Old 04-07-2011, 09:57 AM   #1
Yakima OP
Whee! Wee Strom
Yakima's Avatar
Oddometer: 328
DOT 3 compatible grease for caliper pistons?
I'm rebuilding my calipers (1985 Honda CB650SC) and usually install the pistons using brake fluid as lubricant. (Manual says DOT 3 or 4; I'm using 3 and am happy with it. Not interested in exploring the virtues of 4, 5.1 or 5)
These pistons are very tight, and I've damaged a seal while pressing them in.
I've read of using grease on the piston, a light, light, coating. But: what grease? Permetex makes something compatible with brake fluid. I tried it with an Amsoil all purpose grease I use for most everything: it dissolved into the fluid, turning the fluid pink. Not sure what it did to the fluid.
I've drained everything. Got new seals. Ready to install, but don't want to damage any more seals.
Grease recommendations? Other advice?
Many thanks.
Yakima is offline   Reply With Quote
Old 04-07-2011, 10:31 AM   #2
JSharp
Oddometer: 270
I've used this -
http://www.crcindustries.com/ei/cont...x?S=Y&PN=05351
Lots of auto parts stores carry it and it's available in small tubes. One should be plenty for what you're doing.
2011 Ninja 1000
JSharp is offline   Reply With Quote
Old 04-07-2011, 11:16 AM   #3
Bill the Bong
Supern00ba
Bill the Bong's Avatar
Oddometer: 951
Red rubber grease for hydraulic connections
KTM 690 R - "Its just a little crush..."
Bill the Bong is offline   Reply With Quote
Old 04-07-2011, 11:31 AM   #4
Yakima OP
Whee! Wee Strom
Yakima's Avatar
Oddometer: 328
Great! Thanks, guys.
Old 04-07-2011, 12:37 PM   #5
showkey
Oddometer: 1,897
Originally Posted by These pistons are very tight, and I've damaged a seal while pressing them in.
[COLOR=yellow
Other advice?[/COLOR]
Many thanks.
If everything is right the piston should install with hand pressure.
Remember the seal is the part that will cause the piston to retact after brake application, the piston must move smoothly in the bore or the brakes will drag or hang.
1982 CX500 Turbo ,2006 ST1300, 2012 NC700X
1971 CT90,1981 C70, 1986 TRX 250,
1993 TRX300 4X4, 2001 TRX500 4x4, 1987 XR250L
showkey is online now   Reply With Quote
Old 04-07-2011, 12:50 PM   #6
Tosh Togo
Oddometer: 1,594
What he said. I've found that lubing the new seal with DOT-whatever before installing it into the caliper's bore helps a lot... apparently by being lubricated the seal can more easily move into its' slot, and let the piston slide by.
Btw-use absolutely no "grease" of any kind, not even a little bit, unless it says that it's designed to be used in a hydraulic brake system...if it was made from oil, it can result in the seals in the brake cylinders swelling to the pont of sticking.
Tosh Togo is offline   Reply With Quote
Old 04-07-2011, 01:05 PM   #7
big-t
Oddometer: 486
Been using this stuff for many years.Its thicker and slicker than brake fluid......and harder to find.
http://www.autoparts2020.com/rsdev/p...T_HDR_ID=40378
big-t is offline   Reply With Quote
Old 04-15-2011, 05:22 PM   #8
Tepi
Tepi's Avatar
Oddometer: 543
I use PBR Rubber grease, its made for brake rubbers. Then I also use a brake grease for the slidebushing if applicable, its made for that, ATE makes it.
Tepi is offline   Reply With Quote
Old 04-15-2011, 05:45 PM   #9
indr
Oddometer: 1,197
Offtopic noob question. What's the purpose of rebuilding calipers? Clean out the built up grime and replace the cylinders that push on the pads? How often should this be done?
indr is offline   Reply With Quote
Old 04-15-2011, 06:23 PM   #10
EduardoMas
Spartan Overlander
EduardoMas's Avatar
Oddometer: 404
Yakima,
Using brake fluid to lubricate the seal and dust seal before installation is all that is needed. The pots should press in by hand, unless you are still connected to the rest of the brake system (I am sure you are not).
Lightly wet the perimeter of the pot before installing. If it does not press in with your fingers something is off. A larger section seal, a twisted seal, swapped seal for dust seal sound like possible culprits.
My experience is only with XRR and KLR. I spec hundreds of seals, nothing in this size range needs much force to compress (even 28%) when lubricated.
The caliper greases are for pins and items other than the piston seals. These greases and the brake fluids do not contact each other AFAIK.
Cheers!
Eduardo.
Eduardo
XR650R
KTM300
Simplicity is the ultimate sophistication.
EduardoMas is offline   Reply With Quote
Old 04-15-2011, 09:22 PM   #11
hpsVFR
Hoosier Daddy
hpsVFR's Avatar
Oddometer: 1,340
Yes, to clean out accumulated grime, and to allow inspection and refurbishment or replacement of pistons and seals. Refurbishment generally amounts to a good washing/cleaning, and the use of crocus cloth (a fine abrasive paper/cloth product) on your pistons, replacement of seals (you've got them out anyway, and they're cheap), and perhaps attention to your bleed nipples (replace chewed up ones, swap speedbleeders (tm) in, seal the threads).
You should do it often enough, that is, inspect your calipers and decide whether or not they look goopy/gunky enough that you're willing to empty the system of fluid and re-fill/flush it. This will happen much more often in environments where salt corrosion is an issue than in other environments, as I understand it.
hpsVFR is offline   Reply With Quote
Old 04-16-2011, 09:35 AM   #12
bwringer
Gimpy, Yet Alacritous
bwringer's Avatar
Oddometer: 2,168
I suspect you're trying to use an aftermarket kit. The aftermarket brake rebuild kits commonly sold for vintage bikes are nothing but dangerous low-rent junk. (I'm lookin' at YOU, K&L. ) Shame on the retailers who peddle this evil crap.
Get OEM parts from your favorite Honda parts source, and everything will go together like buttuh. And it will actually work properly afterwards. Plus, the OEM kits are a much better deal -- they usually include new pistons for close to the same price as the shoddy seal-only aftermarket kits.
Do NOT contaminate your brake system with grease or anything else. Fresh brake fluid is all the lubricant you need. If you have to force anything, something is wrong.
Many people in this thread are ignorant or aren't paying attention, and are recommending the "brake grease" that is used on the slide pins. This is VERY dangerous. Again, NEVER, EVER, EVER apply ANYTHING besides fresh, clean brake fluid to the innards of your brake system.
1983 Suzuki GS850G, Cosmic Blue
2002 Suzuki Vstrom DL1000, Midnight Blue
2005 Kawasaki KLR685 - Turd II.2, The ReReTurdening
"Do not crinkle your food wrappers loudly. Be considerate to others, or I will bite your torso and give you a disease."
bwringer is offline   Reply With Quote
Old 04-17-2011, 07:23 AM   #13
Yakima OP
Whee! Wee Strom
Yakima's Avatar
Oddometer: 328
I'm cheap. Not frugal. Cheap.
Ordered OEM caliper seals/dust seals. Two weeks ago. Should be in-hand tomorrow.
I'll try assembling first using only brake fluid. Coat everything in that nasty stuff.
Parts are CLEAN, new stainless lines are on, bike is running sweet (although she burns oil. Rings next winter, methinks.)
Thanks, guys, for all the suggestions and advice.
Old 04-17-2011, 10:14 AM   #14
C Squared
Now with TURBO!
C Squared's Avatar
Oddometer: 6,971
Everything stated below
If it goes together tight, it will not work! (won't release)
This info brought to you by an ASE certified person
I can explain it to you, but, I can't understand it for you.
C Squared is online now   Reply With Quote
Old 04-19-2011, 12:56 PM   #15
Yakima OP
Whee! Wee Strom
Yakima's Avatar
Oddometer: 328
Got all the pistons in. Three went in with MUCH pushing with fingers/thumb. The fourth required a tap with a hammer.
I know, I know: should go in with hand pressure only.
Uhn uh. didna happen.
Once in, I mounted the calipers without pads. Filled and bled. Pumped the pistons out. Pushed them in. Installed pads.
It was late when I finished. Torque things up today and perhaps go out this evening for a bit.
Oops. Nope. Work tonight.
Thanks for the help, one and all.
Times are GMT -7.   It's 10:50 AM.
