Old 12-20-2014, 05:54 PM   #1
headtube OP
6 mesas de invierno!
headtube's Avatar
Oddometer: 323
Is my steering stabilizer toast?
Well, the obvious dried up fluid would point to a resounding "yes", but it does have some resistance. I've never had one in my hands until now so I don't know how hard the resistance should be. Also... do these bikes really need one? Can I run without it or I'm I asking for trouble at 80mph plus?
headtube is offline   Reply With Quote
Old 12-20-2014, 05:59 PM   #2
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,963
you can ride one just fine at 80 plus without one, no trouble there. Or: it wont be what makes or breaks the ride at that speed
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 12-20-2014, 06:15 PM   #3
Pokie
Just plain Pokie.
Pokie's Avatar
Oddometer: 1,017
Like Stagehand says, you shouldn't need it anyway. Just leave the silly thing off and plug the hole in your cap nut with a rubber plug. I haven't had a bike with a functioning steering damper for years.
Pokie is offline   Reply With Quote
Old 12-20-2014, 06:20 PM   #4
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,233
It is possible to make it work again if the shaft seal is still good. The fatter tubular section is the reservoir and it's sealed up with some sort of hard caulking material. Often, that's what leaks. If you can dig the stuff out of there and seal it back up with fresh fluid, it'll work again.
Usually, if a damper is low on fluid, it'll have resistance part way out and then move easily the rest of the way.
Some of the airheads came with steering dampers, some didn't. You'll be fine without it.
Old 12-20-2014, 06:25 PM   #5
ME 109
ME 109's Avatar
Oddometer: 3,022
Not needed ime.
If one has a wobble, fix the wobble instead of relying on a bandaid.
Lord of the Bings, kangaroo farmer
ME 109 is offline   Reply With Quote
Old 12-20-2014, 09:07 PM   #6
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,141
^^^ +10.
--Bill
'73 R60/5 Toaster
Old 12-21-2014, 07:50 AM   #7
headtube OP
headtube's Avatar
Oddometer: 323
This sounds interesting. I just might try it. Do you know what weight fluid to use?
Old 12-21-2014, 08:12 AM   #8
supershaft
because I can
Oddometer: 9,116
That thing definitely needs seals and oil.
I have never had one on one of my bikes. I would like to have one if they weren't so expensive. The stock setup? They work but not that well. Part of it is mechanical IMO. A good setup has ZERO slop. A good setup does a whole bunch of very important damping before the stock setup even gets a chance to for slop. Pretty much ALL the new hot setups have them. Even dirt bikes use them to good effect now! I have ridden a few with high dollar setups and it was nice.
They are mostly for hard riding. Riding street bikes hard is always a tank slapper waiting to happen no matter how smooth your are and that is the sort of thing steering dampers are good for!
Old 12-21-2014, 03:10 PM   #9
headtube OP
headtube's Avatar
Oddometer: 323
Si Señor... but need to know what type, weight and amount of oil to add.
Old 12-21-2014, 03:14 PM   #10
ME 109
ME 109's Avatar
Oddometer: 3,022
And where to get the seals?
Old 12-21-2014, 07:07 PM   #11
headtube OP
headtube's Avatar
Oddometer: 323
No seals available. But you knew that.
A discovery...
I decided to strip the unit of it's paint and greasy mess with aircraft stripper to get a better look. The seal in question is made from a fibre gasket type material and a lot of it could be scrapped out with a dental pic.
I will use a plumbers epoxy putty that hardens like steel on this joint and seal up both ends of the reservoir. Then I will drill a hole in the reservoir and add the oil, (but still don't know what type and how much). Perhaps this will be trial and error. Then I will fill the hole with putty or drill and tap. Nothing to loose right? If it works, great. If not, into the trash.
Old 12-22-2014, 03:30 PM   #12
Thorazine
Likes exhaust fumes
Thorazine's Avatar
Location: Smoggy Valley, east of Smog City, Southern Calif.
Oddometer: 835
I've always heard differently (including from one of Oak's articles). It would seem to make more sense for high-speed, but they're mainly for low-speed off-road use. Sumpin to chew on.
Bones aren't important; we like motorcycles.-- My boy D @ 4 y/o
* Posts submitted under the moniker Thorazine are for entertainment purposes only, and may include exaggerations, prevarications or bald-faced lies. -- Thorazine - '74 R90/6
Thorazine is offline   Reply With Quote
Old 12-22-2014, 07:12 PM   #13
headtube OP
headtube's Avatar
Oddometer: 323
Hard riding doesn't necessarily mean straight line high speeds. Consider sticky tires, hot pavement, and some serious RPM's leaning over hard coming out of a corner. I think the Shaft has got it right. With all do respect to the Oak-man.
Old 12-22-2014, 09:44 PM   #14
ME 109
ME 109's Avatar
Oddometer: 3,022
A dampener is good value on an airhead if you get the front wheel off the ground whilst leaned over.
It's a shit-fight when the wheel touches back down again and loads up.
Lesson learned, do wheelies in a straight line.
Other than that, dampeners are overrated. If you got a wobble, fix it.
Old 12-22-2014, 10:17 PM   #15
Wirespokes
Wirespokes's Avatar
Oddometer: 8,233
If I'd had the damper cranked up when I hit the elk, it's possible it could have stopped the tank slapper and I might have been able to prevent going over that 20ft embankment.
You never know when you might need the damper to do its job. Kind of like 'all the gear all the time'.
I'd try 15wt fork oil. See how that works. Maybe even 20wt. I've heard ATF is 15wt - perhaps use some synthetic ATF.
Times are GMT -7.   It's 02:21 AM.
