Old 05-08-2011, 06:12 AM   #46
gsuser OP
Amateur Explorer
gsuser's Avatar
Oddometer: 298
Originally Posted by ClearwaterBMW View Post
i was thinking the very same thing
if only we could have THIS tire on the GS
now THAT would be awesome
On my GS the mods would have to start at the Y pipe, where the muffler slips on it woud have to move probably and inch to the left. Which means the Remus (smaller than the stock muffler) wouldn't clear the Jessie box so that means a new muffler.
As far as getting the power to the ground this 175 Nitto that I have does the job.
"Have you ever noticed? Anybody going slower than you is an idiot, and anyone going faster than you is a moron." George Carlin
Save $5.00 on Smugmug, coupon code 55zuywCalohxw
gsuser is online now   Reply With Quote
Old 05-08-2011, 06:46 AM   #47
ClearwaterBMW
The Examiner
ClearwaterBMW's Avatar
Oddometer: 5,972
i love that 175 Nitto
i'll have to see how the 155 does when the hack returns in about 6 weeks (i hope)
Greg
'11 R1200 GS Adventure with a DMC M72DX Sidecar
'14 R1200 GS & '14 R nineT (march, 2014)
Live life like you mean it... but take your family and friends (and DOGS) along for the "ride"
ClearwaterBMW is offline   Reply With Quote
Old 05-08-2011, 06:51 AM   #48
gsuser OP
Amateur Explorer
gsuser's Avatar
Oddometer: 298
155
I had a 155 Kuhmo on for a few test rides, lots of clearance, does wonder for the gear ratio being so small in diameter, it just looked a little wimpy under the GS. Size does matter
Old 05-08-2011, 07:42 AM   #49
ClearwaterBMW
The Examiner
Oddometer: 5,972
1. the tire has a smaller diameter at the RIM, but is FAR TALLER than the "corresponding" motorcycle tire it is replacing
so.....
the OUTSIDE diameter should be ALMOST THE VERY SAME as the standard tire...
you can see this simply by how the bike "SITS" on the center stand...
exactly the same way as it would with the standard motorcycle tire... which sits on a larger diameter rim, but has a lower profile
as for your... "size DOES matter" comment....
well....
simply put....
that's why i had to go to medical school.... just to get a date
Greg
Old 05-08-2011, 10:27 AM   #50
gsuser OP
Amateur Explorer
gsuser's Avatar
Oddometer: 298
rim
Is that one of the Weld Racing Draglite rim?
Old 05-08-2011, 11:00 AM   #51
ClearwaterBMW
The Examiner
Oddometer: 5,972
actually, the wheel we have chosen (pictured above) is:
http://www.jegs.com/i/JEGS+Performan...69002/10002/-1
Greg
Old 05-08-2011, 03:33 PM   #52
gsuser OP
Amateur Explorer
gsuser's Avatar
Oddometer: 298
wheel
I think the next adaptor will be built around one of the Jegs wheels. There price is good and that sure looks nice on your 1200.
gsuser screwed with this post 05-08-2011 at 05:06 PM
Old 05-08-2011, 04:38 PM   #53
ClearwaterBMW
The Examiner
Oddometer: 5,972
I think the next adaptor will be built around one of the Jegs wheels. There price is good and that sure looks on your 1200.
thanks
i appreciate that
can't wait to SEE my rig... in person...
it'll happen one day very soon, i'm sure
Greg
Old 05-09-2011, 08:26 AM   #54
xpyro
Oddometer: 4
solo
Originally Posted by lousot View Post
[thats a nice rim
thanks
i appreciate that
That is a nice looking wheel and tire! I was just wondering how the bike handles solo (no hack).
xpyro is offline   Reply With Quote
Old 05-09-2011, 10:50 AM   #55
Abenteuerfahrer
Deaf on Wheels
Abenteuerfahrer's Avatar
Oddometer: 2,302
uuHHH....you don't want to even try that.. with front end mod and square car tire in rear. Did that in Alaska after sidecar mishap...uh....
Abenteuerfahrer is offline   Reply With Quote
Old 05-09-2011, 04:53 PM   #56
ClearwaterBMW
The Examiner
Oddometer: 5,972
as elmer said just above me
after the trail-reduction steering modification...
even without the car tire on the rear, the bike is UNrideable without the sidecar
with the car tire... nope...
please don't
Greg
Old 05-18-2011, 05:46 PM   #57
gsuser OP
Amateur Explorer
gsuser's Avatar
Oddometer: 298
Part 2
So since my adaptor has not fell apart yet, about 700 miles on it, it is time to make one for my buddies 1100GS. This one should go a lot quicker as we have most of the dimensions, although he is using a different wheel, and we have figured out the which machining process to do in which order.
Old 05-19-2011, 05:26 PM   #58
gsuser OP
Amateur Explorer
gsuser's Avatar
Oddometer: 298
adaptor #3
So I was working on the the adaptor for the 1100 and I had this idea, why don't I make 2 at a time, since I already have the parts setup to turn and drill I might as well do two. I do have 1 more piece of aluminum that needs a project.
Old 03-06-2012, 05:46 PM   #59
pops
Oddometer: 1,589
Hi. Any updates
pops is offline   Reply With Quote
Old 03-29-2012, 03:44 AM   #60
pops
Oddometer: 1,589
Made a little progress on both projects, sprayed some primer on the kneeler and got the wheel adaptor ready for wheel studs and setup to do the counter bore for the BMW bolts to the final drive. I am waiting for some countersinks from McMaster & Carr.
Hi gsuser.I am having some trouble finding a countersinks to put the taper on our adapters .
I have just gone to two wheel drive and i need to put the tapers in the adaptor to get the bolt head lower to fit a u joint flat on the adaptor face.
What did you end up using type ,size please.
Thanking you Ian Ian
Times are GMT -7.   It's 05:39 AM.
