Old 02-01-2005, 04:02 PM   #16
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,634
All these posts, and I might of missed it, but did no one suggest a fucking sidestand?
I'm 6'3", and it was still the first thing I put on the bike. Hell, I bought it before I even put down the cash for the bike itself.
After that, for me it was bar risers, rallye pegs, proper bark busters, headlight protector, tank bag, luggage, and gps.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 02-01-2005, 04:24 PM   #17
Barry
Just Beastly
Barry's Avatar
Oddometer: 7,318
Will a sidestand bolt on my 2001 AND let me retain the centerstand ?
Thanks,
Barry
Tail of the Dragon at Deal's Gap... Avoid it now, do a trackday.
Do not do business with Myrtle West Cycle... Not a reputable vendor by a long shot.
Barry is offline   Reply With Quote
Old 02-01-2005, 04:37 PM   #18
BoulderBoy
BoulderBoy's Avatar
Oddometer: 206
rally pegs...
Anyone measure the stock pegs vs. the rally pegs?
BoulderBoy is offline   Reply With Quote
Old 02-01-2005, 04:47 PM   #19
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Go straight to Hell, do not pass Go....
Originally Posted by creeper
FCR carb
Creep
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 02-01-2005, 04:48 PM   #20
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,235
screw all y'all and yer bloomin' excessories...
all i want is more time to ride the biatch!
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 02-01-2005, 04:51 PM   #21
meat popsicle
Ignostic
Oddometer: 14,235
pssst - its a test...
Old 02-01-2005, 05:03 PM   #22
Rad
Just me
Rad's Avatar
Oddometer: 12,175
I found I had to re-jet, open the air box and put on a new SXC (I think?)can before it was even rideable, due to vibes, with my Calif version.
Nut'n else for me was a must do, just all wanna do's:
Rally pegs
Rear side rack for soft panniers
Soft panniers
“Vibration” proof Dual Star tail light bulb
Dual Star mirrors
Bar risers
GPS wired in and mounted in the shell above the speedo
Fender tube bag
Better grips
Better off road tires
Motion Pro jet tool (extra jets) for on board tool kit
Tool box replaced air canister in back
Chain breaker in tool kit with spare master link to replace any broken link
Heavy duty tubes with sealant for off road work
Bar mount map pocket
50 gallon drum of Loctite
Gonna do:
Scott’s steering damper plus Loaded’s mount, when he gets it done
Re-worked front forks and rear shock
Fastway pegs
Rad is offline   Reply With Quote
Old 02-01-2005, 05:10 PM   #23
Nom de Guerre
Nom de Guerre's Avatar
Oddometer: 2,034
Thanks,
Barry
Pretty sure the answer is no for the KTM sidestand for the '01. I have an '02, and the KTM one is an either or deal with regard to the centerstand.
However, SW Moto Tech makes a sidestand that does work in conjunction with the centerstand. It's a simple bolt on deal (no mods necessary), and I have one on order (they're on backorder at the moment). They're $99.00
http://twistedthrottle.com/trade/productview/328/162/ for gray
or
http://twistedthrottle.com/trade/productview/329/162/ for silver
Nom de Guerre is offline   Reply With Quote
Old 02-01-2005, 06:45 PM   #24
SoilSampleDave
Oddometer: 1,987
New muff
Everyone loves a new muff, but after a while, you feel the urge for some strange...
Don't drive like my brother!
"Comparison is the thief of joy" - TR (the good Roosevelt)
'14 690R
SoilSampleDave is offline   Reply With Quote
Old 02-01-2005, 06:54 PM   #25
SoilSampleDave
Oddometer: 1,987
What year, and... as I will go into excruciatingly painful detail, I'll do this tonight. M-kay?
B-bye
Well, seeing as how you're going to be doing all that typing anyway...the '02 I picked up Sunday is bone stock. I want to add the open airbox cover, rejet, and open up the stock exhaust. I must be the dumbest sonofabitch around, because I searched the forum and couldn't find a thread covering modifying the stock exhaust, and jetting to go with it.
Love ya - mean it.
'14 690R
Old 02-01-2005, 06:59 PM   #26
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
As promised...
OK… here we go. As I have never seen a 2005 640 Adventure, we are, for purposes of clarity, going to assume it is the same as ’03 - ’04.
1. Main jet.
You should have a 152.5 as stock. Remove this (the bowl cap is a 17mm as I recall) and install a 160 main jet; pay attention to the spacer that comes out with the jet. This is only a starting point, you may go up or down 1 or even 2 sizes for your conditions. They are the same main jets used in Mikuni HSR carburetors for Harley-Davidsons, which makes them available at just about any H-D dealer or custom shop.
2. Removing the vacuum cap from the carburetor.
Remove the fairing and fuel tank, you don’t have to remove the dash, simply tie the “ears” up to the handlebars.
Remove the 2 screws holding the cap on while lightly holding the cap down. Remove the cap, and gently remove the vacuum piston/slide assembly. Remove the spring and push the needle up and out the top of the slide.
Note the position of the parts; refer to your owners parts catalog for correct position.
2.a. Remove the clip (do this over a large table, maybe with a white bath towel on it… just in case you “loose” the clip) from what is I assume will be the 3rd position from the top and relocate it to the 4th position.
2.b. Obtain a drill bit, preferably a longish one, .110” to.125” in diameter and drill out the two vacuum ports in the slide, on either side of the needle hole, to the drill diameter. Drilling from the top is slightly better because the surface inside the slide is square to the ports; the outside has a radius that requires you to have a bit of drilling talent.
2.c. That’s all the mods… you can reassemble the carb. You can use your finger to help guide the needle back into the needle jet in the carb body, then insert the spring. Be careful when reinstalling the cap that you do not pinch or distort the vacuum diaphragm. Don’t over-tighten the cap screws.
3. The air box is easy… either buy or make a copy of the KTM high flow air box side cover. Do not remove the snorkel on top the air box… unless you plan to run a 41mm Keihin FCR and a complete Akrapovic system, or it’s equivalent.
Here is one I "hacked" out of some 1.5mm carbon fiber plate... actually cost more to make this than go buy a KTM one.
4. Stock muffler.
Remove the Supertrapp spark arrestor discs and end cap. Obtain a 1.5” hole saw (might be 1.375"... but I think it's a 1.5" ), find a wooden dowel that fits tightly in the center hole of the mechanical baffle… you need this to help center the drill. (Vrago’s bitchin’ idea )
Core out the baffle tube with the hole saw. A tube of about 6 inches in length comes out when the hole saw cut thru.
Reinstall the discs… the bike probably comes with 10 – 12 discs stock… you can add up to around 16 to suit your personal sound meter, but as I recall, 10 – 12 is more than enough for most folks.
A bike that sounds good is great… a bike that deafens citizens is not so good.
That’s it… I hope.
Creeper
Quick addendum...
While you have the tank off... this is a good time to remove the stock evap cannister and hoses. Just run a regular gas cap vent hose into the hole in the fork stem nut... just like 99.9% of the dirt bikes, or get a spiffy one way valve from e-line... or whatever.
E-line one way vent
So... how's tricks?
creeper screwed with this post 02-01-2005 at 07:58 PM
creeper is offline   Reply With Quote
Old 02-01-2005, 07:01 PM   #27
GODSPEED
finger lickin' good
GODSPEED's Avatar
Oddometer: 2,077
Love ya - mean it.
Hey SSD, check this out: Stock Exhaust Mod With help from Creep.
Godspeed
I'd rather do it than watch it.
Those of you with spouse and SO's know this already, but man give them a big hug, and don't take anything foregranted. - MACK RIP
When 51% of the grasshoppers vote, the ants are screwed.
http://godspeed.smugmug.com/Motorcycles
GODSPEED is offline   Reply With Quote
Old 02-01-2005, 07:06 PM   #28
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Love ya - mean it.
Your mods are almost identical. You start out with a 142.5 main jet, so you'll be going to a 152.5 as a starting point. If anything, it may be a bit rich.
Some folks with pre '03 LC4s have felt the need to richen the pilot circuit. This can be done by installing a richer fuel jet or a leaner air jet. You will have to decide for yourself if this is really needed.
Creeper
So... how's tricks?
Old 02-01-2005, 07:53 PM   #29
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
The first time I did one was at Passy and Vrago's Sacto Tech Day on ex-GSpilot, now LC4pilot's '02 Adventure. Quick and easy it was... and it sounded bitchin' too!
Vrago's brilliant idea to stuff a wooden dowel into the hole as a guide for the centering drill bit was ah... brilliant!
So... how's tricks?
Old 02-01-2005, 08:06 PM   #30
Walker Sky Ranch OP
Riderdown.org
Walker Sky Ranch's Avatar
Oddometer: 1,346
Originally Posted by darmahman
PICS PLEASE !
COMING, COMING SOON!!
Les Walker
www.RiderDown.org
http://www.advrider.com/forums/showthread.php?t=304490
The RiderDown Foundation is a non-profit organization dedicated to helping responsible off road motorcyclists and ATV racers who have been injured while riding. Proceeds are used to provide assistance to the riders and their families when faced with medical expenses and related issues.
Walker Sky Ranch is offline   Reply With Quote
Times are GMT -7.   It's 12:29 AM.
