Old 04-19-2011, 01:05 PM   #16
chammyman
Oddometer: 421
brake fluid only.
Anyway out of interest where on earth can you find DOT 3 fluid? You'd need a time machine here. DOT 3 last sold probably 20 years ago here.
1984 Honda CBX 750 FE
1985 Honda VF 750 F
1987 Honda CBR 1000 F
1988 Honda CB 350 SG
chammyman is offline   Reply With Quote
Old 04-19-2011, 09:00 PM   #17
C Squared
Now with TURBO!
C Squared's Avatar
Oddometer: 6,985
Originally Posted by chammyman View Post
brake fluid only.
DOT 3 is still the norm here.... 4 is happening more and 5 is race...
I can explain it to you, but, I can't understand it for you.
C Squared is offline   Reply With Quote
Old 04-19-2011, 09:30 PM   #18
Beezer
Oddometer: 5,659
Parker O Ring Lube... that's what it's called. It's the slickest stuff on rubber ever. Made by Parker, the leading name in O ring things. I have used it on everything bike, auto & aircraft with no problems. Great stuff.
Beezer is offline   Reply With Quote
Old 12-08-2012, 09:54 AM   #19
simonpig
packin' heat
simonpig's Avatar
Oddometer: 1,094
I am rebuilding the front brake caliper on an XT225. I ordered the Yamaha OEM front brake rebuild kit (includes both pistons, 4 seals) and it came with a little packet of pink grease. Nowhere in the rebuild manual does it state to grease anything and as mention before, I was only planning on using the brake fluid to lubricate it.
What is Yamaha trying to tell me by including a packet of this pink grease?
simonpig is offline   Reply With Quote
Old 12-08-2012, 10:41 AM   #20
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,546
They may be trying to tell you that leaving brake fluid residues outside of the seal may not be such a good idea.It will attract moisture and may cause corrosion later on. Use the grease and use some on the external dust seal if you have one of them.
Parker O-ring lube....right on their product specs it says that it shouldn't be used in brake applications. I just got a big can of Miller Red grease from the UK, cheap and have already been portioning out for some friends that also understand brake rebuilds and other rubber parts preservation.
Have tools, will travel!
Old 12-08-2012, 10:51 AM   #21
simonpig
packin' heat
simonpig's Avatar
Oddometer: 1,094
Thanks for the response, that makes a lot of sense about lubing the outer exposed seal with the grease.
Times are GMT -7.   It's 01:18 AM.
