11
GREWUPIN_D11's Avatar
Oddometer: 86
Powdery red dust is the classic, definitive symptom of 'fretting corrosion'. See http://en.m.wikipedia.org/wiki/Fretting Note that this red dust is harder than steel, and VERY abrasive. Per the wiki article, it's technically not rust.
Reaver correctly notes the most common source, motion between sprocket and countershaft splines. In this particular case, based on the localized nature of the red dust shown in the photo, seems SOP may be correct in the diagnosis of some failed O-rings on the chain.
GREWUPIN_D11 screwed with this post 06-24-2014 at 07:57 AM
GREWUPIN_D11 is offline   Reply With Quote
Old 06-24-2014, 09:26 AM   #14
SOP Dirt-Rider
Oddometer: 668
Something else, it isn't salvageable. No amount of love will revive that chain. It will eventually fail and biding by Murphys law, when you need it most.
www.pssor.com
Old 06-24-2014, 01:39 PM   #15
KSO
Grab a Handfull
KSO's Avatar
Oddometer: 110
After every off road adventure I use Keosene to get all the nasty shit out of there. Then on a regular basis so Im not putting lube on the black gum that builds up. I'll even carry it with me if I have along ways to travel after the off road adventure.
Chance favors the prepared mind.
KSO screwed with this post 06-25-2014 at 03:57 AM
KSO is offline   Reply With Quote
Times are GMT -7.   It's 05:09 PM.
