Old 04-07-2011, 04:12 PM   #1
Frank06 OP
Oddometer: 211
Strange noise from Airhead Valve Cover
There was a *strange* noise coming from the area of the right-side valve cover on my '81 R100RT after a ride this afternoon. It sounded like an air leak (I thought I had picked up a nail or something at first.) Is the crankcase pressurized? I quickly removed the dipstick - no change. Head gasket leaking (this was only the 2nd ride after changing pushrod tube seals)? I removed the spark plug - no change. The noise slowly died away and I never determined the source. I started the engine a couple of times but it never recurred.
Advice, hints, theories, etc. appreciated! I've never heard a noise like this before.
Frank06 is offline   Reply With Quote
Old 04-07-2011, 05:41 PM   #2
supershaft
because I can
Oddometer: 6,082
Have you washed your bike since you got it back together?
Old 04-07-2011, 05:54 PM   #3
baldwithglasses
Godspeed, Robert
baldwithglasses's Avatar
Oddometer: 789
I bet it sounded like a moaning duck. My money also says it's your crankcase ventilation valve.
baldwithglasses is offline   Reply With Quote
Old 04-07-2011, 06:22 PM   #4
Country Doc
Wanderer
Oddometer: 2,442
My bet is that it's something that happened when you took that side apart to do the pushrod seals. Forgot to tighten the valve adjusters/set the valves? Forgot to torque the heads? A 10mm crescent wrench rattling around in there?
I'd take off the valve cover and have a _look_ before doing anything else.
dc
Country Doc is offline   Reply With Quote
Old 04-07-2011, 06:32 PM   #5
Beater
Scope Creep's Victim
Beater's Avatar
Oddometer: 2,214
My bet is that one of your carb tubes has bent or become 'unsealed'. It is a sucking sound, allowing unfiltered air to go directly into the carbutators ... mine did it and I tore the thing apart looking for it, and the tube had 'crimped' underneath because I had over tightened the pipe clamp.
I do these things for the common good, in the hopes that my idiocy will serve as a warning to others.
True story.
Fred
'85 R80RT G/Sified
'91 R100GS Bumblebee
Airhead Zen: Ride-Maintain-Repair-Ride On.
Beater is offline   Reply With Quote
Old 04-07-2011, 06:42 PM   #6
Frank06 OP
Oddometer: 211
No
Old 04-07-2011, 06:44 PM   #7
Frank06 OP
Oddometer: 211
It was a pretty loud "hiss" sound - where is that valve? Is that what feeds into the airbox?
Old 04-07-2011, 06:45 PM   #8
Frank06 OP
Oddometer: 211
True story.
I wasn't clear, but the engine was not running when this happened. It wasn't a carb sound.
Old 04-07-2011, 06:45 PM   #9
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 7,361
My first thought exactly!
The first time that happened to me it drove me nuts! What happens is a well is formed between the head and valve cover near the spark plug. When the bike warms up the water boils and makes that popping hissing sound.
Wirespokes is online now   Reply With Quote
Old 04-07-2011, 06:46 PM   #10
Frank06 OP
Oddometer: 211
dc
I think you're right; I did all that but it can't hurt to double-check. I'll do it tomorrow early a.m. and report back.
Thanks for everyone's thoughts.
Old 04-07-2011, 10:00 PM   #11
supershaft
because I can
Oddometer: 6,082
I forgot to ask if it got rained on. From the way Frank06 is describing the noise, I can't see how it is anything else. After the bike is shut off and for some time?
Old 04-08-2011, 03:31 AM   #12
Frank06 OP
Oddometer: 211
Hmmm, now that you mention it, it did rain (quite a lot) on the first ride a couple of days earlier, but it didn't make the noise after that ride and it's been warm(er) and dry since then. And I didn't see any water when removing the spark plug; the noise sounded like it was inside.
Old 04-08-2011, 09:47 AM   #13
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 845
Yeah, water can collect around the spark plug indentation and then boil off. Normal when wet.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 04-08-2011, 10:25 AM   #14
supershaft
because I can
Oddometer: 6,082
You would have to remove the valve cover to see the water. It gets trapped in that little gap right in the center of the cover between the head and the cover. I suspect this is what you are hearing. They all do that.
Old 04-08-2011, 12:37 PM   #15
Frank06 OP
Oddometer: 211
Ah-hah. Well, I'm surprised that the water would be there after sitting around and being ridden for a couple of days but it sure sounded like that!
Nothing amiss under the valve cover and the bike runs fine (knock, knock) so we'll assign probable-cause to trapped water.
thanks everyone!
Times are GMT -7.   It's 10:32 AM.
